Question about Carrier 38CKC036 Air Conditioner
Wiring diagram needed for carrier air con unit
Wiring diagram needed for carrier air con heating and cooling roof unit with the drawing No 315153-401 rev A Help please
  • mopar440man May 28, 2010
    What is the model and serial number
    Scholar:
  • 66 Answers
Here ya go:
http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/38ckc-c2w.pdf
Posted on Jun 30, 2010
Can a pro recommend a comperable replacement wall AC only-no heat?
Most air conditioners now are reverse cycle, which means that they can heat as well as cool. Cooling only units were popular many years ago due to the price difference for a reverse cycle. Today, the cost of manufacturing has dropped and it has resulted in cooling only units being virtually finished. I would suggest you get a local air con sales company to come to your house to measure up properly and determine what would be best. There are a lot of factors in installing air conditioning. IE/ The size of the house, the area it will be required to heat / cool, the amount of windows, types of walls, roof etc (Heat loading on the house) Roof and wall insulation etc etc.
Apr 09, 2014 | Heating & Cooling
We have a carriers air con that is about 4 yrs old it has a remote control and digital readings on the unit it is in the wall we can not get it to heat but it does cool we didnt put this in it was here...
Normally all air-cons carry an identifying label on the compressor unit. It has to by law state the gas used. On a split system this would normally be on the outside unit. Sometimes an additional label will be on one of the ends of the inside unit. Some units only do cooling - you need to check once you've found information. Check your remote control 'Mode' setting is correct - it should show a small 'sun' to indicate heating. A small 'icicle' looks similar, but means cooling. Then check temp setting is high enough to cause heating.
Jun 12, 2011 | Carrier Heating & Cooling
Schematic diagram of central air conditioning
Several types out there. 99% of them use the same basic wiring.
Red is power from transformer to t'stat. Sometime there is a wire for common from transformer to t'stat too, but not always.
While is for heat. Green is for fan. Yellow is for cooling.
These 4 to 5 wires go on the terminals that are maked with letters: C=common, RH/RC is for power, W=heat, Y=cooling, G=fan.
In most cases, 2 wires from the indoor unit will go to the outdoor unit to power it for cooling. Usually connected to the yellow wired, Y terminal and common or grounded to the unit if the transformer is done in the same fashion.
If you have a heat pump, totally different animal and different wiring too.
Hope this helps you. Good Luck.
Dec 19, 2009 | Carrier Heating & Cooling
Need wire diagram for 3207-121189
http://www.corp.carrier.com/www/v/index.jsp?vgnextoid=9d087afdef677010VgnVCM100000cb890b80RCRD
Search this web site. It has lots of manuals. It is Carrier site.
Hope this helps. Wiring diagrams are hard to find but I know they are there if you input enough of the right info.
Hope this helps and be patient while you search.
Nov 20, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Run(heat) for a certain minutes then it stop.
You may have a durty evaporator coil do to a durty filter, the heat is cuting off by the limit control sensor
Feb 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
My carrier air con unit is a problem
There is a low voltage wiring problem. Make sure your t-stat wire is in the correct positions and that you have not removed the jumper wire at the t-stat. There should only be 2 control wires leaving the airhandler and going to the condenser unit outside. Unless it is a heatpump. One wire goes to common and the other goes to the Y terminal. W terminal is for heat. The unit will cut off if you have the unit calling for heat and cool at the same time.
Jan 05, 2009 | Carrier 38CKC042 Air Conditioner
My carrier air con is only blowing cold air and i need the hot
It sound like the heating sequecer maybe have gone bad on the fan coil unit that you have. You need to call the maintenance personnel that does the work where you live or a service company out to repair the unit because since y0u only rent it is their responsibility to provide youp with heat and if by chance that you have a heat pumo unit then you definately want them to get on the roof to fix the problem. Remember to always change oyur filter inside when ever you get your electric bill because even though it's theeir unit it's your electric!
Carrier ac unit
This appears to be a Roof Top packaged unit. You will definitely need some help with this install. Your local Carrier distributer should have the installation curb kits and economizer etc.
Here is the most technical data I can find for this unit. Under the 50TFF section you will see the accessory dimensions. I hope this helps. (You will need adobe acrobat to read the file)
Jun 14, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Dometic roof top air-con trouble
1.check wiring of unit.
2.check drain tray.
3.check u band of drain pipe.
Feb 16, 2008 | Dometic Rooftop RV Air Conditioner
Carrier 38CKC036 Air Conditioner Logo
1,016 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
