Question about Kenmore 15343
Needle will not move..motor runs fine when pedal pushed down, but needle will not go up and down. Not in ''bobbin mode'' and knob is pushed in. (Sorry, still a beginner with all this, so I don't know all the lingo yet). Called various ''experts'' and no ideas on the problem yet. Any help would be appreciated....can't afford a bunch of money to get it repaired.
  • 980 Answers
Check that the belt is tight, make sure you do not have any thread stuck in the machine, take the bobbin case out and the raceway completely to check
Posted on May 29, 2010
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
Needle is not moving
Of course I have to guess here--not seeing the machine, but it appears that your motor is working fine. That would leave two possibilities, I think. The first is a defective foot pedal. The second is, when you push the bobbin winder, it engages a clutch that diverts power from the needle shaft to the winder. It is possible that the clutch is stuck. To find out, disengage the bobbin winder and press the foot pedal, and see if the bobbin winder spindle is still spinning.
Jan 02, 2014 | Singer Inspiration 4206
LED that illuminates the stitch selection bar quit working as did the up/down needle button.
Check your bobbin spindle. If engaged (pushed toward the right) LED will not light. When the clutch knob is pulled out, when you wind a bobbin, the up & down needle will not move. So you must push the clutch knob in again to let the up & down needle go up and down. The clutch knob on my machine is in the large hand wheel upper right side of my machine.
Jul 17, 2011 | Janome 4623 Mechanical Sewing Machine
Power on machine runs but needle does not move up and down on Singer 9802C
Is the clutch disengaged ie is it in bobbin winding mode?
You might have a knob inside the flywheel that needs to be tightened up to renagage the clutch, most mechanical machines operate the bobbin winder mechanisim this way.
Just hold the outside of the flywheel and turn the inside knob away from you to lock it again.
Or there may be a little spool that the bobbin sits on and moves over against a stopper to engage the bobbin winding motor, just check that it is back to the left away from the stopper as this may also stop the needle bar from moving up and down.
Hope this assists, however, this is just the simpliest reason, if you have tried these things already and no joy, then perhaps it has a deeper fault. If so, check the manual for other trouble shooting suggestions, and/or take it to the dealer for a service.
Apr 25, 2011 | Sewing Machines
On my Kenmore sewing machine Model 1756 when I press the pedal the needle does not move. When I turn the hand wheel the needle does not move. any help out there? or is the machine done for
Disengage the sewing mechanism (like you are winding a bobbin)
If the motor runs fine that way then you have a machine that is frozen.
If that is the case take off the top, bottom, needle plate, needle bar and bobbin cover. Spray all moving parts down with Mean Green and let it sit for about an hour. After that blow it out with canned air.
See if there is any improvement. If so you just need to clean out all the old lubricants. Sometimes I take a hair dryer to loosen the sludge up.
Aug 26, 2010 | Kenmore Sewing Machines
Needle is not moving when i step on the pedal...i hear the motor running
Check to see if you bobbin winder was left on by mistake. Just push it to the left and your needle should start moving. Thanks for asking FixYa!
Aug 24, 2010 | Janome L-344 Mechanical Sewing Machine
I have a Singe 3116. The needle not working
the clutch is out. that allows you to wind a bobbin. take it out of bobbin mode and put it in sew mode (clutch in)
Feb 26, 2010 | Singer 3116 Simple
Kenmore 158.1703 sewing machine - needle not going up and down
Sounds like your worm drive gear is striped and needs to de replaced. If you twist the handel on the end of machine does the needle move up and down.
Jan 03, 2010 | Kenmore Sewing Machines
Needle won't move
I had that problem too! I usually turn the tension knob and it works,
Aug 07, 2008 | White Sewing 1632 Mechanical Sewing...
Sewing Machines Logo
81 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
