Question about Bosch 24 in. SHU43 Built-in Dishwasher
I have a Thermador dishwasher that won't drain after it runs. I
I have cleaned the filters on the bottom. Is it the pump?
    Brigadier General:
  • 3,513 Answers
Yes you are correct . You also need to clean the pump .
Thanks
Posted on Jun 01, 2010
Dishwasher won't drain all the way
A dishwasher will never drain all the way. It is designed to hold water as to not let the pump run dry and keeps the seals preserved.
Jun 03, 2017 | GE Nautilus 24" Built-in Dishwasher
My dishwasher won't drain properly. The pump has been making a weird sound for a month or so and last night it couldn't drain. It starting beeping and the pump was running. I cleaned the drain filter
If the pump is running but noisy then that indicates a loose pump impeller (new pump I am afraid) if running (no noise) but failing to remove water, then I would be checking that drain hose is clear, or even that your machine is not syphoning water from waste disposal, a quick check would be to disconnect waste hose from waste disposal and see if it will then drain into a bucket, hope this is helpful.
Feb 18, 2013 | Dishwashers
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
Dishwasher won't drain.Leaves several inches of water in bottom of unit after cycle is complete
Check for blockages in the base of the dishwasher under filter etc.
Also make sure the kitchen drain is clear and if you have garbage disposer run it prior to running the dishwasher.
Also need to confirm if the dishwasher pump is actually operating during the drain cycle. If the pump is faulty then it will not drain. Provide full model number of dishwasher if you need further assessment of the problem. Good luck.
Aug 30, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Hello, LG LD 14AT1 dishwasher, starts cycle runs 3 minutes, starts stops on off no water in bottom. Then displays OE chimes! Checked tap under sink water there, checked filter inside bottom, turned off for...
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
The dishwasher won't drain completely. Water is left standing in the bottom of the tub.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 02, 2011 | Dishwashers
Water left in bottom after running dishwasher
Hi
Daniel
Aug 01, 2011 | Whirlpool Dishwashers
The dishwasher is not draining and won' t go into a program.
Hello
Please check the drain pump filter and try to clean the drain hose, pump filter for any clogs/blockages. After this also check drain pump operation, if after cleaning the problem is not solved then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Nov 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
78 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
