Question about HP LaserJet 4730mfp All-In-One Printer
No poweraftereplaced the adf scanner in hp color laserjet 4730mfp
Replaced the adf scanner in hp color laserjet 4730mfp and now the whole system doesn't get power
  • 903 Answers
Make sure you reconnected all of the cables when you replaced the scanner. Unplug and reseat the connectors -- maybe one of them is not seated all the way in.
Posted on May 28, 2010
Hp laserjet 4345 mfp cannot photocopy anything because the startup button has a red light
Hi Bridgette.
The red light on the startup-button indicates that the machine is not ready for a photocopy. Usally there is something stuck in automated document feeder (ADF). Take a close look and see if can see something in the paperpath. If no luck, try pushing a A4 sheet manually through the ADF and see if something comes out with the sheet. Usally there is a small piece of paper, a paper clip or a staple stuck in the ADF. If nothing found in the ADF, the Scanner Controller Board is probably broke, and needs to be replaced. Good luck.
Dec 31, 2013 | HP LaserJet 4730mfp All-In-One Printer
Amber light on no scanner error ADF dead but printer works.
the adf might be faulty and needs to be replaced, let a technician assess it onsite.
Nov 12, 2013 | HP LaserJet 4730mfp All-In-One Printer
Amber light on no panel error code ADF stops working.
there a small pieces of paper in the paper path of the ADF by the paper jam sensor.
HP Laserjet M1522NF MFP Scanner adf
Please try to use scanner glass and see the resultSecondly try to scaan to PDF for multiple files.If the issue still persists clean the rollers on the ADF and if not working, replace the ADF
Apr 20, 2012 | HP LaserJet M1522nf Multifunction Printer...
Hp Color Laserjet CM4730 MFP printer. The problem is on the output copy from the ADF showing a line on the edge. But from the glass scanner, the print out is ok
I think that ADF of the printer is causing the issue and requires cleaning. Fortunately, HP Official support has provided the details along with pictures about maintenance/ cleaning of the ADF Unit.
Cleaning the ADF delivery system
Please visit the above link and follow the procedure to perform regular maintenance of the copier.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 24, 2011 | HP LaserJet 2840 Printer
Problem with the HP LaserJet 4730mfp All-In-One Printer Unable to use ADF. Red light under start button.
Do the calibration for the scanner.
1. Place letter- or A4-size paper in tray 1, and adjust the side guides.
2. On the control-panel Home screen, scroll to and touch Administration.
3. Touch Troubleshooting.
4. Touch Calibrate Scanner.
5. Touch Calibrate to print the first pass of the calibration target(Print out).
6. Place the first pass of the calibration target face-down in tray 1 so that the arrows are facing into the MFP.
7. Touch Start to print the second pass.
8. Place the calibration target face-up into the ADF, and adjust the side guides.
9. After the calibration target has passed through the ADF once, reposition it face down in the ADF and touch Start.
10. Place the calibration target face-down on the scanner glass, touch Start, and scan the page.
After this pass, the calibration is complete.
Calibration will fails if print quality is not good...ensure that print quality must be in order..
Once calibration successfully done, restart printer several times & verify start button light, if its green every time 'u' re success. if not cleaning required for CCD which is major work & not suggestable..
Aug 30, 2011 | HP LaserJet 4730mfp All-In-One Printer
When i want to print to hp color 4730mfp but i'm prompted printer is paused and i click to enable it but it keeps on going back to paused mode
Remove and re-insert the cable connected to the touch screen and also try to calibrate the touch screen. The panel can be removed with ease. If not the touch panel needs to be replaced.
DO NOT FORGET TO RATE THE SOLUTION
Jun 27, 2011 | HP LaserJet 4730mfp All-In-One Printer
Examine the full paper path of the ADF. Look underneath as well. Could be something as simple as a staple caught deep inside.
Mar 16, 2010 | HP LaserJet 4730mfp All-In-One Printer
4730mfp
Re: copy/send error....if it is not a scanner issue, do you have a problem with starting up/initializing error.... if so, it may be the hard disk failure - consider replacing it with a 40 or 80gb sata drive - may need to do nothing more complicated than replace the diskdrive which is mounted on the formatter card, which is retrievable out the back. The card is the metal faced plate on which the network/usb plug is mounted.
Oct 18, 2008 | HP LaserJet 4730mfp All-In-One Printer
HP LaserJet 4730mfp All-In-One Printer Logo
143 people viewed this question
Seeker5211
Seeker5211
