Question about Campbell Hausfeld Electric Stationary Air Compressor 5 HP 161 CFM 90 PSI 80Gallon 230 Volt CE5000
Oil leak filled with oil now can smell oil in th air
    Problem Solver:
  • 17 Answers
Did you over fill it? How old is the compressor?
Posted on Dec 18, 2010
I have a 2003 altima and I keep smelling exhaust fumes in the car.i have replaced the cat . Th esmell seems to be getting worse. What could be th eissue?
Exhaust leaks are a bear, i would first start off by checking where the headers meet the motor. broken down gaskets can release exhaust into the engine bay which will make its way into your cab. either way the burning off of oil is not good as exhaust leaks can damage your valve train and it makes for a very expensive endeavor. Tracking down your exhaust leak should be a top priority though!
Jan 29, 2013 | 2003 Nissan Altima
I put oil in my car and it has been leaking but it does not come out under my car, I noticed that there is a lot of oil on the motor from the cap and it smokes smells like burning oil. what should I do
you should check and replace the pcv valve,if it gets plugged it can cause too much pressure in the crankcase and it will leak out at the weakest point which usually is the oil fill cap.the vapor from the fumes leaking out has oil in it and when it touches anything that is hot it burns off causing the smoke and smell.once the vapor is gone the smoke and smell will eventually go away,or you can wash the motor off.
Jun 10, 2011 | 1996 Volvo 850
I had a Honeywell Oil Filled Radiator HZ 680....I discovered ti was leaking , so I immediately threw it away. However, it appears that the oil leaked onto my hardwood floors....and it seems it spread. I...
You can use a degreaser. The spell will not harm you, just so you know. These heaters are filled with oil that will not harm people from the fumes. Most likely what you are smelling is the part of the oil that burned on the element as it was leaking out. Now as for your floors, I am sorry to hear this but you can replace that portion or call a certified floor repair person that specializes in hard wood floors.
Hope this helps.
Jan 28, 2011 | Heating & Cooling
My lakewood oil-filled radiator heater has a smell of oil? or something. What is it and is it dangerous. Could it be electrical?
The heater is filled with oil and it is leaking....you will need to dispose of it and buy a new one... it is not repairable...
heatman101
Jan 04, 2011 | Lakewood Oil-Filled Electric Radiator...
Oil filled dimplex leaking oil and funny smell
oil smells funny when its hot you heater is porous needs to be replaced
Nov 29, 2010 | Dimplex OFC2000 Oil Filled Radiator Heater
Gas is leaking into my oil pan when parked 2002 yamaha 650 v-star
you have adity inlrt needle in the carb it is letting gas fill th bowl and it leaking past th valve seats it will cause damage to valve seat clean the carbs thourly
Jul 29, 2010 | 2002 Yamaha V Star 1100 Classic
When I turn on the defrost overwhelming antifreeze smell fills th
your heater core is leaking, replace it !!!!!!!!!!!!!
Jan 15, 2010 | 1995 Volvo 850
Trying to bleed clutch ktm 625 smc
they can be a pain.......the best way to do so without a vacuum bleeder is to back fill it. buy a oil ratio syringe from walmart or an auto parts store. attach a short vinyl tube to it and **** it full of fluid. now remove reservoir cap and attach syringe to the slave cylinder. open bleed bolt and back fill slowly....tighten bleeder and work clutch to check for pressure and unsure there's no air.
BE SURE TO NOTE IF IT USES DOT4 BRAKE FLUID OR MINERAL OIL
MAGURA=MINERAL OIL
BREMBO=DOT4
SOME RACERS USE JOHNSONS BABY OIL AS ITS MINERAL OIL THAT YOU CAN SMELL IF IT LEAKS
Oct 01, 2009 | KTM 625 SMC Motorcycles
Oil was low on 96 mazda, red light came on. Filled up w/ 2 quarts. Drove it for 20 minutes and hot oil smell - no light on. Touched it before I was to fill up with another quart and extremely hot. Woud...
it sounds like u have a mild oil leak from the top end of the motor . it is probubly near the exsost which would cause the burnig oil smell.
Jul 29, 2009 | 2000 Mazda Protege
Campbell Hausfeld Electric Stationary Air Compressor  5 HP 161 CFM  90 PSI 80Gallon 230 Volt CE5000 Logo
119 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
