Question about Noritz 6.3 Gallon Residential Tankless Water Heater - N-063S
Will not try to lite
My noritz n-063s-1 well not lite what could be wrong
    Scholar:
  • 73 Answers
1) First make sure you are getting power into the unit.
2) Then check for any visible water inside the unit which might indicate a leak.
3) The third possibility is the flow sensor being stuck. Try opening a large flow of water (bath tub, two sinks and shower) and see if the unit fires. Otherwise you may want to contact a servicer to clean this component.
Posted on Jul 30, 2010
How to descale a noritz tankless water heater
1) Copy following links for general descaling resources for Tankless:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#de-lime
2) Add a comment with what you discover
Jan 04, 2013 | Noritz 6.3 Gallon Residential Tankless...
The Noritz HW Heater has been tripping out some (usually whenever the shower is running, and someone turns on cold water). LED flashing three times. Any Ideas
This is probably a 16 error code. This code indicates the outlet water spiked above the set temperature for an extended period. It usually means the heater needs to be descaled or the manifold pressures need to be adjusted.
Mar 10, 2011 | Noritz 6.3 Gallon Residential Tankless...
I have a Nortitz natural gas water heater, model #N-063s-1. Acouple of days ago it stopped heating the water. what can I do myself to fix this matter. Thanks, lynnatheana@hotmail.com
There are many reasons a tankless heater will stop heating water. The first thing I would look for is a flashing red light on the burner indicator. The flash break down goes as follows
continuous blinking - typically means ignition failure or the unit is overheating; look for visible water inside the unit, have your gas pressure checked, or check the flame rod/igniter for buildup of debris
three blinks - typically indicates 16 error code; typically resolved by performing a descale
4 or 5 blinks - exotic error codes; for these you should definitely contact Noritz tech support
If there is no flashing light, first check your filter for debris. If the filter is clean, your flow sensor is probably stuck. Again I'd recommend contacting Noritz tech support to help you clean the flow sensor.
Jul 31, 2010 | Noritz 6.3 Gallon Residential Tankless...
For a noritz N-06315 do I need an aux drain pan if it is installed above a living space
It depends on local code, no all cities/states require drain pans, but it is always a good idea if you don't want to deal with water damage.
Jul 18, 2010 | Noritz 6.3 Gallon Residential Tankless...
Why does my hot water always turn off after a couple minutes
the 90 error code will be caused by one of two things:
1. the incoming gas pressure is low
2. the unit is dirty and needs to be cleaned
Jun 30, 2010 | Noritz 6.3 Gallon Residential Tankless...
I have a noritz water tankless heater and hot water stopped. Red light blinking three times. Need help.
Three flashes typically indicates the unit is overheating due to scale. I'd try a descale initially and see if that remedies the problem.
Dec 27, 2009 | Noritz 6.3 Gallon Residential Tankless...
Change temperature on noritz N-063S
the only way you can is to pull the jacket off and find the right plug ends to put together to bump the temperature up.you will see them they are all labeled. the controller is alot better to have especially because it will tell you if you have any problems with it before it freaks out and kicks the bucket!
Jul 31, 2009 | Noritz 6.3 Gallon Residential Tankless...
Noritz 6.3 Gallon Residential Tankless Water Heater - N-063S Logo
187 people viewed this question
Top Noritz Water Heaters Experts
jasbo
jasbo
Mack Baxter
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
