Question about Brother MFC 7420 All-In-One Laser Printer
How do I access the area to replace the drum unit?
  • 468 Answers
Showing line in printing
Are the lines white (no toner is printing on that area) or black (too much toner is printed on that area)? In the first case, you might have dirt on the developing unit, the best bet is to replace the developer and before cleaning the developing unit. If the second case is you case, you might have a broken drum (scratches on the green drum that you'll see while the right door is open) or the charging unit might be dirty; in these two cases, you should replace the drum unit. The same black lines appears if the fusing roller is scratched, in this case you should replace it. Just drop us an email at office@bizhubreset.com and we'll assist you further.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 18, 2014 | Konica Minolta Copier Toner, DI-3010,...
Keys are under the drum of a model #ATF600FSO; how do I retrieve them?
You will need to try and see if you have a front access panel you can take apart from the unit, underneath the drum and access the pump area and see if you can locate your lost keys.
Jul 21, 2012 | Frigidaire ATF6000ES Front Load Washer
Bra wire stuck between drum and casing, how can I remove?
our is a Bosch nexxt front loader, we removed a heating element. Were able to get access the area of drum unit where the wire was.
Jun 19, 2010 | Electrolux Washing Machines
Error: open upper cover exit jam
Feed Jam or Exit Jam ecblank.gif ecblank.gif dot.gif ecblank.gif 1. Remove the tray and clear any misfed sheets as given above.
2. Open the top cover.
WARNING! The fuser area will be hot. This area is clearly marked. Do not touch it.
CAUTION! Never expose the image drum unit to light for more than 5 minutes. Never expose the image drum unit to direct sunlight. Always hold the image drum unit by the ends or from the top. Never touch the surface of the green drum inside the image drum unit.
3. Carefully lift out the image drum, complete with the toner cartridge. Be careful not to touch or scratch the green drum surface.
4. Remove any jammed sheets from the paper path.
5. Re-install the image drum complete with toner cartridge, ensuring that it correctly locates into the slots on each side of the printer.
6. Close the top cover and press down to latch it closed.
7. The printer will warm up and commence printing when ready. he page lost through the jam will normally be reprinted.
NOTE If the edge of the jammed paper protrudes (or can be seen) from the exit, reinstall the image drum, close the top cover and switch the printer on. Remove the jammed paper from the exit when the exit roller begins rotating after a few seconds after switching on. However, if the jammed paper cannot be removed, contact a service representative.
Mar 12, 2010 | OKI B4350 Laser Printer
I have replaced the waste toner box but still getting error msg
clean all the area of the drum unit (waste toner box side ) . and check it........
if you have anothe same printer inter change the drum unit....... repalce the drum unit ......if not working change the sensor board.......
Nov 05, 2009 | Kyocera Mita FS-3830N Laser Printer
I have a peice of paper jam in the output area of the imagerunner 1670, but the machine dosn't open to allow access to this area. how do i get the paper jam resolved.
Your jam is in the fuser section of the machine. Unfortunately this area this area is not for users to access. You will need to remove covers to get to the fuser unit. You may be able to access the paper by removing the whole drum unit (make sure you remove the toner cartridge first). Then look into the machine to the left. You may see the tail end of the document for removal. Otherwise, you will eed a service manual to dis-assemble it yourself.
IR1600 Service Manual
May 05, 2009 | Canon ImageRUNNER 1670F Copier
DRUM UNIT REPLACEMENT
no screws to take out make sure all the toner levers are locked down so toners cant slide out. kust below the toners is a lever that will open the drum cover when you open this it reveals the drums just slide them out
Jan 30, 2009 | Canon imageRUNNER C3220 Color Copier
POOR COPY QUALITY
Here is the scoop! There are two (2) components to the fax machine, one is the scanner portion which is located just past where the paper you are copying or faxing enters the machine, separate the two sides and access the imaging plate, clean this area with denatured alcohol.
Step two is to clean the toner and drum unit, get the mirror at the back of the toner and under the toner. If after this you are still getting lines on the prints you will have to replace the drum unit KX FA-84 about $85. Happy faxing, Ken
May 15, 2008 | Office Equipment & Supplies
Brother MFC 7420 All-In-One Laser Printer Logo
52 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
