Question about Zojirushi BBCC-X20 Home Bakery Supreme Bread Maker
On dough mode, machine won't knead
When trying to make a dough to be baked in the oven, not the bread machine, I set the machine to run on a basic dough cycle. I checked on it by the time it had reached the rise step, towards the end of the cycle, and found tha the bread hadn't been kneaded at all, though that step should have been earlier. What's the problem? I attached the kneading knobs according to the picture in the book and set the machine properly!
    Problem Solver:
  • 5 Answers
Paddles could be slipping. that was my issue. Here's the solution if so.
What happened in my case is that the nut holding the rotor that drives the left paddle was loose, allowing the paddle to slip. Only one paddle would knead and mix. The belts in my machine are fine, in fact so massive I can't imagine them breaking. But access? Yikes.
So, forget the screws on the bottom. They just hold on the feet. Remove all the screws around the top of the baking chamber, the two that hold the control panel on, and the remaining screws under it. There are about 12 screws. Remove the 6 at the bottom of the baking chamber, but not the 2 that hold down the element. Remove the metal sides of the baking chamber (it's one piece). All this is to get access to the screws that really hold the works to the base. They're around the perimeter of the metal chassis on which the motor and element are mounted. Remove them (get help or arrange something to keep the control panel from exerting too much pull on the wires to the element. You could unplug the control unit but I didn't need to.)
Once you lift the motor assembly exposing the belts underneath, you'll see what's loose. Each nut holds down a metal plate beneath the rotor. If it gets loose, the rotor can move more or less freely and won't turn. It looks like they applied an inadequate dab of glue to hold those in place. I should have put in a star washer to keep the nut from loosening again. Next time.
Good luck getting all the screws back in the right places ;-) Machine works fine now.
Posted on Jun 27, 2010
Mixing OK but not heating/baking
That's not a good sign. This will keep your bread from rising properly and baking, obviously.
If you are still under warranty, contact your manufacturer, otherwise, you can still use the machine to mix but you will need to use your oven to finish your bread.
If your bread is not rising in the machine:
  • Remove mxing chamber from machine
  • If the chamber is not removable, UN-PLUG THE BREAD MACHINE so the blades DO NOT TURN.
  • Be careful of the mixing blade in the chamber
  • Remove dough gently with slightly oiled hands into a lightly oiled bowl with room for about 2x the volume of the dough
  • Cover with plastic wrap to prevent the dough from drying
  • Place the bowl of dough in an unheated oven and leave the oven OFF
  • Place an empty lasagna pan in the cold oven on a shelf below the dough or on the floor of the oven if there are no exposed elements
  • Boil some water and pour it carefully into the lasagna pan
  • Close the oven door - You have just made a proofing box. The steam and heat from the boiled water is sufficient to make a great proofing cabinet out of your oven hot box
  • Allow the dough to rise to about twice the original volume
  • remove the dough from the oven and remove the pan of water
  • continue with the baking instructions below
If your bread is rising in the machine or you have finished the above instructions:
  • Remove dough gently with slightly oiled hands into bread pans. Breadmakers are different sizes so you may need to use one or two pans. Or make an artisan style loaf on a cookie sheet lined with parchment.
  • Be careful not to compress your risen dough as this will make the loaves dense
  • You may also choose to make buns by separating the dough into smaller balls and placing on parchment lined cookie sheets
  • You can allow the dough to rise again for a short time in the proofing box above but I would just leave them on the counter under clean towels to prevent drying for say another 20 minutes. Over-rising bread should also be prevented. The result will be 'deflated' looking bread.
  • Preheat your oven to 375F and bake the bread until it is golden and makes a hollow sound when thumped on the top or the bottom crust
Personally, I love that a machine will mix and knead my dough for me while i go do something else but I don't like the appearance of a machine baked bread. I like the artisan hand-made look. I recommend you keep the breadmaker until you find one you like that is drastically reduced in price and just use the artisan proofing & baking options above.
If you have a Pizza Stone, you can also try that for baking an artisan bread. Use the breadmaker as the workhorse, use your oven as an artist.
Good Luck and may the Yeast be Lively!
Apr 02, 2015 | Kitchen Appliances - Others
How can I get the machine to start the bread making process from the beginning. It is currently stuck on knead.
Do you have your owners manual and have you baked bread in your machine before? Just want to be sure that you know the stages that the machine goes through. The first mixing and kneading stage in a tr444 will take up to 15 minutes before it stops on its own. It will then let the dough rest for about 1/2 hour before the 2nd knead begins. It takes almost 4 hours for your machine to go through all the stages before your baked bread is finished.
Jan 15, 2015 | Breadman TR444 Bread Maker
How do i get breadmaker just to bake?
According to the manual, I don't think there is a bake only mode. There is a "dough mode" that reads "Use this setting for yeast recipes that only require mixing, kneading and will be shaped by hand. After the end of the first rise, remove the dough, shape the dough and bake it in a conventional oven."
I wasn't able to find a 1010 manual, but did find one for a 1021 (I believe that they are similar). You can download a copy here:
http://kitchen.manualsonline.com/mdownloads/d150413a-28fb-4636-9a77-0d39a015dddb.pdf
Apr 24, 2014 | Pillsbury 1010 Bread & Dough Maker...
Bread machine model TR520, mixes the dough, stops for a long time, then starts mixing the dough again continuously without starting the bake cycle. This was on the french program. The machine is new...
By continuously do you mean forever, non-stop kneading? I'm guessing not. French bread is really nothing more than white bread dough kneaded for an extra long time. The extra kneading creates the chewyness common to French breads.
Hope this helps!
Jun 17, 2011 | Breadman TR520 Bread Maker
I have a toastmaster Bread Box bread machine...I am making French bread...the banging noise was so loud I stopped it fearing the machine was broken...is it ? If not should I continue the kneading/baking...
Unless the sound is mechanical like metal on metal etc. what you may be hearing is the sound of the dough ball being knocked around and kneaded. Sometimes that gets pretty loud. While it is kneading go ahead and open the top and see if you think the dough ball is making the noise. If it seems to be coming from somwhere else then you may have a more serious problem. Is this a new noise or it this the first time you have used the machine?
Nov 08, 2010 | Toastmaster 1183N Bread Maker
Keeading blades
I had the same problem. I find the loaves to be a much better size if I just use program setting 8 - Dough then put the dough in 2 regular bread pans or on cookie sheets (bagetts), let them have a second rising and finish them in the convection oven at 350 F for 21 minutes.
Nov 20, 2009 | Black & Decker B2300 Bread Machine
I need a manuel for my bread maker chefmate hb-12w
Here's the instructions for Model HB-215. Source =>
http://www.globalgourmet.com/forum/index.php?topic=47.msg222
The post below this post says Chef Mate - Models HB12W, HB215 and CM725 only! So, it might be the same instructions.
Chefmate Bakery Oven Model HB-215
Modes:
  • Standard 1.5 lb normal crust: Bakes a 1.5 lb basic loaf of bread in 2 hrs 30 min.
  • Standard 1.5 lb dark crust: Bakes 5 min longer.
  • Standard 1 lb normal: Bakes a 1 lb basic loaf of bread in 2 hrs 20 min. No “dark” option.
  • French mode: Bakes a French loaf of bread (salty taste) in 3 hrs 40 min.
  • Sweet mode: Bakes a sweet flavor loaf which tastes like a butter roll in 3 hrs 40 min.
  • Doughmode: Use this mode for making dough for rolls, croissants, doughnuts,etc., which you want to bake in your conventional oven. Prepares doughin 1 hr 20 min.
Control Panel: (when pressing a controlbutton, be sure to hold it down until you hear a “Beeping” soundindicating contact has been made.
  • Display: Shows the time remaining until a mode is completed. Can also display timer setting or mode selected.
  • Select button: Push to select mode: Cycles through modes in following order:
    Normal 1.5lb -> Dark 1.5 lb -> 1 lb -> French -> Sweet -> Dough
  • Start button: Push to start processing the mode selected.
  • Stop button: (press for one second to take effect)
    Push to turn off power after baking is completed or to reset the mode or timer.
    If used after a mode is started, it will stop it.
  • Timer set buttons: Up arrow: advances timer setting 10 min each time pressed.
    Down arrow: sets timer setting back 10 min each time pressed.
Ingredient Information
  • Flour– Use flour that is marked “bread flour” or “better for bread”. (Thesewill usually be labeled as having more gluten than regular flour.)
  • Dry Skim Milk – This enhances the flavor and adds to the nutrition of the bread.
  • Butter – Butter adds a rich flavor to the bread and makes it soft.
  • DryYeast – Yeast is necessary for causing the dough to rise. Select readyto use yeast which needs no preliminary fermentation. Use only activedry yeast. Don’t use 50% faster dry yeast.
  • Sugar – Sugar speeds up the dough rising process, adds flavor, and makes the bread soft and the crust brown.
  • Salt – Salt controls the activity of the yeast and makes the dough firm.
  • Water– Gluten is formed when flour is mixed with water. This allows thedough to rise by retaining air. The amount of water and its temperatureare very important. Usually, the water temperature should be between 68F/20 C and 77 F/25 C. When the room temperature is over 82 F/ 26C, usecold water (about 41 F/5 C). When the room temperature is under 50 F/10C, use lukewarm water (about 100 F/38 C).
Operating Instructions
Baking a standard loaf of bread using Standard Mode.
Ingredients for 1 lb loaf for 1.5 lb loaf
Water 7 ½ ounces (210ml) 9 ½ ounces (270ml)
Bread Flour 2 1/3 cups 3 cups
Dry Skim Milk ½ tablespoon 1 tablespoon
Sugar 1 tablespoon 1 ½ tablespoons
Salt 1 teaspoon 1 ½ teaspoons
Butter 1 tablespoon 1 ½ tablespoons
Dry Yeast 1 ½ teaspoon 1 ¾ teaspoons
1. Open the lid and remove the bread case (hold both sides of handle and turn counterclockwise.
2. Position the kneading blade on the drive shaft. (remove any crumbs from drive shaft.)
3. Place ingredients into the bread case. Add ingredients in the following order:
Pour in the proper amount of water.
Add the flour, sugar, salt, butter, and dry skim milk – in that order.
Place the dry yeast on the center of the flour.
Note:When using the timer, make a hollow depression in the ***** of flourand pour the dry yeast into it. Do not let the yeast touch the water orthe dough may not rise properly.
4. Place the bread case into the body of the baker. Turn clockwise to lock
5. Close the lid.
6. Plug in to outlet. (after being plugged in the number “0 00” will flash in the display.
7. Setthe standard mode. Press the select button to set the mode to Normal,Dark, or 1 lb, depending on your preference and the amounts ofingredients used.
8. Start. Press the START button. The timereadout in the display will begin counting down the minutes from theamount of time required for the mode you have selected.
Steam may rise from the vent on the back of the lid during operation.
When baking is finished, the buzzer will sound three times and the display will read “0 00”
9. Removingthe bread case. When the buzzer stops, press the STOP button and openthe lid of the baker. ( The heater in the unit will keep operating tokeep the bread warm for a while after baking is complete. When removingthe bread case, always be sure to press the STOP button to turn off theheater.) Using the handle and oven mitts, remove the bread case. Thehandle and bread case will be very hot. Do not place the heated breadcase on the body of the baker, table cloth, or plastic surfaces.
10. Removing the bread from the bread case.
Usingoven mitts, turn the bread case upside down and gently shake it toremove the bread. The surface of the bread case is slippery, so be sureyou have a firm grip.
If the bread can not be easily removed, turn the drive shaft on the bottom in both directions so loosen the bread.
Place the bread on a wire rack or similar surface to cool.
Note: when baking is completed, remove the bread as soon as possible. If leftin the case for a long period of time, its surface will become stickyand the flavor will be lost. If the kneading blade comes out with thebread, use a plastic or wooden utensil to remove it. CAUTION: it willbe hot.
11. Remove the plug from the outlet.
Baking a French loaf of bread using the French mode
Follow the above instructions, except select French mode in step 7 and use the following ingredients in the order shown:
Water 9 ½ ounces (270ml)
Bread Flour 3 cups
Sugar 1 ½ teaspoons
Salt 1 ½ teaspoons
Butter 1 ½ tablespoons
Dry yeast 1 ¾ teaspoons
Baking a sweet flavor loaf of bread using the Sweet Mode
As above, but select Sweet Mode in step 7 and use the following ingredients in the order shown:
Water 7 ounces (200ml)
Egg (medium size) 1
All Purpose Flour ½ cup
Dry Skim Milk 2 tablespoons
Sugar 2 tablespoons
Salt 1 ½ teaspoons
Butter 3 tablespoons
Dry Yeast 1 ½ teaspoons
How to use the timer. (The timer function cannot be used with Sweet or Dough modes)
The timer extends the time from pressing START until the baking completes.
1. Place all ingredients into the unit and plug it in.
2. Select the desired mode
3. Press up arrow once. The normal time for that mode will be displayed: 2:30 for a standard loaf.
4. Keep pressing up arrow (or down arrow) until the desired time to completion is displayed.
5. Press the START button to start the delayed timing.
Preparing a dough for handmade bread using the Dough mode.
1. Follow steps 1 through 6 for standard loaf. Select Dough mode in step 7.
2. Press START to begin the dough making process. It will take 1 hr 20 min. The display will show the time remaining.
3. Thebuzzer will sound 3 times to let you know the dough is ready. Take itout and shape it as you wish for baking in a conventional oven.
4. Unplug from outlet.
Dec 30, 2008 | Kitchen Appliances - Others
Baking gluten free bread in model 5890
good day,
hope this link below will solve your problem.
Set your bread machine program for 1.5 loaf medium crust. I used the gluten-free cycle on the Breadman; if you don't have a gluten-free cycle, I believe a rapid rise cycle will also work.
Check the dough after a few minutes of kneading- it should be closer to a muffin batter than bread dough, soft but not too wet. Adjust dry to wet ratio with a tablespoon of flour or warm liquid, as needed. Humidity influences the dough. As does temperature (your bread will rise higher on a hot day).
If you like a crusty loaf, remove the bread from the pan and place it in the oven at 350 degrees F for an additional 10 minutes- keep an eye on it and don't let it get too brown. It should be a light golden color.
Cool the loaf before slicing for best results.
Enjoy fresh from the oven- the first day (as with most gluten-free baked goods) has the best texture and taste
Read more: http://glutenfreegoddess.blogspot.com/2009/02/delicious-gluten-free-bread.html#ixzz0ZZASptEr
Dec 09, 2008 | Sunbeam 5890 ExpressBake Bread Maker
Kneading blade keeps baking into the bread- help!
Watch/listen to the machine your machine. After the last knead cycle, remove the paddle from the bake pan before the dough rises, continue to bake as normal.
Dec 05, 2008 | Sunbeam 5891 Bread Maker
Looking for manual of a chefmate bread machine
I have a manual for CM 725 if someone still needs it.
Sep 20, 2007 | Kitchen Appliances - Others
Zojirushi BBCC-X20 Home Bakery Supreme Bread Maker Logo
829 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
