Question about GPS
Goodmans gnav10 sat nav
Have bought a second hand goodmans gnav10 and when i switch it on it says no maps found,where can i download uk/ireland maps,any help very appreciated
How to charge mio sat nav in car
should power up all the time
sales pitch doesn't mention a short life battery
can t find a user manual for that one
unplug it after a while if it wont function then it may not have a battery feature
Mio Spirit 685 5 Sat Nav with UK and Ireland Maps
Jul 19, 2016 | Mio Spirit 685 GPS 5" Widescreen Sat Nav...
I wish a free download for maps on my sat nav
Sat Nav - Free Downloads at CNET Download
download.cnet.com/s/sat-nav/
Download.comResults 1 - 10 of 1697 - sat nav free download - TV Remote Controller (ARM/XScale), Virus ... Includes detailed instructions, with maps and street view images of.
upgrade sat nav maps - How-To - PC Advisor
www.pcadvisor.co.uk > ... > How to update satnav maps
Dec 17, 2013 - How to update satnav maps: TomTom, Garmin and Navman charges ... purchasing, you are entitled to download it and update your device for free. ... when i bought my Garmin, there were roads both new and old that were not ...
MapFactor GPS Navigation Maps - Google Play
https://play.google.com/store/apps/details?id...mapfactor.navigator&hl...
Rating: 4.5 - ‎736,227 votes - ‎Free
Jan 05, 2016 | GPS
Hi my sat nav ran out of charge. After re-charging it it won't switch on.
HI YES ,I HAD SAME PROBLEM ..THE CONNECTION IN SIDE FOR BATTERY CONNECTION TO CHARGE IT HAS GOT TO BE CONNECTED ,,MINE HAD COME AWAY ..OPEN BACK CAREFULLY AND RESOLDER ..OR TAKE TO SOMEONE WHO DOES ELECTRICS ,IT IS EASY THOUGH ,,HPE THAT HELPS ,-)
Apr 27, 2015 | Mio Spirit 485 GPS Sat Nav with UK and...
How do I convert my sat nav from europe to usa
Some Sat Navs can't convert, If it's bought & set to UK & Ireland maps, then you are stuck. 2nd thing , even if you can use Europe Maps on your Sat Nav, you still will be unable, to load USA maps.
Sat Nav not compatable, You will have to buy a NEW ONE.
Mar 07, 2015 | Garmin nuvi 255W GPS Receiver
Garmin nuvi 1300 Query
Usually they come preloaded with some maps and you purchase additional ones. Check the manual that came with it or the box and that should tell you which ones it has. Generally speaking a basic unit bought in the UK will come with UK & Ireland preloaded, more expensive unit may have UK, Ireland & Europe and the most expensive may have all three plus USA. It's unlikely you will have 'lost' your USA map. The unit should have a 'drop down' menu which allows you to choose which map to load. Hope this helps!
Jul 26, 2010 | Garmin nuvi 1300 Car GPS Receiver
I need help installing a map onto a gramin sat nav
No. They are refering to maps sent from the computer to the Garmin device. Maps are not transferred off the SD card to the unit. Simply insert the SD card into the device and the Garmin will read the maps from the card.
to double check follow these steps
  1. Power on the unit with the card in
  2. Press Tools
  3. Press Settings
  4. Press Map
  5. Press Info (or map info)
This page should list out both your UK and Ireland maps(old as dirt) and your new Benelux and France maps as well
Apr 20, 2017 | Garmin Nuvi 600 Car GPS Receiver
I formatted garmin nuvi 205
You have not only erased all of your maps but you have also erased all of the internal software that was a part of your Garmin. I do not recall seeing anything on the web site that resolves your issue. If you can get a hold of another 205 perhaps you can make an image file of its software and then transfer that over to yours.
Apr 22, 2017 | Garmin Nuvi 350 Car GPS Receiver
LUCCA 3.5b sat nav
buy a 1 gig memory card then use the dvd you got with it and pull uk and ireland maps on to that little chip. i cant figure out how too get it from the chip to the nav but it works fine if you leave the chip in there
Sep 13, 2008 | GPS
Goodmans Gnav 10 with no display
don't think to much, just buy another one.
May 27, 2008 | GPS
GPS Logo
187 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
