Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
After my Timecutter 1642 z sit for a day or so it will not start. I just had a new starter put in and it started right away so I put it away. 5 days latter I went to start it and the engine will only partially turn over. It either spins a quarter turn and stops like it is stuck or can't overcome the compression or the starter gives a loud click and may or may not give a high pitched whine sound like eeeeeeeee. When I walk away and come back periodically it may or may not start. When I do get it to start it unexpectantly starts turning over normally and I do get it started. Help!
  • 2,841 Answers
If you know the battery is fully charged and good and the battery cables are tight and you have a clean connection then I would suspect the starter is not seated properly or it is defective even if it is new. Check to make sure the starter is fully seated and not cocked slightly or one side is not fully seated and tight. If the battery is over 2 years old, it is very suspect. Check all the electrical connections at the starter and the battery. It has to be either the starter, the battery, or the connections.
Posted on May 27, 2010
  • 3 more comments
  • thjohnston May 30, 2010
    Ray this is not the solution. I have been checking the internet and found that the most probable solution is most likely that I need to do a valve adjustment. The symptoms are identical to mine. I need a thorough discussion on how to do a valve adjustment on a Briggs & Stratton 16HP Model: 286H77 Type: 0265-E1 engine.
    Thanks,
    Todd
    Sorry I ment to address Clay.
  • NOT ME May 30, 2010
    Rather than me try to explain this procedure, I found this excellent video. Hope this solves your problem.
    For some reason the video did not appear. Click this link to see the video.
    http://www.youtube.com/watch?v=hGkn0jR9R...
  • thjohnston May 31, 2010
    Yes thanks Clay I'veseen this.
I have a 96 cadillac deville 4.6 northstar engine. I have changed the starter three times already. Once it was cracked. Third time a new one was put in, it wouldn't start and and there was smoke coming...
You may have ground issue , to much current , high resistance . Do you know how to use a DVOM - digital volt ohm meter ? Do voltage drop testing on the starter electrical circuit . Watch these videos .
Starter Voltage Drop
How to voltage drop test starter motor circuit
Apr 29, 2017 | Cars & Trucks
Not running correctly
not 100% sure if this is a fuel injected bike...if it is...maybe the fuel fillter needs changeing...if its a crab engine....try cleaning the carbs out!!
Mar 31, 2010 | 1997 Suzuki GSX-R 750 V
I have a 2001 saturn sc1 that is having intermittent starting problems. At times after its been driven ill go out to leave again and it won't start. No clicking when I try and start it either. Wait for...
I am having the same problem. did you figure out what was wrong with yours. I have tested all of the wires in the harness under the dash, they r fine. I pulled off the starter and had it tested; O'rilies said it was fine. It is a 5 speed, and I can push start the car just fine any time. Like yours, some days my car starts, some days it doesn't. The days it starts, it runs fine with no problems starting or running. the problem is the days that it wont start.
Feb 25, 2010 | 2001 Saturn S-Series
I have a new battery. i have changed the fuel
I'm guessing you checked the fuses already, so if you have spark at the plugs, look for a vacuum leak. If you still suspect the fuel pump, do a fuel pressure test.
Jan 07, 2010 | 2000 Chevrolet Astro
Starter issues
try tapping on the starter motor/solenoid, it sounds like the solenoind is engaging(the clunk you hear) but the starter is not turning if the wire is getting hot it could be the starter is frozen up.
Jun 19, 2009 | 2004 Harley Davidson FXSTS - FXSTSI...
I suspect a weak battery, but how do I know it's not a bad ALT?
when your car is running disconnect the positive cord from the battery. if the car stays on, than it is your alternator, if not its your battery. also if the car stays on, the head lights go dim if the alternator is malfunctioning
Mar 17, 2009 | 1999 Lexus ES 300
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
120 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
