Question about LG LFX25960 Bottom Freezer French Door Refrigerator
Need help w LG refrigerator..temp control not working. Was told it is computer chip Can you advise?
  • LG Master
  • 3,051 Answers
Hello there:
There are a couple of reasons why this controle may be not working (or it may be working but not properly)
I will post this solution in 2 seperate posts so you can troublehoot this in detail ok before going right to the chip and associated parts
It's not cool If the refrigerator isn't cool, you need to answer some questions,
Is the thermostat knob turned to the proper setting? If not,unplug the refrigerator for 30 min then plug it back in than reset it. first at the highest setting than slowly turn it counterclock wise to see if it clicks if not the temperature control device itself may be bad and not the chip itself.
the chip rarly fails
Next, see if the compressor motor is running Cooling is poor
Posted on May 27, 2010
  • Michael Thomas
    Michael Thomas May 27, 2010
    Evaporator coils
    Poor cooling is often the result of a heavy frost
    build-up on the evaporator coils. You can't see these coils without
    removing a panel on the inside of your freezer. A sure sign that there
    is a build-up is the presence of any frost or ice build-up on the inside
    walls, floor, or ceiling of the freezer. Such a frost build-up usually
    indicates a problem in the self-defrosting system or damaged door
    gaskets.
    The refrigerator is supposed to self-defrost
    approximately four times in every 24 hour period. If one of the
    components in the self-defrosting system fails, the refrigerator
    continues to try to cool. Eventually, though, so much frost builds up on
    the evaporator coils that the circulating fan can't draw air over the
    coils. There may still be a small amount of cooling because the coils
    are icy, but with no air flow over the coils, cooling in the
    refrigerator compartment is quite limited.
    Here's an inexpensive, though inconvenient, way to
    determine if the problem is with the self-defrosting system. Remove all
    of the perishable food from the refrigerator and freezer, turn the
    thermostat in the refrigerator to Off, and leave the doors open for 24
    to 48 hours. (Be sure to have several towels ready in case the melting
    frost and ice causes the drip pan to overflow). This allows the
    refrigerator to defrost "manually." When the frost and ice build-up has
    completely melted away, turn the thermostat back to a normal setting. If
    the refrigerator then cools properly, it indicates a problem with one
    of three components in the self-defrosting system:
    The defrost timer
    The defrost thermostat (also called the bi-metal
    switch)
    T
How to set freezer on LG Bottom Freezer LRFD22850
Hello Fran Miller,
For OPENERS... (my opinion)
always start by setting you temperatures at mid range.
Owners manual... Page 16
Setting the controls 16 - 17 Adjusting control settings...
http://www.searspartsdirect.com/partsdirect/user-manuals/LRFD22850ST-LG-Parts-Refrigerator-Parts-manual
I get a little PUSHY about FOOD TEMERATURES...
(stored poorly there's no quicker way of poisoning ones self)...
I strongly recommend getting TAYLOR refrig/freezer
THERMOMETERS (like Amazon... cheap = $6 ea).
Let the refrigerator stabilize EMPTY 24 HOURS
Loaded with food (not recommended: 72 hours).
ADJUSTING CONTROL SETTINGS
Give the refrigerator time to cool down completely before adding food. It is best to wait 24 hours before you put food into the refrigerator. The mid-settings indicated in the previous section should be correct for normal household refrigerator usage. The controls are set correctly when milk or juice is as cold as you like and when ice cream is firm.
THERMOMETERS
Amazon com Taylor Refrigerator Thermometer 20 Deg To 80 Deg 3 1 4 3 3 4...
Hope I am helping
Carnac the Magnificent
Jul 11, 2017 | LG Refrigerators
LG refrigerator with inverter compressor type,model:gl-b552glhl. compressor can't start.l check all temp.sensor,fan it's working and there is small led on control board is flahing,can i have help.
What is the voltage reading at the compressor? Are the fans inside and outside the fridge working? I believe your model is found in Europe correct? Is there a computer board found on the back of your model? Can you provide photos? Contact Me Here
Appliance 911 Sea Breeze
Nov 03, 2015 | LG Refrigerators
Freezer and refrigerator to cold...everything is freezing on fridge side
check for a faulty thermostat that tells the board when to run or not . If it is still under warranty have a service inspection done .
Jun 13, 2013 | Whirlpool Refrigerators
I have the GE GDS20SBSS only 6 years old. I paid about 1200$, and I have been advised to buy a new refrigerator. The freezer works but the refrigerator won't keep cold temp. There is frost in the...
Oh my God that's crazy. You can change this yourself part number WR55X10942
Bi Coastal Appliance Parts 1-800-673-1262 around $150.00 + shipping
Sep 14, 2011 | GE GDS20SBS
Noticed my refrigerator is 50 degrees. I raised the temp control but hasn't helped. I raised the freezer temp and that helps bring up the refrigerator temp. Also the icemaker stopped working. I used ice...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 31, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
The temp control keeps on the refrigerator side keeps changing (
replace the fan motor . as the do fail and thats how they start. mm
Jul 08, 2010 | LG LSC26905TT Side by Side Refrigerator
LG LSC 26905SW control panel for temp, ice,
Replace the control pnl.
There is no way to fix the existing control.
Jan 12, 2010 | LG Refrigerators
LG model LRFC25750WW 25.5 cuft
You may have a problem with the control board and it will need to be replaced.  You will need to have a qualified LG technician to help resolve your issue.
May 11, 2008 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Temperature Control
call the number in your service manual. they'll ask you to sent the receipr, the silver sticker on the back of the fridge, and a piece of the outlet cord so they know it's not in use. they'll ship you a new fridge. WOW!
May 16, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
Touch Temp Controls
If the touch control doesn't respond then it's most likely bad. They don't normally act up, they either work or they don't.
Jan 05, 2007 | LG Bottom Freezer Refrigerator w/ Swing...
LG LFX25960 Bottom Freezer French Door Refrigerator Logo
405 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
