Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Not draining and check water light on - Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
    Sergeant:
  • 228 Answers
You have a blockage in drain pump consult manual for cleaning process when water drained away check water light will go out.
Posted on May 27, 2010
Place towels at front of machine on the floor. tip forward water will come from bottom. this is a short term solution you could have a leak from your machine. call engeneer to check. ok to use on short term.
Posted on Jun 08, 2010
Miele G 851Intake/Drain light flashes and program stops
http://m.miele.ca/OperatingInstructions/en-CA/Dishwashers/Previous%20models/Miele%20Dishwasher%20Manual%20G851%20SC%20Plus.pdf
Page 39
Jul 01, 2015 | Miele Dishwashers
Water is not draining from the bottom of the dishwasher and there is an E25 message and the check water light is on?????????
The drain pump is not working , possible that the drain pump is clogged or faulty as it fails to drain off the water after the wash. It is best to remove the drain pump and check the continuity, if not clean and reset.
check this link for help:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
The error is due to the failure of the water to flush out and is making the cycle extend.
Sep 08, 2011 | Dishwashers
Dishwasher not emptying at the end of its cycle. If water siphoned out will work temporarily then fails again, with water remaining standing inside machine. Check water indicator light is on, goes off when...
Not sure of your light indicator; check the manual. But fyi there should be a little water left in, so the rubber seal doesn't dry out. More than that, and could be clogged drain or bad solenoid, which tells it to open and drain. See: http://www.partselect.com/repair.aspx?appliance=dishwasher&part=water-wont-drain
Sep 17, 2009 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Both the intake and drain lights are flashing
There are several simple solutions, one is reading the instruction manual. Check Intake: is any water entering? is it slow? This machine filters debris from the supply water so check the water intake filter. It is inside the end of the intake hose end against the home. Rinse it clean.
Drain: The same fault appears if the drain is clogged. Check if the lint trap is perfectly clean. Check the impeller (a set of fan blades) behind it spins freely. If buttons or coins get in there they can break off the fan blades and you can't drain water. Check the end of the drain hose if it drains. put it into a bucket or tub basin to observe how strong it pumps. Call Miele if these tips don't work. Be at the machine with Model and Serial number ready.
Dec 16, 2007 | Miele Touchtronic W1113 Washing Machine
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
638 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
