Mitsubishi LT 52249. Brand new. Low audio on all inputs. Have to turn it up past 13 before I start to hear anything. Mits says its probably in the main board. Is there a setting in tech menu or in main? I've tried sound level. No change.
  • 5,138 Answers
Replace the Main board the board that has your AV/Tuner on it.
Call Encompass Parts Distribution 1-800-638-3328 or look for one on Ebay under Electronics
Posted on May 27, 2010
Where is fuse location?
Can be located at the SMPS [Power Regulator] board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 11, 2015 | Mitsubishi LT-52249 LCD TV
Mitsubishi LT-52249 continuous blinking green light wont pwer on/off
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. Electro help
Jan 07, 2014 | Mitsubishi LT-52249 LCD TV
Is no audio a propblem that is repairable?
Hi hve you checked your setting on your tv. Check to make sure your speakers were not turn off. Try doing a system reset. IF that 's not the problem you might hae a problem with your sysnal board was there a storm or a power failure that might have caused the problem. Hope this helps.
You can get parts at www.interliquidparts.com
Dec 02, 2011 | Mitsubishi LT-52249 LCD TV
No audio in my Mitsubushi LT-52249...
Your signal board is proably bad and will need replacing.
My Mitsubishi LT-52249 television's audio and video become unsychronized after a period of several hours. I have to unplug the set to resynchronize. Any thoughts on what would cause this?
I have seen issues like this on other manufactures sets needing a software up grade. Mitsubishi deals one on one with customers with software upgrades and will usually send out a SD card with the upgrade on it. This is their customer service number. 1800-332-2119
I hope this helps,
Skyassoc
Dec 10, 2010 | Mitsubishi LT-52249 LCD TV
My receiver will randomly lose audio output. If I
Sounds like a loose connection. What audio source are you using? If you switch sources, does the other source have the same problem?
Mar 04, 2010 | Mitsubishi M-VR700
I have a mits wd-52525 i got it from my neighbor, he said it needs a new screen,but the outside looks fine, i hear glass when i move it, someone said the mirrors are broke.could there be anything else, and...
the mirror is a single unit and can be purchased from mitsubishi however you will probably have some scratches in the optics eye and this will show in your picture
Jan 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Vertical lines on my 40 inch lcd mitsubishi hdtv 1080
Similar problem with an eleven and a half month old LT-40148. Approx. 1 inch vertical banding line on left side of screen on all inputs. After about two weeks, same problem on the right side of the screen.
Fortunately this occurred two weeks prior to the one year warranty expiring.
Called Mits customer service and they referred me to an authorized service center who I happened to have dealt with before.
They picked up the set. The front panel (LCD screen ) had to be replaced. Set was gone for two weeks as parts were not in stock. There was no charge. I hope this screen last more than a year.
Jan 16, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
