Question about Kenwood KNB-15AM, ,TK260,TK-270,TK-360,TK-370, 7.5v 1700mAh NiMH 2-Way Radio
How do i reset a Kenwood TK-270?It wont let me key pad program anymore the Field Programming procedure for the Kenwood TK-270 was Press and hold (light) & (dial) while turning on radio and Hold until (SEL) appears on the display. but now since i programed it idk what i did but it wont let me get back to programing like it says.
5 Suggested Answers
  • 41 Answers
SOURCE: Programming Software for Kenwood TK-3130 Protalk XLS Radio
The software is only availible from Kenwood. the only way to get it is to purchase the registration key from them for that software. Sorry, I program radios everyday and even the company I work for has to purchase the Registration keys.
Posted on Jun 02, 2009
SOURCE: need manual for kenwood tk-270 transceiver does any one no were i
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor KeyOff = off1 = Monitor momentary2 = Monitor Lock3 = Squelch off momentary 2. Scan KeyOff = offCo = carrier operateTo = Time operate 3. Dial KeyOff = offOn = enable 4. TA keyTA = talkaroundRV = ReverseOff 5. Lo KeyOnOff 6. PriorityNone1 = fixed2 = selected 7. Fixed Priority ChannelTurn selector to channel 8. Look back time ATurn selector to time in seconds 9. Look back time BTurn selector to time in seconds 10. Revert Channel1 = Selected2 = Last Call3 = Last used4 = Selected + Talkback5 = Priority6 = Priority + Talkback 11. Tx Dwell timeTurn selector to time in seconds 12. Drop out delayTurn selector to time in seconds 13. Time out timerTurn selector to time in seconds 14. Tot Pre-alertTurn selector to time in seconds 15. Tot Rekey timeTurn selector to time in seconds 16. Tot reset timeTurn selector to time in seconds
Posted on Jun 08, 2009
SOURCE: looking for manual for kenwood tk-270 transceiver
the manual from the manufacturer is pretty much useless. every time i wanted to do something with mine all the manual said was "see a sales rep or dealer!" i have the software (windows version) that has a pretty good help file in it. you may want to check out the yahoo boards for kenwood.
Posted on Jul 17, 2009
schast
  • 56 Answers
SOURCE: i have an older kenwood tk 270 radio. im having
These radios can be programmed via the keypad. However, this option must be enabled through the software, and must have a component removed from the circuit board. If you have a radio that will not go into self-programming mode when you use the proper key combination (light button+dial button while turning the radio on), your radio has not been enabled for this option.
programming instructions:
http://www.repeater-builder.com/kenwood/field-programming-tk-x70.html
Posted on Feb 16, 2010
I can't unlock my Kenwood 777 with the key
Check in programming and enable the password. Don't forget the password, write it any where.
Apr 18, 2014 | Kenwood KNB-15AM,...
TK 3300 won't field program
try getting a tech support agent from kenwood to help out they should be able to walk you thru it, our company deals with Motorola and Vertex, so im not too familiar with the Kenwood specs. http://kenwood.com/
Mar 15, 2014 | Kenwood Tk-2300 & Tk- 3300 Radio Software...
Can i field program a kenwood tk-270g handhel if so how
If you buy a programming cable and the software, yes. Unless you're a certified technician (or you're an Amateur using it in the Ham Bands) programming a commercial radio is illegal.
Jan 05, 2011 | Kenwood Radio TK 260 360 270 370 2100 3100...
How do you perform a full reset on a kenwood tk-370
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor Key Off = off 1 = Monitor momentary 2 = Monitor Lock 3 = Squelch off momentary 2. Scan Key Off = off Co = carrier operate To = Time operate 3. Dial Key Off = off On = enable 4. TA key TA = talkaround RV = Reverse Off 5. Lo Key On Off 6. Priority None 1 = fixed 2 = selected 7. Fixed Priority Channel Turn selector to channel 8. Look back time A Turn selector to time in seconds 9. Look back time B Turn selector to time in seconds 10. Revert Channel 1 = Selected 2 = Last Call 3 = Last used 4 = Selected + Talkback 5 = Priority 6 = Priority + Talkback 11. Tx Dwell time Turn selector to time in seconds 12. Drop out delay Turn selector to time in seconds 13. Time out timer Turn selector to time in seconds 14. Tot Pre-alert Turn selector to time in seconds 15. Tot Rekey time Turn selector to time in seconds 16. Tot reset time Turn selector to time in seconds 17. Squelch Level Turn selector to Squelch 18. Beep tone On Off 19. Signalling And Or 20. Battery Save On Off 21. Selectable QT On Off 22. Clr to transpond On Off 23. Del/ Add On Off Pressing (Dial) allows programming of: DTMF 24. digit time Turn selector to time in milliseconds 25. inter digit time Turn selector to time in milliseconds 26. First digit time Turn selector to time in milliseconds 27. Rise time Turn selector to time in milliseconds 28. Rise time with QT Turn selector to time in milliseconds 29. PTT ID Off 1 = connect 2 = disconnect 3 = Both 30. Dial ID On Off 31. Connect ID 32. Disconnect ID 33. # of DTMF keys on Keypad 12 16 34. DTMF hold time On Off 35. Store & send On Off 36. D key assignment Turn selector to D or time in seconds for pause 37. Dtmf Signaling Off 1 = code squelch 2 = Selective Call 38. Intermediate Code OFF A B C D E F 39. Group Code OFF A B C D E F 40. Auto Reset time Turn selector for time in Seconds 41. Call Alert/ Transpond Off 1 = 2 = 3 4 5 42. Transpond On Off Pressing (TA) will allow you to program Frequencies Use selector to choose channel Press PTT Enter Rx frequency using: - the Selector Knob to change kHz; - the Selector Knob + (light) to change MHz. If no channel is Shown press the (LO) button. Press PTT Enter Rx CTCSS code Press PTT Enter Tx Frequency as above Press PTT Enter Tx CTCSS code Press PTT 1. Option Signal Off 1 = DTMF 2 = 2-Tone 2. PTT ID On Off 3. Add/ Del 4. Busy Tx 5. Clock frequency shift 6. Power Hi Low Repeat for the other channels (you've got a 32 channel radio, so it may take a while...) <end>
Sep 16, 2010 | Kenwood Radio TK 260 360 270 370 2100 3100...
I have an older kenwood tk 270 radio. im having trouble puting it in programming mode. iv followed the instuctions to hold the light and dial buttons while turninging radio on but nothing happens got any...
Feb 15, 2010 | Kenwood Radio TK 260 360 270 370 2100 3100...
May 06, 2009 | Kenwood Radio TK 260 360 270 370 2100 3100...
Need manual for kenwood tk-270 transceiver does any one no were i
Apr 27, 2009 | Kenwood Radio TK 260 360 270 370 2100 3100...
Kenwood radio TK270G
HI I'm seeing a different software number...
See: http://www.nielsoncom.com/kenwood/TK-270-370.pdf ( KPG-56D )
One thing you might try is programming off the front panel if "Field Programming" has been "enabled" in the software
See: http://www.repeater-builder.com/kenwood/field-programming-tk-x70.html it's slow coming up but interesting.
Is the transfer cable USB or 9 pin? I know I have had problems with laptops and had to go back to a desktop and it would work fine. I know some of my Motorola programs I have to use a old slower computer because the computer's speed. The new computers won't work with some of the older radio programs. I know my Yaesu VX-7 has the same problem with uploading, I'll get it out today and see what I did to fix it...
Nov 04, 2008 | Kenwood Radio TK 260 360 270 370 2100 3100...
Radio Communications Logo
381 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
