Question about Magic Chef MCD1311ST Microwave Oven
Won't heat My microwave comes on and turns, it just doesn't get hot. Can you tell me what might be wrong with it?
    Genius:
  • 1,416 Answers
what you need to no is that the problem can be from three place 1) from the connection 2) from the element 3)and from the power supply
solution to problem one, unscrew your wave and then trace the wire down to the element were is connected to,to see if there is any form of disconnection if there is you can do the fixing by setting up the wire back to it position but if there is no form of disconnection .
then this mean that your wave element is weak it will need a replacement
while the last of it is the power supply box make sure that is in it best position
if all these can be put in there position your wave will work out fine again
please rate this
Good luck and thanks for using fixya.
Posted on May 27, 2010
Wolf convection microwave
see the next steps , use the VOM and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Jun 17, 2013 | Microwave Ovens
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
GE Profile Spacemaker 2004 JVM3670BF02 doesn't Heat up
Ensure that you have select the correct range of temperature.
Sep 11, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't heat
Sounds like the magnetron has failed. :(
May 18, 2012 | GE Microwave Ovens
My Oster microwave (model #OGG21401) doesn't heat. When operating the light will turn on and the carousel will turn but food will not get hot. Can you provide a solution to my problem? Thank you.
Check the door safety interlock switches for proper operation. #1 trouble with microwaves that operate in all respects but no heat.
Thanks for your question @ FixYa.com
Sep 16, 2011 | Oster 0.7 Cu. Ft. Compact Microwave
We have a sunbeam microwave. it starts but the light doesn't work and it won't heat the food. what should we do?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;'
Sep 01, 2011 | Sunbeam SMW750 Microwave Oven
AMANA MICROWAVE RFS-12SW2 from subway. I have 3 broken microwaves. and repair guys won't change parts to fix. so i am willing to change it myself. one of them has no heat. two of them doesn't...
AMANA MICROWAVE RFS-12SW2 from subway. I have broken microwave. and repair guys won't change parts to fix. so i am willing to change it myself. one of them has no heat.. any help and manuals? thank you
Jul 24, 2011 | Microwave Ovens
How to fix an Emerson microwave 8992RD that carousel doesn't turn and doesn't heat your food..
heatman101
May 08, 2011 | Emerson Black Microwave Oven
I have emerson microwave, when you put something in it the lights comes on, it turn but it does not get hot, what is wrong with it.
most liklet its the (magnatron?) my have spelt that wrong?? thats the part that heats the food up,,,,there very pricy to buy so you may be better off getting a new unit,,,,,
dont open the case up to see if you can fix it,,there is a very big capasitor inside the microwave it holds 1000,and 1000, of volts for a very long time too, if you tuch this capasitor with all them volts still in it, ,,,it could and likley would kill you??? just figerd i should tell you that!!!!
Aug 08, 2010 | Emerson Microwave Ovens
Magic Chef MCD1311ST Microwave Oven Logo
308 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
charles
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
