Question about HP Scanjet 4470c Flatbed Scanner
Need to clean underside of glass. Static elec. has attracted dust that is degrading the scans.
  • dgoolsbee May 28, 2010
    Your solution is one I have been trying for sometime. HP told me that this model cannot be opened by anyone--me or HP. Probably not true but will give up until it is unusable and go to Epson.
    Guru:
  • 528 Answers
Hi dgoolsbee. Please check the link i have provided to you on how to clean the under side glass of your scanner. Please click here.
Let me know if you need more assistance.
Posted on May 27, 2010
The scanner glass inside is cloudy
I recommend you do not take off the glass. I have done it and was never able to get rid of the dust, which really shows up on every scan. The fogging has something to do with an optical coating on the underside of the glass. If I knew then what I know now, I would let it be. If the fogging doesn't show up in scans, leave it. If it really does show up, the glass itself is often held down by simple double stick tape. You try to keep the tape intact so you can put it back down. It may be strong enough that the plastic frame on top of it could snap. Do it in as clean (not dusty) environment as possible so dust does not drift down inside the scanner. Never touch the lamp or move the scan mechanism. Again, don't do it unless it's showing up on scan results. Sadly, nobody "fixes" scanners, they are disposable, like coffee pots, even if they cost 300.00.
Mar 12, 2014 | Epson Perfection 1650 Photo Flatbed...
MY HP 8500A HAS STARTED PRINTING WHOLE PAGE BARCODE LOOKING LINES WHEN I PRINT OR COPY IN BLACK. COLOR LOOKS GREAT. IVE CLEANED THE PRINT HEADS AND ALIGNED THEM. ANY OTHER OPTIONS? THANKS
Solution one: Reset the product If there is static interference, or loose connections with the product, this can result in bands or lines in the copy, fax, or scan output. To resolve this issue, check the product connections and reset the product Press the Power button (c01602202.gif ) to turn on the product.Disconnect the power cord from the rear of the product.Unplug the power cord from the wall outlet.Wait 30 seconds.Plug the power cord back into the wall outlet. Reconnect the power cord to the rear of the product.Press the Power utton (c01602202.gif ) to turn on the product.Try to copy, fax, or scan again.If these steps resolved the issue , you do not need to continue troubleshooting.If the issue persists , continue to the next solution.
Solution two: Clean the scanner glass and scanner lid
If the scanner glass or the white underside of the lid has fingerprints, smudges, lint, dust, or other debris, this can slow performance and affect copy and scan quality. To resolve this issue, clean the product.Before you begin, gather the following materials:Several clean, soft, lint-free cloths
Mild glass cleaner
CAUTION: Use only glass cleaner to clean the scanner glass. Do not use cleaners that contain abrasives, acetone, benzene, or carbon tetrachloride. These substances can damage the product. Avoid isopropyl alcohol (rubbing alcohol) because it can leave streaks on the glass.
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the rear of the product.
  3. Lift the scanner lid. Figure 3: Lift the scanner lid
  4. Spray a clean, soft, lint-free cloth with mild glass cleaner.
    CAUTION: To protect the scanner, do not spray the glass cleaner directly on the glass.
  5. Clean the scanner glass with the lint-free cloth. Figure 4: The scanner glass
  6. Clean the glass strip next to the scanner glass with the lint-free cloth. Figure 5: The glass strip
  7. Dry the scanner glass and the glass strip thoroughly with a clean, dry cloth or chamois to prevent spotting, and then dry the white underside of the scanner lid.
    NOTE: Do not use paper-based wipes or tissues that can leave fiber residue.
  8. Clean the white underside of the scanner lid. Figure 6: The underside of the scanner lid
  9. Close the scanner lid.
  10. Reconnect the power cord to the rear of the product.
  11. If the product does not turn on by itself, press the Power button (c01602202.gif ) to turn it on.
  12. Try to copy, fax, or scan again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution three: Clean the automatic document feeder (ADF) Use the following steps to clean the automatic document feeder. Step one: Clean the ADF rollers and separator pad
  1. Gather the following materials:
    • A clean, lint-free cloth, or any cloth that will not come apart or leave fibers
    • Distilled, filtered, or bottled water (tap water might damage the product)
  2. Remove any documents from the document feeder tray.
  3. Press the Power button (c01602202.gif ) to turn off the product.
  4. Disconnect the power cord from the rear of the product.
  5. Lift the cover of the ADF until it stops. Figure 7: Lift the ADF cover
  6. Find the pick rollers and separator pad. Figure 8: Locations of the pick rollers and separator padLightly dampen a clean lint-free cloth with distilled or bottled water, and then squeeze any excess liquid from the cloth.
  7. Use the damp cloth to wipe any residue off the separator pad.
Aug 14, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I want to clean the underside scanning glass of the HP C4180 scanner/printer because when I scann, the top is clean, but the scaned pictures look like they have little specks of dust all over the scanned...
It takes several steps to remove the glass carrier for cleaning, but it's not really difficult. You'll need a T10 Torx screwdriver, eyeglasses cleaner or similar, and a lint-free microfiber cloth.
1) Remove usb and power cables. Flip the front covers open (revealing the cartridge-insertion area). Remove 2 screws from the right-side panel, and remove that panel.
2) Open the photo-paper holder on the left side, depress plastic tabs on its top and bottom so it can swing out 90 degrees, and remove it.
3) Remove 2 screws from the left-side panel, and remove the panel. This exposes the gears of the paper-handling mechanism; take care not to move the gears. Disconnect the three ribbon cables connected the bottom circuit board.
4) Flip up the LCD, exposing a screw. (Note that this one is shorter than all of the others.) Remove the screw. Lift the scanner lid and remove two screws just behind the rear of the glass. Close the cover. Lift the rear of the glass carrier, then slide it back slightly to remove it. Take care not to move the scanner bar that remains in the main body of the machine.
5) Keeping the lid shut, flip the glass carrier over over. Spray cleaner on the glass and wipe; repeat as needed. I use a bright light at a low angle to check for particles on the glass.
To reassemble, just reverse the steps. Finish by cleaning the top of the glass.
Paul Hays
Sep 19, 2010 | HP Photosmart C4180 All-In-One InkJet...
I'm getting a color line going down the page on my pictures and the quality of the picture is no good
IssueWhen you copy, fax, or scan an original, the resulting output contains vertical bands, lines, or streaks in one or more colors.When you print the original, the output is normal. Figure 1: Sample output with vertical white or black linesc01892760.gif Figure 2: Sample output with vertical colored bands or linesc01892761.gif
NOTE: This article does not apply to most PSC products, to the Photosmart C6100 or C7200 series, or to the Photosmart Premium C309a and C309c All-in-Ones.If you are using a PSC product other than the PSC 2400 or 2500 series All-in-Ones, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c01887564) (in English).If you are using a Photosmart Premium C6100 or C7200 series All-in-One, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c00899181) (in English). If you are using a Photosmart Premium C309a or C309c All-in-One, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c01622189) (in English). Solution one: Reset the All-in-One If there is static interference, or loose connections with the product, this can result in bands or lines in the copy, fax, or scan output. To resolve this issue, check the product connections and reset the product.
  1. Make sure the product is powered on, and then disconnect the power cord from the product.
  2. Disconnect the USB cable from the product, and then disconnect it from the computer.
  3. Reconnect the USB cable to the computer, and then reconnect it securely to the product.
  4. Disconnect the power cord from the wall outlet, and then reconnect it to the wall outlet.
  5. Reconnect the power cord to the product.
  6. Press the Power button (c01892763.gif ) to turn on the product.
  • If the issue persists , see the next solution.
Solution two: Clean the All-in-One and print a blank copy If the scanner glass or the white underside of the lid has fingerprints, smudges, lint, dust, or other debris, this can slow performance and affect copy and scan quality. To resolve this issue, clean the All-in-One. Before you begin, gather the following materials:
  • Several clean, soft, lint-free cloths
  • Mild glass cleaner
Step one: Clean the scanner glass and lid
  1. Press the Power button (c01892763.gif ) to turn off the product, and then disconnect the power cord from the product.
  2. Open the scanner lid. Figure 3: Open the scanner lidc01893292.gif
  3. Spray a clean, soft, lint-free cloth with mild glass cleaner.
  4. Wipe the scanner glass and the white underside of the scanner lid with the dampened cloth. Figure 4: Scanner glassc01893293.gif Figure 5: Scanner lidc01893294.gif
  5. Dry the scanner glass thoroughly with a clean, dry cloth, or chamois to prevent spotting, and then dry the white underside of the scanner lid.
  6. Close the scanner lid.
  7. Reconnect the power cord to the back of the product, and then press the Power or Start button (c01892763.gif ) to turn on the product.
Step two: Make a blank copy
  1. Remove any originals from the scanner glass.
  2. Load plain white paper in the input tray.
  3. Press Start Copy Black to make a blank copy.
If the copy is clean, there is no need to continue troubleshooting.If the copy has vertical bands, lines, or streaks, there might be dust inside the product, poor internal connections, or the product might be damaged. See the next solution. Solution three: Service the All-in-One If you have completed all the steps listed above and are still experiencing a problem, service the product. Causes
  • Static interference
  • Loose USB cable or power cord connection
  • Fingerprints, smudges, lint, or dust on the scanner glass
  • Dirt or debris on the scanner lid
  • Scratched or damaged scanner glass
  • Poor internal connections
  • Dirt or debris inside the product
  • Damaged or faulty scanner bulb or parts
Jan 27, 2010 | HP Photosmart 2610 All-In-One InkJet...
I have a vertical black line on the right side of my copies
Go to the HP website and read their solution. Here is what I found:
Issue When you copy, fax, or scan an original, the resulting output contains vertical bands, lines, or streaks in one or more colors. When you print the original, the output is normal. Figure 1: Sample output with vertical white or black linesc01892760.gif Figure 2: Sample output with vertical colored bands or linesc01892761.gif Solution one: Reset the All-in-One If there is static interference, or loose connections with the product, this can result in bands or lines in the copy, fax, or scan output. To resolve this issue, check the product connections and reset the product.
Solution two: Clean the All-in-One and make a blank copy If the scanner glass or the white underside of the lid has fingerprints, smudges, lint, dust, or other debris, this can slow performance and affect copy and scan quality. To resolve this issue, clean the All-in-One. Before you begin, gather the following materials:
CAUTION: Use only glass cleaner to clean the scanner glass. Do not use cleaners that contain abrasives, acetone, benzene, or carbon tetrachloride. These substances can damage the product. Avoid isopropyl alcohol (rubbing alcohol) because it can leave streaks on the glass. Step one: Clean the scanner glass and lid
  1. Press the Power button (c01892763.gif ) to turn off the product, and disconnect the power cord from the product.
  2. Open the scanner lid. Figure 3: Open the scanner lidc01760887.gif NOTE: Your product might vary in appearance from the one shown in the figure, but the solution is the same.
  3. Spray a clean, soft, lint-free cloth with mild glass cleaner. CAUTION: Do not spray the glass cleaner directly on the glass to avoid damaging the scanner.
  4. Wipe the scanner glass and the white underside of the scanner lid with the dampened cloth. Figure 4: Scanner glassc01891674.gif Figure 5: Scanner lidc01891675.gif
  5. Dry the scanner glass thoroughly with a clean, dry cloth, or chamois to prevent spotting, and then dry the white underside of the scanner lid. NOTE: Do not use paper-based wipes or tissues that can leave fiber residue.
  7. Reconnect the power cord to the product, and press the Power button (c01892763.gif ) to turn on the product.
If the copy is clean, there is no need to continue troubleshooting. If the copy has vertical bands, lines, or streaks, there might be dust inside the product, poor internal connections, or the product might be damaged. See the next solution. Solution three: Service the All-in-One If you have completed all the steps listed above and are still experiencing a problem, service the product. Causes
Nov 21, 2009 | HP DeskJet F380 All-In-One Printer
How to Clean the inner part of the glass for scanning
Generally you should not have to clean the underside of the glass unless you are in a high dust environment. This would require disassembly of most of the printer itself. The glass is held in by double-sided tape or a bead of glue, so don't try to remove the glass sheet itself.
The easy part is the beginning, removing the scanner cover. Next you will have to locate screws around the outside and start taking panels off. Keep note of the panels and the screws. After the side panels are off, there should be a set of screws around the scanner itself that hold the scanner and plastic casing with the scanner glass. Once those are removed, the scanner glass with its frame should be able to be removed. From there you can use whatever you would like for glass cleaning, make sure it is streak free.
Older scanners make this easier. Most of them are 4-6 screws and the top half pops off and can be easily cleaned. A multifunction isn't so fun in this sense.
Hope this helps!
Oct 18, 2008 | Canon Pixma MP800 All-In-One InkJet...
Dirty glass inside scanner
To clean the glass on the inside you must disassemble the unit so that you have access to the underside of the glass. If you save all your screws and are careful to lay things out in the order you remove the it is easy to put it back together and you do not have to worry about breaking anything.
Once you have access to the underside of the glass I use real windex and newspaper. With the newspaper you get a streak free shine with no lint particles. If there is dust inside the glass there is most likely dust on the scanners optics. Gently clean them the same way. Be gentle when cleaning the scan bar optics. They are not extremely delicate but it will break if you apply too much pressure as it is a long thin piece of glass.
When you put your scanner all back together it will scan as good as new and all the little black specs and streaks will be gone in your scans. I've done this 100+ times and it works every time. If you need help feel free to contact me an I will walk you through it for free.
I hope you found this info detailed enough to fix your scanner yourself, But If you need some help or moral support feel free to E-mail me and I will even call you for free. Make sure to say what you need in your E-mail as I fix a lot of things for people.
George
Jul 24, 2008 | Lexmark X5150 All-In-One InkJet Printer
Cleaning the inside of Lexmark 5150 scanners glass
To clean the glass on the inside you must disassemble the unit so that you have access to the underside of the glass. If you save all your screws and are careful to lay things out in the order you remove them it is easy to put it back together and you do not have to worry about breaking anything.
George
Cleaning the Flatbed Glass
We cannot clean inside the flatbed scanner glass, it is not a removable part.
Jun 06, 2008 | HP Photosmart C6100 All-In-One Printer
White spots on scanned photos
There's probably nothing you can do for dust under the glass, but in the Advanced settings for your scanner, there is an option to turn on "Reduce Dust & Scratches", with three different 'strengths'. You may want to try this to see if it helps.
Apr 21, 2008 | Canon PIXMA MP530 All-In-One InkJet...
HP Scanjet 4470c Flatbed Scanner Logo
mukhtar21 shaikh
mukhtar21 shaikh
