Question about RCA Scenium D40W20 40" Rear Projection HDTV
Colors over lapping lll
Was working fine , next morning picture was showing all three color lines and text apeared curved
We have the same problem with this model of rca. What is a IC and where do I get one?
Posted on Aug 07, 2010
  • 94 Answers
Convergence is off, convergence ICs need to be replaced
Posted on May 28, 2010
No picture just 3 curve color lines
do the lines apear all the time? can you make the menu apear.where do the lines apear
Sep 21, 2010 | RCA R61WH76 61" HDTV
Hi, I just aquired an HP 4600n color laser printer, it is used but it works good for text but when printing pictures it prints a really bad quality mainly due to a buch of (mostly yellow)lines running the...
First. Examine the toner cartridges by inspecting the surface of the drum of each color cartridge. Score marks? Replace toner cartridge(s).
Next. for vertical lines from top to bottom, you will want to inspect the fuser real quick to see if the Hot roller is scored or worn or discolored or any adhesives are adhered to roller. Should be perfectly smooth and uniform in color.
Next, do the consumables life page which is in a menu function.
Information --> Supplies Status Page.
This will tell you the life remaining of the image transfer kit (C9724A) as well as fuser unit. These indicators will help you decide if the consumables are the first cause of the print quality issues you are observing.
Feb 12, 2010 | HP Color LaserJet 4600n Printer
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
When I boot up the screen is all colors and lines
It sounds to me like your cable is loose to the lcd or the video card is not properly 100 percent seeded into the mother board. Prolly the cable in one way or the other, perhaps bad cable.
Nov 21, 2008 | Toshiba Satellite A215-S7422 Notebook
Picture problems
OK to help assist everyone having the BLUE HUE and CURVED LINES Issue on their Rear Projection HDTV no matter their model. Here are the steps to take. The first thing to check is the FOCUS BLOCK or G2 Focus Transformer or CRX F-Pack. I have replaced mine, however it didn't resolve the issue. I am onto the next item the CRT Board for Blue (Which is the board under one of the three color lamps inside your tv) Please see photo below (if photo is not large enough below go to link to review notes as well) If the CRT Board is not it, then the next step will be the Signal Board which is a larger board in the back. In a week I will have a picture of both.
INSTRUCTIONS:
  1. Remove the outside cover
  2. Remove the wood plank/panel
  3. In the front is the G2 Focus Block/Transformer, while set is on turn the top 3 knobs till the screen goes black/dark grey.
  4. adjusting the colors till you receive the desired or normal color/picture.
  5. Once you have received the proper color/picture tap the side of the Focus Block.
  6. IF The colors go out of wack again and the blue comes back strong then this "CAN BE" the Focus Block.
Replace the G2 Focus Block aka Focus Transformer, if Hitachi it's called a CRX F-Pack. This item will cost about $50. Not expensive. You will likely need a soldiering iron. DO TURN OFF & UNPLUG THE TV WHEN INSERTING ANY METAL OBJECTS INTO THE TV!!
FOLLOW THE PHOTOS/DIAGRAM in link below for assistance in the above instructions. I will post my next process since it was not my Focus Block that was an issue.
ONE SOLID PHOTO Go to URL CLICK HERE, click on that image to enlarge. Hope this helps you all out!
Mar 30, 2008 | Sony KP-57WV700 57" Rear Projection HDTV
Dlp vertical lines
the person you talked to at samsung is more than likely a customer support rep that does know anything but what his computer tells him. i have seen this symptom several times in many makes and models. if you can give me your full model number i will give you a part number to fix this issue.
Oct 24, 2007 | Samsung HLN5065W 50" Rear Projection...
Lost the picture
RESOLDER CIRCUIT BOARD LOOK FOR CRACK SOLDERING AT TRANSISTORS FOR CONVERGENCES
Oct 22, 2007 | RCA P56812BL 56" Rear Projection...
Color print lines
try to replace with colour catridge bye
Sep 24, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
RCA Scenium D40W20 40" Rear Projection HDTV Logo
107 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
