I would like to use an old A/C Condenser fan
I would like to use an old Goodman Condenser fan to blow some air around. It's a 220 volt, (most are), three wire Black, Brown, Purple. Is it required that I draw from two different 110 phases with a common ground? What about 'capacitors'? Can I wire these 3 wires to a simple 220 outlet / circuit? The A/C unit went out and I salvaged the fan however I didn't take note of how it was wired. Motor A.O.Smith 1075 rpm 1.5 amp
Any drawing - details can be sent to ps24244@charter Thanks
    President:
  • 949 Answers
Black and Purple are your power(each have to have a separate phase of 110 volts, The capacitor (typically around 5 microfarad) connects from Brown to Purple
I would like to use an old A/C Condenser fan - 8d60f74.jpg
Posted on May 27, 2010
  • ps24244 May 27, 2010
    Are you saying that the brown then goes to grd with capacitor in line?
    This is a big help - thanks - any recommend on type / brand capacitor?
  • Philip May 27, 2010
    The frame of the motor it the ground on these types of motors.
    DO NOT connect the brown to neutral.
    Brand is not real important on the capacitor in my mind. The rating is the most important thing. Check the tag on the motor close to see if you can find a number follow by MFD or MF or UF, this will be the rating of the capacitor, it is almost always 5 microfarad for this size of motor.
Goodman model F48F97A76 need to know what the
if your condenser fan motor is not bad. change out fan capacitor
Apr 08, 2010 | Heating & Cooling
My AC unit comes on, but the fan doesn't work or blow air
The condenser fan motor has gone bad... this is a very common problem. Find the specs. on the side of the motor and then get a replacement from Goodman or from a company like www.grainger.com
The fan motor is rather easy to replace, the worst part is getting the fan blades off of the shaft of the old motor. Use WD-40 and be patient...
heatman101
Apr 07, 2010 | Goodman CKL24AR24 Air Conditioner
We require condenser fan motors for Interclisa Carrier package (rooftop) air conditioner model AAD 250 (1980's model) model. Air conditioner - supply voltage 380 Volts 50 Hz AC. Condenser fan motor voltage...
Hi, this is an odd voltage 380 volts. Is it a 3 phase unit? To get a 220 volt 50hz condenser fan motor, you will have to go through a refrigeration/air conditioning parts house and order this. 60hz you would have no problem finding one in stock. Carrier is a good unit, and have been around for many years. You shouldn't have any problems locating one.
Sincerely,
Shastalaker7
PS You will need to go through a wholesale parts house.
Jan 21, 2010 | Carrier Heating & Cooling
My goodman airconditioner is not blowing out air even though the fans are rotating
could have the fan running back wards , very dirty condenser, Bad capacitor the in side unit evaporator may be froze up or very dirty is the filter clean? your question is some what vague. good luck Tom
Jul 06, 2009 | Goodman CLQ36AR49 Air Conditioner
Fan does not turn but motor seems to be running fine
Rain should not affect an outdoor unit. It is designed to be outside. The motor that you are hearing... could this just be your compressor running? If the condenser fan is not operational the compressor will run much louder. TURN THE POWER OFF! See if the fan will spin freely if it is pushed. If it doesn't replace the fan motor. If it does you need to check the power at the contactor going to the condenser fan motor. This is 220 volts BE CAREFULL.. If power is going to the motor and the motor is not running... Change the motor and capacitor. If no power is going to it it could be a bad contactor.
Good luck....
Apr 11, 2009 | Goodman CKL24AR24 Air Conditioner
Goodman CKL60-1 Condenser Fan Runs OK, then stops
Bad bearings on the motor or check the fan rotations . Air should always blow out the top and **** in through the sides or coils.!... Thank-you-very-much!
Aug 25, 2008 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
