Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
I need programing instruction for Hobart LX30H to lower temperature settings. The one in the manual doesn't work. Can you help?
  • Hobart Master
  • 3,247 Answers
Please confirm if you have seen this Instruction manual
http://www.askanowner.com/_upload/1_2/attachments/LX30H_1.pdf
Posted on May 27, 2010
Hobart lx30h leaking from bottom
This is a testing for the post on this web site, not a solution.
Mar 27, 2014 | Hobart Lx30h Commercial Dishwasher
Hobart lx30h rinse additive is running all the
The main cause is the "anti flood" device at the bottom of the washer that detects a water leak "hose leak" etc. This device made up of a polystireen float and micro switch is a safety device and when activated puts the washer in pump out mode only. You need to look at the base of the washer and see if water leak has caused this. Rectify the cause "normaly hose or clamp" and this should clear the
Mar 21, 2010 | Hobart 29 in. AM15-1 Free-Standing...
Hobart dishwasher model LX30H displays -5 on
by the way you're describing the problem, i would have to say there is something wrong with your control board. part#473173 can be bought @ any hobart office in your area. dont forget to vote
Feb 07, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Lx30h P2 ERROR CODE? WON'T DRAIN COMPLETELY - HELP
the p2 err. is on open or shorted rinse thermistor which is located on the back of the mach next to the vac. brkr. as for draining ck the drain valve for debris, and the end of the drain hose where it connects to the building drain
Dec 25, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
P1 error code on LX30 Hobart
This is a bad sump temperature probe. The unit will function, but will not heat nor display the wash water temperature.
This is a very easy fix. Order Hobart part number 328994 from your nearest Hobart parts dept.
Turn off and drain the unit. Kill the power to the unit at the circuit breaker. Remove the lower front cover. Locate the screw-in temperature probe at the front of the sump. Unplug the sensor from the wiring harness, remove with a 7/16" open end wrench. Screw in the new probe, using teflon tape of the threads, snuggly. It does not need to be super tight. Plug it into the harness, reinstall the front cover, turn the breaker back on, and start up the unit.
TURN THE BREAKER OFF AS EVEN WITH THE UNIT "OFF" THERE WILL BE 120 VOLTS PRESENT AT THE SUMP HEATER (yellow wires) DUE TO ONLY ONE LEG OF POWER BEING SWITCHED OFF!
Sep 04, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Temperature Problem
Whats the model?lxih,lx30h,lx18,lx40?What temps are low,wash or rinse?Im a hobart tech and service these units.Let me know.
Jan 19, 2009 | Hobart 24 in. LXIC-5 Built-in Dishwasher
LX30H Hobart torsion bar adjustment
im a service tech for hobart,there are no adjustments,the torsion bar is broken.the parts arent expensive but installing them are tricky.
Dec 06, 2007 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
83 people viewed this question
Top Hobart Dishwashers Experts
Jason
handygirl911
handygirl911
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
