Humidity control for house. We are very sensitive to humidity in the house. We have the temp set at 75. At times that feels hot and other times that feels cold. It's a function of the humidity. If the AC is on we can feel comfortable at 75. If the Ac is not running we feel hot at the same temperature. Are there any thermostats availability that take both temperature and humidity into account.
  • Gerald Gier May 27, 2010
    Thanks..
    I just bought a new digital thermostat. Are there any add on that will do the same job
  • Gerald Gier May 28, 2010
    The idea I had in mind was an electric timer that could be set to run the AC for a set time, say 10 minutes every hour or so, but would be overridden by the thermostat if the temperature rose
    Guru:
  • 415 Answers
Yes. Look at Carrier's Thermidistat. Combined with a variable speed blower motor, you will enjoy optimum humidity control during the Cooling Season.
Posted on May 27, 2010
  • laura Newman May 28, 2010
    There are arrangements that can be configured to run your a/c and your electric heaters simultaneously............. it allows your a/c to run longer (to remove humidity) without overcooling the house......... obviously, it is an expensive option.
  • laura Newman May 29, 2010
    A timer might offer some limited amount of relief. Another option is always a portable dehumidifier. I, too, find myself sensitive to humidity levels. But it usually only affects me during the sleeping hours. Having a fan run...air blowing constantly helps me alot. But a dehumidifer could prove helpful. :-)
I am trying to figure out the icons on my Delonghi conditioner and I don't know what the one is that is a circle and it looks like part of a face is for
generally that icon is for a setting that maintains a relative humidity in the room as against the temp setting
it is a comfort setting so that you will not feel cold at a setting
understanding that air conditioners are conditioners of the air and they do that by removing the humidity ( moisture present in the air) to allow you to perspire more freely and so feel cooler
with near no humidity in the room a temp setting of 25 c will feel too cold so the smiley icon is a setting where the humidity is kept at a level where the 25c feels "just right"
all is explained in the user manual that you can download from the manufacturers web site if you do not have one
Jun 25, 2017 | DeLonghi Heating & Cooling
Tip
Taking the Confusion Out of Using a Dehumidier
Many consumers are confused about setting the proper levels of humidity on dehumidifier units. And then think something is mechanically wrong with the unit. When in fact, over 70% of the time it operator error. That and a lack of proper routine maintenance are the problem.
The numbers on the LED screen represent the amount of humidity you want to maintain. Not the amount you want to remove. For example: If you set the level at 70%, which is rather high, more than likely the unit may start up momentarily and then shut OFF. That's because the setting is to high. Now, if you set it at 45%, the unit will turn ON and run until either the bucket is full and/or the humidity level has reached 45%.
Here's a good rule of thumb if you use your humidifier year round.
In the Winter you want to maintain a humidity level of 50 to 60%. The moister the air, the more comfortable it will feel. Plus, the humidity helps eliminate static electricity in the air.
Conversely, in the hot, humid Summer months, you want to keep the humidity level as low as possible (35% or less). Also, if you have ceiling fans, using them 24 hours a day, helps to move the air and generate a windchill, which fools your body into thinking it's cooler than what it really is. At the same time, it's saving on energy costs by not having to run your AC as much, because the dehumidifier is removing the humidity.
Just remember, the higher the setting, the higher the humidity level will stay. The lower the setting, the more humidity will be removed and the more comfortable you'll feel in the Summer.
And don't forget Routine Maintenance. Clean the air intake filter regularly. Clean and wipe down the refrigerant coils every 60 days. And don't allow water to remain in the collection bucket to long. As mold can build up in it.
Speaking of which, the water in the bucket, when fresh, is great for watering house plants. Because, when it's fresh, it's distilled water. No chlorine or minerals.
on May 04, 2011 | Maytag M7DH45B2A Dehumidifier
Can my 3 in 1 air cooler also be used as a dehumidifier
an air cooler is a dehumidifier by definition
It cools the air around the evaporator giving you cool air and at the same time any humidity in the air is condensed into water and drained off
to understand air conditioner principles it goes something like this
we sweat and the more we sweat is because of the humidity in the air
if the air temp is 30 degrees c with a humidity of 75% then we feel that it is a very hot muggy day simply because the humidity stops the sweat from evaporating and allowing the skin to cool
Now it you take the humidity out of the air and at the same day temperature , you will actually feel cool because the sweat can evaporate and cool the skin
now you can understand that the best setting for air conditioning is 25 degrees c because if the setting is lower then the skin gets too cool because there is no humidity to restrict the evaporation of the sweat
modern spilt systems have a mode called comfort where the fan and the compressor work to maintain a constant level of humidity when sleeping and you don't get cold especially towards the morning
Jul 29, 2015 | Dehumidifiers
What are my humdity settings for DH504E Unit?
Simply put the humidity extraction settings generally range from 35% to 65%. The lower the percentage, the more humidity is removed and the house feels more comfortable. The higher the percentage, the more humidity remains in the house. In the hot humid Summer months, you want the humidity in the house to be as low as possible (i.e. 35%-45%) in the cooler months a higher humidity
( 60%) make the house feel more comfortable and does away with carpet static shock.
Choosing a setting is your decision, based on what I have explained above and your own comfort level.
I hope my information has helped you and thanks for choosing FixYa.
Aug 22, 2011 | Goldstar DH504EL Dehumidifier
I have an existing honeywell thermostat - 4 wire hook up. I added a honeywell humidistat. I hooked it up for series operation meaning when we leave the house in south Florida for the summer, the humidstat...
That 's a really good idea. My question would be is that a two wire humidistat? If it is. you would have to parallel the wires. One wire on the "R" on the thermostat and the other would go on "Y" and jumper to "G". Really interesting , I would like to know if it works. I live in Okla. and we have real high humidity summers but probably not like Florida. Hope this helps you.
May 14, 2011 | Honeywell Heating & Cooling
Our house is extremely humid and the a/c needs to be set lower to feel cooler. What are we doing wrong regarding aprilaire humidifier on our furnaces? Shouldn't they be turned off? yet the directions...
Hello
It depends on personal preferance,an air conditionner is going to remove humidity or water from the home,as water contains heat.
I would shut off the humidifier.The 40% setting depends on where in the world your located,say nevada is dry and hot so you may want a humidifier.Where florida is hot and humid so you would want to dehumidify or get rid of the humidity.
Lower the setting to 20% or just turn it off.
May 03, 2010 | Aprilaire 600 Humidifier
I have a Honeywell programmable Thermostat (an expensive one that handles humidity, etc) and every spring and fall the thermostats behave improperly by ignoring the programmed temperature and cooling the...
What is the model number of the thermostat? What may be happening is the humidity control is trying to satisfy the humidity setting by running the a/c. In the installers set-up, there should be a setting to determine how long the system should run to satisfy humidity setting. I typically set thermostats for a 3 degree droop. Meaning it'll only drop 3 degrees below set temp. Also check your humidity setting to be sure it's not set too low. It should be set between 45% and 50%.
May 03, 2010 | Honeywell Programmable Thermostat Heater
Hi I need help understanding the controls to my humidistat. I have a honeywell a/c unit so I'm assuming the gold colored humistat next to it is also honeywell. I bought a digital temperature and humitiy...
The higher the % of RH, (relative humidity), the more humid the house will be. I would disregard the temp part of the dial, and focus more on your comfort. Adjust it up daily until you reach a satisfactory humidity level. Hope this helps
Dec 19, 2009 | Honeywell Power Humidifier: Furnace...
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
Temp
Before an evaporation cooler will feel "cool" there has to be a greater difference in the outdoor and indoor temps and/or humidity. If the humidity is high and the temp cool < 80'f The "cool" wont feel cool because there is not much evaporation taking place.
Now if the temp goes to 90 or the humidity goes down under say 40% the cooling effect "feeling cool" will change and be more like its cooling. Part because of the difference in the temperature but also because the air can hold more humidity and it is pulling moisture off your skin.
When you talk about "feel" it is rather suggestive and always different for different people.
Aug 04, 2008 | Mastercool 67680 Evaporative Cooler Air...
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
