Question about HP LaserJet 5200tn Printer
Problem printing When I try to print it tells me that the top bin is full.  It will print if I mess with it (turn it off, etc.) Can you hlep
    Problem Solver:
  • 8 Answers
Empty the output bin. Printing resumes
Posted on Apr 24, 2008
Can not print. Standard top bin full shows up on the display
Clean top bin sensor.
Remove back cover., observe a flip moving up & down while paper is coming out & the same was fed into a ir sensor., u can see from back side., clean that sendor with good brush or cloth..
Sep 24, 2014 | HP LaserJet 5200 Printer
HP Laserjet 5200 top bin full
Hi, Remove all the papers from out put bin & check if not solved remove both side and top covers absorve right side of the out put bin flag sensor clean it with high pressure air or clean with dry cloth gently. Best of luck...Vinay
Apr 18, 2011 | HP LaserJet 5200 Printer
Standard out put full remove all paper from bin
If you have removed the paper from the output bin at the top of the printer and the message won't go away, either the sensor is bad or the actuator is stuck in the up position.
Look at the top of the printer at the rear right of the fuser. There should be what looks like a plastic rod(usually black in color) with plastic "flags". It should be free, moving up and down with your finger. It is used to guide the paper into the bin. What usually happens is the rod gets jammed in the up position telling the printer that the output bin is full. If your printer has this problem, just push the flags down to free it. This should fix your problem. Sorry but I don't have a 5550 in front of me, so this is from memory.
Good Luck
Sep 06, 2010 | HP LaserJet 5550dtn Printer
Display say "BIN IS FULL"
HP says: 1) remove all printed pages from output bin 2) "flick" the output bin lever with your finger
If fault continues, contact HP.
Nov 27, 2009 | HP LaserJet 4000n Printer
Jam in Output Bin Message
The output Bin message comes from the sensor that reads when there are to many pages printed and they are sitting on the top BIN. Check the BIN sensor or arm and make sure that it is reading. Most of the time the sensor has a broken arm the the sensor reads to let it know when the BIN is full. You might want make sure that you reconnected the sensor and you have take the top cover off to replace the fuser.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
Std bin full
The Standard Bin Full message is refering to the main output tray for the printer. If you have nothing mounted to the top of the printer, then the standard tray is where the paper is exiting.
What the message is telling you the bin is full and it is not, most likley the failure is that the sensor (a piece of wire is jammed in the up position. Just release the wire and let it hang down. That should clear your message and let you start printing again.
Mar 26, 2009 | Lexmark T622 Laser Printer
Standard top bin full error in hp 5200 tn laserjet printer
i have hp 5200 printer
printer shows message top bin full
and not prints what slution of this error
Aug 28, 2008 | HP LaserJet 2420 Printer
Std Bin Full
If you see the flag at the paer exit, where the printed paper is.
Jun 18, 2008 | Lexmark Optra T614 Laser Printer
Prints image too small
Your actual computer print settings may need re-setting if this makes sense, check your pc's print settings, not just the printers own settings. Yoou can get help with this by going to control panel, printers and faxes, troubleshooting, help and supposrt, and follow links. Did you try specifying the paper type to your printer in properties or settings or selecting fit to page which can override printer default settings. It may be that your printer has a glitch like spyware too, try unplugging all cords, replug and turn on. This will rest it. Sometimes this does the job, and run antispyware etc just to be sure. Some programs have their own "printer" guide, go to printers annd faxes settings to see if you need to select a program specific printer setting.
Aug 01, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
HP LaserJet 5200tn Printer Logo
165 people viewed this question
Ben Johnson
