Question about Philips Magnavox 27MS343S 27" TV
I have a philips tv an the power cord on the back has been cut. how can a replac the cord? Or is it fixable?
  • 94 Answers
Go to a local tech and he will be able to fix it for ya.
Posted on May 28, 2010
Puppy chewed the cord. It is an internal cord and does not plug into the back of the tv. Can I replace it myself? Directions or diagram? Where is the best place to get the replacement cord?
Any polarized power cord will work----cautions: the cord where it connects inside will have either a white stripe on one side or a rough surface---that is the neutral side---replacement must be soldered to correct points---you get it backwards and set will work but shock hazard will exist-------if you have enough cord left you can do a splice repair-----I cut them back and offset so not next to each other(the two sides of the cord----get some heat shrink tubing--slide it over each side and down a ways---solder the two ends for each side back together (you will lose a little of the cord) and once soldered slide the shrink tubing down over the soldered parts and heat it with a hair dryer and it will shrink air tight over the solder connection's---you do not want the splices side by side to prevent any possible short----for extra protection once done use some black electrical tape and tape the whole area.
Either replace entire cord or splice repair it. Examine cord end to end for any bare wire showing---if chewed in more than one spot replace entire cord.
Nov 08, 2012 | Philips 32PFL3505D 32 in LCD TV
My son cut the power cord to the tv, how do I replace the cord? can I replace the whole cord from the back of the TV?
That cord in this model is usually a plug in--inside the set it either goes to a plug or is soldered in place.
Depending on how short it was cut it can be repaired--notice that here the cord has two sides---one will be smooth and the other has a white stripe or is rough----if spliced the splices must match the ones on what is left of the cord-----cord is polarized and should not be plugged in unless matched to set.
A fairly easy repair if done right--most people or any outside repair person can easily do this.
May 04, 2012 | Philips 60PP9202 60" Rear Projection...
I have a Phillips 46WB2K3RA tv and the power cord got cut accidentally while moving it. I spliced it and put it back together and now can't get the tv to come on, any suggestions as this is the only...
On the cors itself one side has either a white line or is ribbed. Just match up the correct lines and splice it back together. If you have them reversed, polarity is backwards and TV won't operate. If that doesn't solve your problem it's more than likely the fuse inside the TV where the cord enters the back.
Sep 04, 2011 | Philips Televison & Video
Where do you insert a/c cord.
Back of the tv,the back of the tv should have a three prongs steels rods stick out in a hole for u to enter the a/c power cord.Or a two holes for a power a/c cord to plug into it.Both of these design a/c's sockets power a/c cord to insert in the holes both of these a/c holes inputs should have a word A/C written wright beside it holes.
Jul 12, 2011 | Philips 20MF251W 20 in. LCD Television
Help philips 50pf9630a/37 no power remote or switch will not do anything but there is power getting from wall ( cord tested with voltmeter )is there reset or fuses and where are they located any help...
If you open the cover at the back of your tv you will see the ac input then you can see the fuse their, if made of glass you will see the filament, if cut and no burn mark just try to replace it,but if the whole glass is burned and cant see the filament of the fuse your regulator is shorted replace it.
Oct 23, 2010 | Philips 50PF9630A 50 in. Plasma Television
When i turn the power on the tv clicks for up to ten min before the picture comes on. is this fixable?
Yes,very fixables.Ur tv power suppply board have these parts call capacitors.They are dead and gases leakages,not total,but dying.These capacitors they alway bulges up on it top,puff up on it top,these capacitors are dying,that why tv still have power but it take up to ten min. clicking to recieve power to the rest of the tv.The power supply board,that the board where the power a/c cord plug into it.U have basic understanding of electronic's?U have tools,soldering iron,desoldering pump,solders?Take the tv aparts.U just looking,searches all around the power supply board and replaced these dead,dying capacitors that are bulges,puff up on it tops.Replaced these gases leakages capacitors,ur tv will have it power back to normal and work on the first click.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 04, 2010 | Samsung LA40A450 40 in. LCD TV
Instruction to replace fuse philips 32mt3305/17 quit working after house power surge wont turn on
The internal main A/C fuse is usually located within close proximity to the power cord entry point on the main PCB. So remove the back cover and follow the cord to something that looks like this.
Nov 06, 2009 | Philips 32MT3305 TV
No sond no picture philips
check power in outlet , check power cords if is not cut ( check with ohmmeter), check fuse
Sep 14, 2009 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
