Question about Panasonic KX-TD7896 Cordless Phone
Battery works. Won't turn on
Battery works - charged with green light. Won't turn on. Blank display.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
I have the exact same phone and exact same problem. Phone is charged in cradle and green light (indicating full charge) is lit on handset. Opened it up and everything appears clean as a whistle. Did the original poster find a solution? if so, please post it. Thanks.
Posted on Jun 13, 2010
  • 1 more comment
  • Axster Jun 16, 2010
    If the battery is good and the phone is working it will come to life with this one simple step: Press power button (same as "hang up button") for a few seconds. Voila!
  • Roslyn Phillips
    Roslyn Phillips Feb 04, 2014
    Genious!! Thank you so much...
  • Alex Liberman
    Alex Liberman Apr 15, 2014
    Thanks Axster, worked perfectly!
Not charging
The chances are that the battery has failed. The age of the device would indicate that the battery is probably NiCd - these batteries have a memory effect that means after a while the battery thinks that "fully Discharged" would be the state that is the most usual for the charger to be used most often. You will need to open the device to get the battery out to find the part number. You will then be able to order on from an online retailer.
Jul 11, 2013 | Aluratek APMP101F Cinepal HD Media Player...
My coolpix L810 won't turn on. Green light comes on but goes out. Can't see screen. Lense was frozen but plugged into computer and closed.
have the battery full charge? sometime the battery is not charged although the charging indicator is full charge, maybe the battery is shorted out.
May 04, 2013 | Nikon COOLPIX L810
I purchased a new battery for my Dell Latitude 810 and it still won't hold a charge. The battery indicator light is green for a brief period, turns amber and then shuts off.
If you installed a new battery in your Dell computer and still can't get it to charge, there is a strong possibility that there is something wrong with the charging system
Mar 07, 2013 | Dell Latitude D810 Notebook
DS Lite screen won't light up
your battery is very low. Charge the battery for 3 hours. you can still play games, while it charges.
Jan 14, 2013 | Nintendo DS Lite Console
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
Motor won't engage. I turn the throttle and get a clicking sound, but nothing happens. We've charged the battery for about 4-6 hours, but the light stays red, never turns green. Help?!!
sounds like the battery is bad and not taking charge.replace battery attemp again if not then check for fuel, spark and compression.then c wat happens or wats not working any motor no matter how small or big has to hv those three things to run. hope this helps.
Jul 08, 2012 | Electric Razor Pocket Rocket Ride-on...
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
My battery indicator won't turn green when it is fully charged.what is this issue?
It is possible one of the battery cells has degraded enough the battery is not showing a full charge, or there is an issue with the green light, but this is minor provided everything is working.
Mar 07, 2012 | Acer Aspire One D250 16GHz Intel Atom...
Ok i have a Ibm thinkpad and my charger is stuck on green battery but it wont charge at all. It was working earlier but i turned of the computer the wrong way by holding the power button since i was in a...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 18, 2011 | IBM ThinkPad T30 2366 Notebook
Brand new out of the box Volitation 9053 wont take a charge. Charger never goes green to indicate full charge. At most I get 5-10 seconds of weak spin and then the red light on the ECS board flashes. ...
  • If this is a brand new item out of the box, if this were my item, I would send it back for an exchange. The charger never turns green because the battery never gets a full charge. Because of that you won't get a 7.4volt reading out of the battery, Either the battery is not taking the charge or the charger is malfunctioning and not charging proper. The lights may work for a bit while the motor won't spin because a light takes far less voltage than turning a motor. Because you don't know if it is the battery or charger and it is new I have to suggest to take it back. The sooner the better. Messing with it will just void the warranty.
Regards, Tony
May 22, 2011 | xheli 9053 Outdoor Volitation Metal...
Panasonic KX-TD7896 Cordless Phone Logo
577 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
