Question about Ruud UAMB036 Air Conditioner
Hi, some anknown animal bit off the reset button on my outside compressor. Where can i buy a new one? Part # I guess DBK 4B04799 or so. Thank you
    Guru:
  • 415 Answers
If this is a RUUD unit, the reset button is for the High Pressure Switch. It cannot be replaced without refrigerant recovery and recharge. Unless it is creating a problem for you, I recommend NOT replacing it (quite expensive) until it DOES become a problem. In the meantime, continue to keep your filters and coils clean. :-)
Posted on May 27, 2010
I was given a 3-HP HDC pancake compressor a few days ago and the man (he was throwing it away) said it worked although a bit slow to build up pressure and that it needed a new gasket. Is it worth keeping...
Hi app_3rp778
I would suggest that you replace the head gasket, it should not cost too much to replace it.
I would guess the gasket would be around $10-$15 usd
If you replace it yourself it would be very advantageous as the repair cost would only be the gasket.
If you take it to a repair shop, I would guess they would charge around $50-$60 usd for the repair of the compressor and replacement of the gasket
Do some research on the web for your parts or check out the webpage below.
Have the parts sent to your house...will be cheaper to take the part to the repair shop then to have them order it...they normally charge 200% on parts.
Also look at the following webpage for repair of the gasket and some more hints on how to repair a porter cable compressor pancake compressor, it is not your compressor but it will be somewhat like your compressors repair procedures.
Please take time to rate me
Bud
http://www.ereplacementparts.com/porter-cable-cf2600-type-pancake-air-compressor-parts-c-129_1662_2167.html
Oct 27, 2012 | Hdc Homer Hdc 2 Hp, 4 Gallon Pancake Air...
I am looking for the reset button on my Amana heat pump the outside unit fan inside operates but the compressor does not run
There are no simple reset buttons for that...
Here is a tip about troubleshooting your airconditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 11, 2011 | Amana Heating & Cooling
Hi...i've lost my SE G900. I've backed up my contacts on my pc with my PC Suite for SE. Now I want to restore my contacts to my new phone, but i cant do this because different type of file extension. the...
hi just use any zip [like 7zip winzip use right mouse button on the file and select open with option and select any zip software ] software to open that bm3 . then unzip the contacts and simply copy to a memory card and use contacts import option in your new phone.
if any problem while doing this just mail me tsnp@ymail.com
Apr 15, 2011 | Sony Ericsson Walkman W810i Cellular Phone
Air conditioner fan in the outside unit shuts and after a little bit when I hit the reset button and manually push the fan it goes back on for a little bit. 1)Your site is wonderful THANK YOU 2) If it...
Hello Open the service panel near where the wire/power goes in.It will look like a large battery with plug in termnials on top.Write down what wires go/went where.C=common,HERM=compressor,F=fan.You need the UF & the volts values off the old one.Good luck.
Sep 07, 2010 | Heating & Cooling
The compressor reset button trips often, , it reads within the specs under load 8-10amp or reset at 12amp , I hard wired it and its been working fine for 20 days now , should I buy a new reset button
I have read that a thin or long extension cable can cause this. But you can also circuit breaker that plugs into the line before the device. And I would think the breaker on the main board would be enough protection.
Aug 10, 2010 | Hitachi EC12 Portable Electric 2hp Air...
How to open a dbk file
by changing the .dbk extension to .zip exe.. then open in outlook express
May 23, 2010 | Sony Ericsson K530i Cellular Phone
Where is the reset button on the Comfortmaker AC-model number NAC048AKC3? Thank you!
if it is a split system that is permanently installed in your house the reset button will always be near the compressor so that means on the outside unit somewhere, you probably wont need to remove any screws to get to it. but before you press that button and think all is well, why did the reset button trip? answer> because it is a high pressure cut off. your unit probably reached over 350psi on the high side line or possibly even higher. that is not good. you may have a dirty condenser coil (outside) and you can just hose that out with a garden hose (pull the disconnect first). or you may have a rotting out coil if your unit is old or you live less than 5 miles from the ocean. Or you may have a bad condenser (outside) fan motor. check that out. if it overloads again after hitting the reset (which this unit may not even have, not all units have these just the higher end ones) well if it does overload again call a licensed ac guy trust me it will cost you less in the long run.
Oct 09, 2009 | Heating & Cooling
Is there a reset button on the outside compressor/fan unit?
No there is no reset button "per se" but you can check the fuse box/disconnect to see if the fuse is blown.
Jul 05, 2009 | Carrier 38BRC036 Air Conditioner
Very hot outside. blower comes on but outside fan
Check the voltage source for the fan and compressor
Check the start capacitor for the compressor.If its over heating :bad compressor
Hotpoint freezer
The compressor needs to cool off before it will restart. Leave it unpluged for a couple hours to see if it will restart.
Apr 04, 2008 | Freezers
Ruud UAMB036 Air Conditioner Logo
108 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
