I have a Sony KP-46c36 projection tv and I replaced the convergence IC's. I need to know how to adjust the convergence manually without the remote.
  • Steve Yelmene
    Steve Yelmene May 28, 2010
  • Steve Yelmene
    Thanks for the help
  • 10,515 Answers
I am Sorry to inform you that there is No Way to adjust the Convergence Manually without the remote.
I wish i could have a better solution.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 28, 2010
  • 19,396 Answers
Hi.
Here the service manual for the 41'', chassis corresponding to same series- service adjustment procedures should be the same:
SERVICE MANUAL
Posted on May 27, 2010
  • Ginko
    Ginko May 27, 2010
    Here also the manual for RA2A chassis. Unfortunately your model is RA2 and I do not have the manual. Procedures for RA2A are definitively the same.
    If the procedure does not fix convergence, that means that you need to replace the convergence ICs located on the D board.
  • Steve Yelmene
    Steve Yelmene May 27, 2010
    So, There is no way to adjust it from the front panel buttons?
Need part # KP-53XBR45, convergance IC
The convergence ICs are STK392-010, the locations are IC1601 and IC1602.
Apr 18, 2010 | Sony KP-53XBR45 53" Rear Projection...
How Do I Manually Adjust The Convergence On My Sony TV Without The Remote
Hi! with regards to your inquiry if it is possible for you to adjust the convergence of sony without the remote,. i think it is not possible.
Nov 05, 2009 | Sony KP-53HS30 53" Rear Projection...
There are red, blue and green lines going all the way across
it sounds like a convergence problem; in the customer menu there is an option to adjust it with the Sony remote---if either blue or red will not adjust in some direction---you have a bad IC---this set uses two STK-392-560 IC chips for convergence---both would need to be replaced and the set adjusted again. If this has been helpful give me a vote here---if you need more direct assistance--------- etower.766@netzero.net
The convergence IC chips are available on Ebay from Surburban Electronics for less then 14 dollars for the pair.(plus shipping)
Aug 15, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony tv
if you go into the convergence mode in the customer menu does the red convergence adjust? if it does not you have a bad convergence Ic--set uses two of them, have both replaced and set adjusted and you will be back in business---if this is helpful give me a vote; if you need more direct help-----------: etower.766@netzero.net
Aug 11, 2009 | Sony KP-43HT20 43" Rear Projection...
Sony rear projection kp-51ws510. color alignment
sounds like bad convergence IC---not uncommon on this set-both convergence IC"s need to be replaced and the set adjusted
Aug 07, 2009 | Televison & Video
How do I perform a convergence adjustment on a Sony kp48s70 rear projection tv?
Hi, you picked a real difficult set to do, you`ll need the service manual,the original SONY remote, you may need to change out the ic`s and a few support parts, ie; resistors & chemical fuses which you can get at acme enterprises in orlando, be sure to read the entire convergence section of the service manual before you change any settings, my advice is to pass but gl if you go for it, video-tek
Jun 06, 2009 | Sony KP-48S70 48" Rear Projection...
The blu display on my sony 65" tv is arched, making the convergence adjustment in-effective.
its failure of Convergence Out IC chip and requires replacement.
TV has 2 IC chip in convergence circuit and I would recommend to replace both at same time.
Let me know exact model of Sony 65" TV to provide you more technical info.
Mar 14, 2009 | Sony KP-51WS510 51" Rear Projection...
Convergence IC`S
Let me know do you have related service manual of Sony KP-57WS500 to guide you further?
Without service manual it would be difficult for you to understand our directions like what to check and where to go in TV etc.
Sep 30, 2008 | Sony KP-57WS500 57" Rear Projection...
Convergence problem
you will need to replace the stk ic's they are mounted to 2 large heat sinks in side the tv. the ic numbers are on the chips themselves. i do believe it is stk392-510 for sony. once you have the number you can buy these anywhere online. just put new ones in and should be good to go. if this doesnt work then there are a few resistors and fuses by the ic's that sometimes fail.
Oct 11, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
