Question about Acer AL2216W LCD Monitor
Screen turned blue tint
Screen turned to strong blue tint. how do i get it back to normal?
  • Bud Martin
    Bud Martin May 27, 2010
    Did you check all the pins on the VGA cable? Does it do the same with other PC?http://s807.photobucket.com/home/budm/al...
4 Suggested Answers
  • 17 Answers
SOURCE: blue tinted monitor screen
black and white tracking can vary in color depending on which color that the dispay is not getting enough of or to much of. In the case of it changing when you walk
in to the room, sugust that there is probably a loose connection or poor solder joint on the curicut board of the moniter. I don't suggust that you get inside the moniter and try to fix this due to dagerous voltage potential with in the moniter. Good luck
Posted on May 14, 2008
  • 3278 Answers
SOURCE: my screen has a blue tint over it
Sounds like a cable or video card.
Move the video cable - if the monitor switches from blue/normal or normal/blue, replace the cable.
Test the monitor on another PC - if it works, replace your video card. If it doesn't work, replace your monitor. Note: It your PC has an on-board video, it must be disabled in the BIOS.
Hope this helps.
Posted on Aug 12, 2009
  • 58 Answers
SOURCE: I unplugged my Acer al1914 monitor from my
Check the color settings in the on-screen menu. You can choose between "Warm", "Cool" and "User". Maybe you used the "Warm" setting before and somehow it got changed to "Cool".
If this is not the case, you can try the "User" mode and reduce the intensity of the blue channel.
If even black areas show a blue tint, maybe running an auto configuration from the menu helps.
As a last resort, use the "Reset" menu item which resets all settings to factory defaults.
Posted on Mar 30, 2010
I unplugged my Acer al1914 monitor from my computer and plugged a different acer al1914 in my computer and now when I transfer the screen from notebook to monitor it has a blue tint on the entire screen. I...
Mar 30, 2010 | Acer AL1914 19" LCD Monitor
My screen has a blue tint over it. I have restarted the computer. Every once in a while it will switch back to normal but then it just turns blue again.
Hope this helps.
Aug 12, 2009 | Computers & Internet
Normal screen is white background, but lately I am getting a blue tint that clears up sometimes and sometimes not. Please advise
Try hooking up another knowng working monitor to the computer and see if the blue tint comes back intermittently.
If it still comes up then you know your video card is the culprit. If the blue tint goes away then you know the original monitor is bad.
Aug 04, 2009 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Picture and menus are red-tinted all over
check system mode on dvd player,should be on pal
Jul 12, 2009 | Televison & Video
Strong red tint and a blurry screen
This is a serviceman only job.  It isn't worth it.  The parts and labor are at least $500.
Sep 15, 2008 | RCA P46924 46" Rear Projection Television
Monitor screen changes from regular color to a green tinted screen?
Is the cable connected securely? You may need to check your video card also. You may be able to disconnect the cable and get a red, green, blue icon on the screen. If that appears normal then there is nothing wrong with the monitor itself, it may be the cord or the video card.
Hope this helps!
May 31, 2008 | Dell 1503FP 15" LCD Monitor
Screen Green Tint
Turn down your color and see if the screen has a normal black & white screen. If it doesn't then the CRT is bad (picture tube). If it is black & White then you have a either lost your red or blue.That problem will be in your video driver circuit of which a service center can handle.
Feb 18, 2008 | RCA 20V500T 20" TV
Ds top screen half normal half green tint
i had the same problem  but it was blue tint shortly after the ds would turn on flash then turn off turned out to be the wire ribbon to top screen:: needed new top screen!!
Oct 22, 2007 | Nintendo DS Lite Console
Strong red tint with horizontal lines across screen
if you have warrenty, return it. if not, then buya new one...the video fuses are dying...hard to fix it.
Oct 06, 2007 | Akai PT4799HD Rear Projection Television
Occasional discoloring, tv randomly turns from green tint to no tint
Loose connections in CTR board ( picture tube), resolder it.
Aug 05, 2007 | Insignia NS- 27" TV27 TV
Acer AL2216W LCD Monitor Logo
228 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
