Question about Kenmore 24032\24036 Top Load Washer
Water will not empty from the wash cycle and go into rinse cycle.
I think its the pump at bottom.It stops with dirty water in drum. It will restart but won't empty and fill back up for the rinse cycle.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
If the hoses are fine (make sure that the outlet hose leading to the drain or wash basin isn't clogged), check the shaft from the motor to the pump ( make sure that the pump turns) and check inside the pump to make sure the inlet and outlet aren't blocked.
Posted on May 28, 2010
How do I fix washing machine to finish emptying during rinse and spin cycle?
Long shot, but does it fill the same as when new? I would check the atmospheric switch which is a hollow tube that runs down the inside of the drum(not in the wash cage) when the water fills, It pushes air up to stop the fill. It may have gotten clogged. Or partially clogged.
Mar 28, 2016 | Fisher and Paykel Washing Machines
Dishwasher not cleaning very well.
Hello do it heat up ok is the water Hot please
Nov 13, 2015 | Siemens Dishwashers
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Why does my creda washing machine stops when it gets to a rinse
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the next cycle with excess water in the drum.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom)
Jul 05, 2011 | Washing Machines
During short spin cycles between rinses it doesn't pump water out
Try looking to see if the little motor is spinning the drain pump. It is in the bottom right. Occasionally I get a small metal shard which locks the pump and therefore-no draining. You can undo everything and check the pump for blockage. Then if need be, replace the mechanisim. The parts are all on line, as is the manual. or call 800 776-3538
May 11, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Water drips out of front door
There does obviously need to be water in the drum to wash or rinse the clothes, however it may be the water level is now higher than normal , check for any blockages and check any drain pump filter.If all o.k. it may be the door seal is leaking .If under g/tee call maytag for repair
Jan 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Aeg 72630 update will not rinse during rinse cycle
if is an asko remove the top panel and check the triple valve for a faulty solenoid,also remove paddle from inside the drum with a screwdriver in the middle hole and pull toward you,and look inside the black sump hose to see if theres a plastic ball in the hose if so you need to remove it take of front panel/s to get access to the hose.also check for coins in the hoses acting like a valve.let me know and i will think of somthing else
Mar 25, 2008 | Asko W6761 Front Load Washer
If the drain lines were plugged, there may have been enough pressure on the pump to fault out. Make sure the sewer line is completely open, as well as the lines at the pump.
Jan 14, 2008 | Washing Machines
Front Load washing machine
common for the impellor to come off the drain pump also common to have water in the pump rotor housing making the pump fail to start
Oct 13, 2006 | Indesit WA 115 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
37 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
