Question about Garden
Starts and runs good but after an hour of cutting when you turn off.. then you want to cut again it will start just fine but when you engage the blades the fuse blows it has a 20 amp fuse is this the right size fuse or is something shorting out the pto...
  • 66 Answers
I normally see 30 amp fuses to the deck...but it depends on which mower you have. If you place a larger fuse and it does take a 20 amp..you may burn something up. I would check the blades, spindle towers and clean all the stuff on top and inside the deck to look for something catching on the blades. www.nnyparts.com
Posted on May 30, 2010
2004 cut out..then started..then cut off while turning into drive..steering locked..tried to start..whirring sound but won't start..running fine before
> whirring sound
Not related to other described problems but this is the sound when a starter is not engaging the teeth on a flywheel.
This implies either a failed Bendix that shoves the starter gear into the flywheel or a missing tooth or teeth on the flywheel.
Jun 06, 2015 | Volvo XC70 Cars & Trucks
After or during rain with the water on the road the car will have an engine shutter and slows right down and then cuts out, it does not want to start and drive until a about 12 hours latter.
Well sir or mam. If I had more information it would be helpful. First, has the car ever had a tune up? (spark plugs/wires/distributor cap and rotor) If your vehicle is at least 6 years old or has 60,000 miles on it that would be a great place to start. However the problem your describing is what sounds like a worn out distributor cap and rotor. They should be removed from the vehicle and inspected for corrosion. If they appear to be discolored or rusty I would definitely replace them. That's where I would start. If you still have problems after that please contact the site again and I can give you more info.
Apr 05, 2015 | Cars & Trucks
Starter clicks will not turn engine over
next is jumper cable jump start to good running helper car battery.
that cuts cause in 1/2 , 15min works.
car starts, your battery is bad, or not charging, running, or is only discharged. (left head lights on)
wont crank. now?\\
hot wire the solenoid, for cutting possibles in 1/2 again.
what transmission? in car?
see tricks here. (and the hot wire trick)
http://www.fixkick.com/nocrank.html#tricks
Feb 15, 2014 | 2005 Honda Accord 2.0
Starts and cuts off
serial number/keygen for registry reviver
Jan 28, 2014 | Cars & Trucks
Kmx 200 (1988) not starting
Sounds like its not getting enough fuel to stay started. Look for clogged fuel lines and bad gas.
Feb 07, 2013 | kawasaki KMX 125 Motorcycles
My wife can drive around town for about an hour the car runs good but she will come back home try to leave again and the car want start but if i let it sit for about an hour then it will start
the ignition (coil) is affected it will make your car cold run fine but cuts off when hot if occurred look for the coil replace it with new one
Jun 24, 2011 | 1990 Buick Skylark
2003 hyundai xg350. Starts and runs, then cuts off.
Ita an imobilizer fault.Try changing the key fob battery first.Before having it reprogamed.
Jul 07, 2009 | Hyundai Motor 2003 XG350
Garden Logo
140 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
