Question about Indesit W 123 Front Load Washer
Broken Indesit IWDC 6125 Washer/Dryer
In the middle of a cycle today my machine stopped and all the program lights started flashing. The machine is full of water still. I switched it off and left it for a while and when I turned it back on I tried to drain it which didnt work so I turned it off again and when I turned it back on put it on a wash cycle. It started ok but then after about 10 mins it had stopped again and the lights were flashing again. Please help!
  • 15 Answers
SOURCE: Door jammed
take the top off the machine,put your hand down to the reigon of the door lock and by using a small screw driver the catch on the door can be forced open without doing any damage.
Posted on Jul 19, 2007
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Posted on Feb 27, 2008
barkencoa
  • 3463 Answers
SOURCE: Indesit washer dryer 'omega 1200' WDG1295W won't drain!
Sounds like the pump is possibly faulty, or there is a blockage
There should be a removable plastic cover at the bottom front of the m/c, behind this you will see a round plastic cover.
This is the pump filter, unscreit and unblock it if it is full of ****!!!
Hopefully this should solve your problem.
Please leave feedback.
Posted on Dec 02, 2008
SOURCE: Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
Posted on Jan 18, 2010
SOURCE: all lights flash on indesit washing machine soon after switch on
Indesit washing machine lights come on briefly when awitched on at mains and then no power
Posted on Apr 19, 2010
My washer/dryer model iwdc 6125 will not dry clothes properly they come out hot steaming and wet its only a year old
Check the vent hose for lint build up. If it goes into a wall, be sure there is no obstruction. The dryer has a flow sensor that detects a reduction in airflow out the vent hose. It will shut off the heat to prevent a vent fire.
Oct 24, 2016 | Washing Machines
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Oct 14, 2015 | Kenmore 24032\24036 Top Load Washer
Hi I have a indesit IWDC 6105 washer dryer. problem with door lock light. as soon a wash starts light goes off and wash stops and the door unlocks
It's possibly a problem with either the door solenoid/lock or the 'door closed' sensor becoming apparent with the extra movement of washing requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 14, 2011 | Washing Machines
A few weeks ago the machine (IWDC 6125 S) started to flash against all the options at the top. I had turned it on an off and it was working OK. Just yesterday the door was shut, but the machine would not...
The only quick suggestion I have is to unplug it for several minutes and see if it resets. If not, without any other indicator, the only thing I can think of is the door switch, which should be a fairly easy fix.
Jul 04, 2017 | Indesit W 123 Front Load Washer
May 30, 2009 | Indesit W 123 Front Load Washer
Indesit WDG1095W combined washer/dryer - program wheel stopped
I'm a bit confused you posted under Bosch but you specify Indesit, which is a UK machine. The really bad news is you need to replace the timer. the really really bad news is you can only buy the timers from Indesit, I can't find them anywhere in the US. The really really really bad news is they want 117.99 british pounds for them! plus shipping and handling. Here is a link to the Indesit site where you can purchase one.
http://www.4indesit.co.uk/cgi-bin/product.pl?PID=111846&query=Indesit%20WDG1095WG&model=WDG1095WG&path=52691
May 22, 2009 | Bosch Exxcel WFO 2264 Front Load Washer
Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Dec 01, 2008 | Indesit W 123 Front Load Washer
Indesit washer dryer stops halfway through a wash....
depends on what lights are flashing this is your fault code
Mar 28, 2008 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
513 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
