Question about Asko D1716 Built-in Dishwasher
The power button will not "click" on. When you press it and hold it down the lights come on but as soon as you let it go the power goes off. I assume the button is broken but is it a simple fix that I can do?
    Sergeant:
  • 228 Answers
The detent spring in the button has failed this locks it into open or closed position it will need to be replaced will need to remove console to gain access be sure to isolate power before work.
Posted on May 27, 2010
I have VIBE bluetooth keyboard for iPad mini ( VE 1089) and can't find ON switch
yes the red charge light will only stay lit for just a little bit... then turn it on by pressing down above the words written "charge". You should be pressing and holding down on a dial with three semi circles above it (as szuravic stated). Press and hold down until you get the bluetooth and power button lit on blue. Then go to your settings and bluetooth.... "bluetooth keyboard" should pop up. Click on it and then it will ask you to enter a 4 digit code on your keyboard followed by the return key. Soon after you should be "connected". If you are fully charged (first time plugged in should be 12 hours.. then after 4 hours) then you can unplug. Hope that's helpful!!
Feb 05, 2013 | Apple Ipad I-pad
Tip
Pontiac service light 1983-01
Firebird
1998-01
To reset the "CHANGE OIL" light, press and hold the "TRIP/OIL RESET" button on the instrument panel for 12 seconds. When the light flashes and goes out, the system is reset.
Grand Am
1999 -01
To reset the Change Oil light, open the driver's side instrument fuse panel and turn the ignition on. Press the "RESET" button and release. The light will flash. Press the button again and the system will be reset.
Grand Prix
1999-01
Driver Information Center If Equipped). Turn the ignition to ON without starting the engine. Fully press and release the accelerator pedal three times within five seconds. If the CHANGE OIL SOON indicator flashes two times, the system is resetting. Turn the ignition key to OFF, then start the vehicle. If the CHANGE OIL SOON indicator comes on and stays on, repeat the procedure. To reset the OIL LIFE indictor if equipped with a Trip Computer: Press the trip MODE button until the light appears next to OIL LIFE. Press and hold the trip RESET button until the oil life percentage changes to be 99 percent.
Grand Prix
1997-98
To reset the oil life indicator, press the "MODE" button until the light next to "OIL LIFE" is lit. Press and hold "RESET" for 3 seconds until oil life percentage is 100%.
Grand Prix SE
1997
Turn the ignition on, but do not start the vehicle. Within 5 seconds, push the accelerator to the floor 3 times. Turn the ignition off. Start the car and the Change Oil Soon indicator light will be reset.
Grand Prix
w/ Trip Computer
1988-93
To reset "CHANGE OIL", "CHANGE OIL FILTER", or the mileage of either on the Trip Compute, continually press the "SERVICE" or "SYSTEMS CHECK" button until the item appears with the mileage below it. Then press the "RESET" button and the mileage will be reset to the maximum value. If you want to reduce this value, hold the "RESET" button down and the mileage will count down. Release the button at the mileage you would like to observe.
Bonneville,
6000
w/ Driver Information Center
1983-91
To reset "CHANGE OIL SOON" or "OIL FILTER" or to adjust the mileage on the Driver Information Center, continually press the "DIC" button until either message appears with the mileage below it. At this point, hold down the button. In 5 to 10 seconds, the mileage will count down. When it passes 0, it will cycle back to a maximum figure. Release the button when the mileage gets to the service interval you'd like to observe. If "CHANGE OIL" or "OIL FILTER" already appears, just hold the button down to reset the mileage. "CHANGE OIL" and "OIL FILTER" are reset separately.
on Dec 07, 2009 | Pontiac Grand Prix Cars & Trucks
When I press down and turn the know the pilot lights but as soon as you let up on the knob to turn it there is a click and the pilot light goes out.. This is on my Mr. Heater Big Buddy
When the pilot lights continue holding the button down for a full minute and then release. It should stay lit then to allow you to turn it to the on position. If the pilot will not stay lit after holding it for the full minute, then the thermocouple will need to be replaced.
Hope this helps.
Sep 16, 2011 | Mr. Heater Big Buddy Heater
Trying to synch my remote to the new tvee model 25 sound bar and can't get the orange lights.
I had this same problem and it was due to their instructions which do not adequately explain the setup procedure.
On my own, I was successful in programming volume up but that was all. I assumed that for volume down I would hold the power button and the VOLUME DOWN button and wait for the flashing light just as I had for volume up. Problem is, you never get a flashing light.
Today, I spoke with a rep from Boston Acoustics who patiently explained that step one of the instructions has to be done the same way each time as it is the step that puts the soundbar into programming mode.
It is only at step 2 that things change.
The solution is to hold the power button and the Volume Up button every time in order to get the system into programming mode. Once the light is flashing, in order to program Volume Down, you then hold the Volume Down button until the light goes solid. Once the light goes solid, then press the volume down button on your remote 4 times slowly. Works like a charm.
Works the same way to program the mute button. Follow step one to get the unit in programming mode. Once the light is flashing, hold down only the mute button until the light goes solid. When the light goes solid, press the mute button slowly 4 times.
OBTW, this was programmed with a Logitech Harmony 650 remote unit.
Sep 05, 2011 | Boston Acoustics Audio Players & Recorders
Have a BA TVee 25 Soundbar. Only able to program Volume Up on my remote. Cannot program Volume Down or Mute. Nothing happens except to turn the Soundbar off and on. Don't tell me to follow...
Jul 26, 2011 | Boston Acoustics TVee Model Two TV...
Got the Boston Tvee 25 and was able to program the volume up ok, but not able to program the volume down or mute functions. The process is the same but ive tried 100 times with no luck! Any help?
Jun 05, 2011 | Boston Acoustics TVee Model Two TV...
Ink absorber is full on my Canon MP 160...what do I do?
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Nov 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Epson Stylus Photo 1270. All lights flashing. Whats wrong and how can I fix it?
Hi Guys
I had the same problem with all lights flashing nothing working, happened after a panic power shut down. As with peter after the paper button was released, printer lit up like a christmas tree again. I played around with the button combinations and found that holding down the ink button instead of the flashing paper button cleared the problem. Great tip guys saved me a lot of money. cheers me dears clive.
Mar 02, 2009 | Epson Stylus Photo 1270 InkJet Printer
Is it possible to reset the waste tank on a Canon S9000?
Hi Try this.
Canon S9000
1. Turn off printer
4. Press Resume button twice then let BOTH buttons go.
8. Your printer should then respond as normal.
Good Luck!
Tinteiros (Ebay)
May 30, 2008 | Office Equipment & Supplies
Epson Stylus Ink Jet Printer
1. Turn printer off
2. Press the left 2 buttons down and continue holding them down while turning the power button on. (all 3 are now pressed down)
3. In 3 or 4 seconds, the paper feed (jam) LED light begins to flash. (middle button)
4. Within 3 seconds as the paper feed button LED still flashes, release all 3 buttons together and immediately press down the ink cleaning button (left) and continue to hold down for about 10 - 20 seconds. As soon as the cleaning docking button LED flash, release it. That's it! You are now reset and ready to go.
NOTE: This is a strict timimg procedure and must be done fairly precisely in order for it to work. It may require several attempts for it to work for you. But...it does work! Happy printing!
Oct 12, 2007 | Epson Stylus Color 880i InkJet Printer
Asko D1716 Built-in Dishwasher Logo
90 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
