Question about Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM PUMP BY
Motor removal on a Jacuzzi magnum force pump.
I removed the mounting nut rachet inorder to remove the motor to replace the "O" rings. The motor is locked into the pump housing, what is holding the motor from being removed?
    Scholar:
  • 54 Answers
The impeller is threaded onto the end of the motor shaft and the housing (pump body) is attached to the motor with the same bolts that hold the rear cover on the motor they run all the way through on most pumps.
Posted on May 27, 2010
Remove pool pump motor jacuzzi magnum force
It may be easier to disconnect the power, depending on access. You can also remove the impeller, seal plate and mounting bracket. Which ever way is easier.
Nov 28, 2013 | Pool & Spa
I have the 7-184948-22 1 hp Got home to day (very hot ) motor was triped off. Reset and now it just hums, locked up. Any hope? It's about 3 years old
Turn off the power at the breaker, then reach in to the impeller and see if it will turn freely. If it does you probably only need to replace the capacitor. If it will not turn freely you'll have to remove the motor end by unscrewing the large ring that holds the motor to the wet end. Remove the small screws that hold the diffuser cover and inspect the impeller and impeller ring, sometimes known as an impeller weir or floating eye seal.
Even if you have to replace the motor this pump is worth saving if there is no damage to other components. Note: Replacement motors are easy to find, I favor Magnatek / A. O. Smith motors but any brand such as Emerson or other will do. Jacuzzi parts though are getting increasingly hard to come about.
Jul 21, 2011 | Jacuzzi Magnum Force Series Pool Pump 1...
Change pump seal
Frank,
I could not find a manual to refer you to as jacuzzi is very proprietary with their products, they want you to pay their techs for help. I will do my best to walk you through it using the parts diagram here: http://www.poolinspections.com/manuals/pumps/jacuzzi_magnum.pdf
Disconnect power
remove pump mounting nut
seperate motor from pump
remove the diffuser which is on top of the imeller
now remove the end cap at the rear of the motor (should be 2 1/4" hex screws)
this should expose the back end of the motor shaft.
find an open ended wrench to secure the end of the motor shaft we just exposed (typically is a 7/16" wrench)
*if this unit has a center screw securing the impeller to the other end of the shaft, unscrew this by turning CLOCKWISE (this would be a reverse thread screw)
next while locking onto the end of the motor shaft with the open ended wrench, spin the impeller counter clockwise until removed. This is where you will find the shaft seal. pay attention to how it is installed.
remove shaft seal
install new shaft seal
reassemble.
Note: it is highly recommended to secure new orings while replacing this seal (unless its new)
if you attempt this and one of the o-rings has deteriorated, it will not fit back together properly.
If you need any more help or advise, please contact me @:
adamh@newconceptchem.com
If this post helped you, please take the time to vote positively for me after reading this.
Thanks,
ADAM
Oct 28, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I have a Jacuzzi Magnum Force pool pump. 3/4 hp. Have a replacement motor. I have the motor out of the pump. How do I get the impellar off of the motor?
The other end of the shaft has a place to attach a 7/16 or 1/2" wrench. also, there might be a "Reverse Thread" screw in the center of the impeller that you must remove first.
Sep 26, 2010 | Jacuzzi Pool & Spa
How do you get the pump out of the housing on a jucuzzi magnum force pump
If yours is the model with the big round ring around motor, it is a large retaining nut. Remove this nut and the motor should come from the pump housing. Don't be too rough, plastic breaks.
Jun 27, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
We are having issues getting the impeller apart on the jacuzzi magnum force pool pump and need some instructions on how to proceed.
I believe the jacuzzi pump impeller has a locking screw directly in the middle of the impeller. You'll have to turn it clockwise to remove it. Then you'll need to remove the cover from the back of the motor using a 1/4" nut driver. Depending on the motor, you should be able to use a 7/16" open end wrench to hold the motor shaft from turning as you turn the impeller counter-clockwise to remove it. Some motors are different, some have a keyed shaft or require a special tool to hold the shaft while the impeller is removed. Hope this helps.
Nov 22, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi Magnum 1000 - overheating & looking for manual
Loosen the motor and impeller from the pump by backing off the large plastic nut and take that whole section to an electric motor repair shop for inspection. If the motor is salvagable, they can quote the repair or replacement.
Jul 05, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Getting to impellre
the impeller is what is holding it in on the end of motor is the impellel the impeller is in a houseing right off motor that is held togethere by screws you should disconect power then power for motor then remove water in/outtake there may be some kind of strap holding it down
Feb 25, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM PUMP BY Logo
559 people viewed this question
Top Jacuzzi Garden Experts
john h
Jay Finke
Jay Finke
Ian Kime
Ian Kime
Are you a Jacuzzi Garden Expert? Answer questions, earn points and help others
