How to remove for the prop for replacement from a minn kota electric motor
There is a plastic nut that screws onto the prop shaft and needs to be unscrewed. there is also a metal pin that goes through the shaft that needs to be in place and in the right position when you replace the prop. make sure you clear out any fishing line etc that may have collected behind it when you change props.sually recommend you put a little clear silicone grease on the parts as you assemble them as well.ake sure you disconnect the power leads from the battery while your doing this to avoid injury.
