Question about Fantom G-Force MegaDisk 1.0TB 7200RPM USB 2.0 16mb cache (MDU1000) Hard Drive
Formatting a Fantom G-Force drive from NTFS to FAT 32
MY PC OS is XP Pro and uses the FAT 32 format for the internal hard drive. I just purchased a Fantom1TB G- Force external hard drive to back up my computer. Due to a print error it was suposed to use the FAT 32 format stated in the manual but it is actually a NTFS formatted drive. I do not want to reformat my FAT 32 internal drive but wish to reformatte the external Fantom NTFS drive to FAT 32.
I am not a geek so I want know if this is possible and will XP Pro do this for me without a lot of problems. I have until June 2, 2010 to return it for refund. Thanks.
Andrew
    Master:
    Sergeant:
  • 383 Answers
My computer> right click on the terabyte> select format> make sure u change the option of ntfs to fat 32
Posted on May 27, 2010
How do i convert FAT 32 to NTFS without formatting / Loosing Files in my Hard Disk Drive?
1) Backup your data!
2) XP or later: Open CMD (DOS Window) "Convert" [Drive:] /fs:ntfs
To verify you have the command available, in Cmd window, type "convert /?" that should bring up the various parameters to use with the command. If convert is not available, it will return "unrecognized command".
Apr 03, 2015 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
Kingston Data Traveler 2.0 64 GB USB - file system corrupted - need to work on windows XP- Upon formatting the pen drive It shows that it has become a raw drive - wat is the file format for the USB to work...
Theoretically, you can't format a more than 32 GB drive with FAT/FAT32 file system. In your case you have to choose the NTFS file system to format your 64 GB USB flash drive. However, if you really need to format it with FAT32, you got to use the command line or a third party tool. Hope this is going to help you.
Apr 06, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Hi, I have an iomega Prestige 2tb desktop hard drive which i was using on a PC but now want to use it for my macbook pro. How do i reformat the hard drive for Mac? Thankyou
Connect it to your Mac and open Disk Utility. Find the disk in the left pane of the Disk Utility window, click on it, then click the Erase tab in the right pane. Choose your format, then click the Erase button. If the disk does not appear in the left pane or is grayed out, click the Erase or Partition tab first, then select the disk.
Note: the "MS-DOS" format is the FAT-32 filing system. You will have to partition the volume (Partition tab) to use it since FAT-32 cannot cover the entire drive in one partition (I think it is limited to 80 GB). Microsoft won't let Apple use an NTFS volume for Write operations, but FAT-32 can be read and written by both Mac and Windows systems. If you think you may want to use the drive to share files with the PC, make two partitions - one formatted as Mac OS Extended (Journaled) and a smaller one formatted as FAT-32.
Jan 06, 2011 | Iomega 2TB Prestige External Hard Drive
I think I did a few things wrong while formatting...I have a Mac but the person using the hard drive has a PC. First, I formatted it for FAT, then I tried to partition it for Mac OS (journaled) and FAT....
Connect it to a PC, and use "Disk Management" on the PC to delete all the partitions:
Click Start
Right-click My Computer
Click Manage
Expand "Storage"
Click "Disk Management (local)"
Click to select the partition.
Right-click and choose Delete.
Nov 17, 2010 | Fantom G-Force MegaDisk 1.0TB 7200RPM USB...
Iomega fat 32 formatter program does not allow me
If you really must have fat 32 (maybe for MAC use ?) then windows itself does not support doing a fat format on large drives.
However there is a fix Yup thats why they call it FIXYA
Here is a link to just what you need
Hope its what you need and good luck
Nov 20, 2009 | Iomega 250GB Ego Portable HD Red 250 GB...
No drives found
Tour full installation guide
http://www.windowsreinstall.com/
This will help you to get you hdd and windows running.
Aug 11, 2008 | Toshiba MK1637GSX 160 GB IDE Hard Drive
Formatting Memory Card
You must format your mmc's as FAT.............not FAT32 or NTFS
May 23, 2008 | Nokia 6233 Cellular Phone
Fantom Drive problem
Try connecting it to a Windows XP Pro pc. Right click on "My Computer", left click on "Manage". Once the new management console opens, left click on "Disk Management". If the USB drive is recognized by the pc, you will be able to right click on it, and select "Delete Partition". WARNING: YOU ARE DELETING EVERYTHING ON THE DRIVE! Once it's done, right click on the drive again, and select "Create New Partition". Proceed thru the wizard that pops up, and format it. You will have a choice of using FAT32, but, if the partition is larger than 32 GB, it will fail (it's a Windoze limitation), so NTFS is your only choice, unless you use a 3rd party utility, Win98 (supports huge FAT32 partitions, 4 TB, I think), or Linux.(preferred). Good Luck, hopefully everything will work out fine. T-Power
Apr 01, 2008 | Fantom Titanium Hard Drive
One Touch 4 Maxstor 750 external hard drive installing on a macbook pro
If you have a hard-drive that is formatted as NTFS which stands for (New Technology File Ssytem), Mac OS X can only read the partition. It cannot write to it.
The trick is to use your drive manfacturer's disk-formatting software which will allow you to format your drive as one large partition. Formatting your drive as one large FAT 32 partition is the easiest way to make a drive so it can be used with both PC's and Mac's.
Another option is to use a third part utility so that you can read a MAC formated harddrive's from your PC. Here is one option: http://www.macdrive.com/.
Good luck.
SeekPCRepair
Feb 08, 2008 | Computers & Internet
PC halts while formatting hard drive
make sure your hard disk is error free Try formating the disk with FAT first ,if it doesn't work out the try disk utilities .
Nov 29, 2007 | Microsoft Windows XP Professional for PC
Fantom G-Force MegaDisk 1.0TB 7200RPM USB 2.0 16mb cache (MDU1000) Hard Drive Logo
624 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
