Sharp LC-13av4u will only stay on for about 8 sec.. I ahve checked the caps, on power board
  • Matthew Albert
    Matthew Albert May 27, 2010
    I dont think thats the same power board?
    Anyway i found out that 2 out of 4 lights are out,,is there any way to bypass this so the tv will stay on?
    it looks fine with just the two lights
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If you have already checked the capacitors on the power supply board and they seem to be fine then it can be a circuit protection issue. If that is the case the unit either turns off after sometime or the sound remains there. To check what is the issues inspect the diodes as they are part of the protection circuit if the backlight misfires. You can also test the components by a voltmeter however, it is only recommended if you have knowledge of internal circuitry. Please note that the TV components consists high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 27, 2010
  • 4,472 Answers
I would purchase and replace the power supply board as a whole as this is the common problem with these tv's and it only runs 25$. Here is the link:
http://www.discount-merchant.com/SHARP-BL0170F01012-1-Power-Supply-Board-Main-p/1004275.htm
Thank you,
Lee
  • Lee A.
    Lee A. May 27, 2010
    If i am understanding what you are saying then it's probably a problem with the bulbs or the inverter board. Also that is the power supply board listed for the model you have me. If you need further assitance let me know and if/when you find it appropriate please accept/rate my solution accordingly.
    Thank you,
    Lee
WHEN I TURN TV ON IT SHUTS OFF IN LESS THAN 10 SECONDS
These sets have a tendency to have bad power supply boards. They have to be replaced as a complete assembly. you should only call out, or take this set to an authorized Sharp repair center my friend. Good Luck
May 25, 2007 | Sharp LC-13AV4U 13 in. EDTV-Ready LCD...
Sharp LC-50LE442U does not turn on. RED standby LED is lit, when I try to turn it on, the LED turns green but screen stays black. LED then stays green, won't go back to red when turning off.
You cannot tell if capacitors are bad just by looking at them. they need to have a meter called an ESR meter to test them, I can tell you with almost certainty that it is a capacitor in the power supply that has failed. The whole board is Sharp 9JY0950CTN02000 Power Supply Board (09-50CTN020-00) LC-50LE440U LC-50LE442U
May 27, 2016 | Sharp AQUOS LC-50LE442U 50" LED TV...
My Sharp Aquuos tv won't turn on. It has power and will come on for a second or two, then goes black. The tv's power indicator is on and stays red
The issue here is with the power supply board, allot of these TV's are known for bad capacitors so you might want to check those out.
When a bad cap is present the TV will not function as normal so keep that in mind.
A best resource for bad caps www.badcaps.net
A $2 cap could save you hundreds in repaires.
Please do not forget to leave a postive rating before you leave,
Rulds2008
Sep 20, 2011 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp LC-13AV4U - turn it on and in ten seconds it turns off. Happens every time.
Hello
There is some short with the inside circut of your TV. The short usually occurs with the inverter transformer for backligh bulbs of with video processing section. These tw sections should be checked throrughly to find out the actual short. You must have sound knoledge in digital electronics, skill to work with these section, good quality digital multimeter [analogue multimeter or low quality digital multimeters should not be touched with LCD circuits]. Actually this is not a user repairable fault. If you have all facilities mentioned above check these sections for short. OK.
Jul 02, 2011 | Sharp LC-13AV4U 13 in. EDTV-Ready LCD...
Sharp Aquos LC-42DH77E 42" LCD TV TV appears to
The PNL-POW (LCD panel Power) and the PS-ON will be 0V until the main board send out the signal to turn them on, it is working.
Do you get backlights?
Did you check the fuses on the Inverter board? You power supply is working.
This service manual may match your chassis:
http://elektrotanya.com/?q=showresult&megnev=Sharp&megnev2=LC-42DH77E&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 01, 2011 | Sharp Televison & Video
Sharp TV powers off after 15-30 seconds
FOR SHARP LC-13AV1U TV - is it lighting up with in 5 sec
May 11, 2009 | Sharp LC-13AV1U Television
Lc-13av4u Shuts down 10 seconds
some projection tv's will do this if you do not touch another button within 10 seconds. Power your tv on then change the volume or channel. This should let your tv know that it was not an accidental power on. Hope this helps.
Sep 11, 2008 | Sharp Televison & Video
Turns itself off
Happens every time.
Any Ideas?
DO THIS AT YOUR OWN RISK!
This is NOT a fix, this is a permanent band-aid.
All you need is a phillips head and tiny diagonal cutters....
Heck, even a nail clipper would do it.
Just disable that faulty protection shut-down circuit!
Remove all the screws from the back cover
and look at the main board with the
unplugged! power cord towards you.
In the upper right corner of the board, you will find
a tiny red-striped zener diode, labeled as D409.
It is to the right of an electrolytic capacitor marked C403.
Snip this diode, at either end, or snip both ends and discard it.
Re-assemble the TV.....and you just got your tv back!.
I only run mine when I am sitting in front of it,
I never leave it running unattended....just in case!
Don't blame me it yours burns up....but mine is just fine.
The Robot Doctor.
Oct 20, 2006 | Sharp LC-13AV4U 13 in. EDTV-Ready LCD...
Televison & Video Logo
157 people viewed this question
Top Televison & Video Experts
Electro Med Services...
