Question about HP Scanjet 8390 Flatbed Scanner
HP Scanjet 8390 display reads "duplex error", then switches to "processing". We have disconnetted and reconnected, reset, and unstalled & reinstalled software and drivers
5 Suggested Answers
SOURCE: HP Scanjet 3200c Driver
Hola sera posible que me envien programa del sencajet 3200c en español por favor
Posted on Jun 15, 2008
SOURCE: Scanjet 3770 installation
I WANT SOFT OF HP SCANJET 3770 PLEASE
Posted on Nov 09, 2008
SOURCE: the drivers of my scanjet hp 3670
driver of scanjet hp 3670
Posted on Mar 14, 2009
  • 489 Answers
SOURCE: Software for HP Scanjet 3200C, OS = WinXP
ftp://ftp.hp.com/pub/softlib/software4/sj648/sj-24149-1/sj648en.exe
try this
rate pls.
Posted on May 28, 2009
PDF FORMAT INVISIBLE
Check the full feature software is installed and also check the Adobe Acrobat Reader installed.
Make sure both Acrobat Reader and Scanjet full feature installed.
Mar 11, 2014 | HP Scanjet 5590 Flatbed Scanner
HP Scanjet 8390 Flatbed Scanner will not power up.
Power supply most likely: If external "brick" power supply, a volt meter can tell if you have power at the tip If attached or detacable power cord (NO "brick", you''ll have to disassemble to determine
Jan 06, 2013 | HP Scanjet 8390 Flatbed Scanner
In your best soulution for fixing the 59.30 error code on a hp 4700 printer it states to remove the duplex devise from the printer. what is the duplex device and where is it located
Duplex is here:
But 59.30 error (Fuser motor startup error/Black or N/A)
Follow next instructions:
Fuser motor error
1. Reconnect the connectors J4605 for the fuser motor and J1024 on the DC controller PCB.
2. Run the component test to verify that the fuser motor is working correctly.
3. Replace the fuser motor.
Aug 01, 2011 | HP LaserJet 4700 Printer
I just replaced the Fuser Kit on the Office''s HP 5500 laser color printer but the error is still there and as in the instructions I never received the question: "Is this a new fuser...
Here is the instructions to reset the fuser maintenance count:
HP Color LaserJet 5500/5550 Maintenance Code Reset Instructions
  1. Press the ? button until the display reads "CONFIGURE DEVICE" and press ?.
  2. Press the ? button until the display reads "RESETS" and press ?.
  3. Press the ? button until the display reads "RESET SUPPLIES" and press ?.
  4. Press the ? button until the display reads "FUSER" and press ?
This should reset your printer and clear the error message.
I hope this helps, if so please rate my solution,
BuddyMc
May 09, 2011 | HP LaserJet 5550 Printer
MY PRINTER hp laserget 4250 dtn is displaying 57.4 error when I turned it on, what can I do? I am ofetn requested to suitch off and then to switch on but it fails to mark " Ready"
57.4 Main fan error
Hi I hope this will help
The text come from the hp manual
good luck Ian
Q2431-90912 Chapter 7 Troubleshooting 287
57.X
PRINTER ERROR
To continue turn off then on
or
57.3
EP FAN FAILURE
or
57.4
MAIN FAN FAILURE
A printer fan is not functioning.
X Description
3 EP cartridge fan, right side
(LJ 4300 only)
4 Main cooling fan, left side
Turn the printer off and then on.
57.3 Cartridge fan error (F2)
between the fan and the
DC controller PCA
(location J78).
2. Replace the fan. See "Cooling
fan (right side;
HP LaserJet 4300 series
printer only)" on page 170.
3. Replace the
DC controller PCA. See
"DC controller PCA" on
page 181.
57.4 Main fan error (F1)
power supply.
2. Verify that the ribbon cables
are fully seated in the
connectors on the
DC controller PCA.
3. Replace the fan. See "Main
cooling fan (left side)" on
page 168.
4. Replace the power supply.
See "Power supply" on
page 188.
5. Replace the
page 181.
57.7
DUPLEX FAN FAILURE
The cooling fan in the optional
duplexer is not functioning.
1. Turn the printer off and then
on.
2. Replace the duplexer.
Mar 25, 2011 | HP LaserJet 4250dtn Printer
Hp scanjet 8390 display message error ( duplex error )
Check for paper mis-feed. Look in back for panel. Duplexer (2 sided printing) sometime hang paper when turning it over in the machine.
Feb 06, 2011 | Computers & Internet
Cancel double sided copying
Slide the DUPLEX switch to the one sided mode on the ADF.
Also you should be able to set the single and dula sided mode from your scanning application in the setup tab.
Oct 15, 2009 | HP Scanjet 8250 Flatbed Scanner
ScanJet 5300c didn't work
Most likely the destination folder for the scanning is a shared folder with limited rights. As the administrator, reset the permissions for that folder or redirect the software to a common folder with read/write/creation etc... access.
Also, make sure you are using the HP provided drivers and not those from Microsoft.
Nov 24, 2008 | HP ScanJet 5300C Flatbed Scanner
HP SCANJET 8250
Do you have the scanner set for "duplex" (two-sided) scanning? Check the switch near the front of the unit.
Feb 20, 2007 | HP Scanjet 8250 Flatbed Scanner
324 people viewed this question
Seeker5211
Seeker5211
