Question about Palm Treo 755p Smartphone
Trying to hotsync my desktop and my 755, and I use Outlook.
This is the message on my hotsync log and it is the same for Contacts, etc. I don't see a Date Book application on my device:
Date Book application database is not found. Please invoke the Date Book application on the handheld once and re-synchronize
OLERR:05-0001
OLERR:0D-0004
OLERR:0D-0001
- Not Synchronized
Outlook Calendar synchronization failed
  • Ettinger Jun 09, 2008
    I have erased all the data in the device and re-booted the device. Time consuming and frustrating.
    Tom Ettinger
  • EarlDGrt Jul 17, 2008
    Outlook Calendar
    OLERR:03-0010
    OLERR:0D-000E
    OLERR:0D-0004
    OLERR:0D-0001
    - Recovery Sync
If using verizon go into the wireless sync application and select settings> connection> advanced settings> and select enable other sync apps.
Posted on May 26, 2008
Can't syncronize
Posted on Apr 20, 2008
  • 78 Answers
Http://kb.palm.com
Solution ID: 36784
Posted on Apr 07, 2008
Sync loss on outlook
You go to your toolbar and right-click on the icon. Select custom. On the drop-down, secect your hotsync name.. make sure the contacts and other built-in conduits (date-book, memos) are set to desktop overwrites handheld.
Sep 14, 2005 | Samsung SPH-i500 Handheld
Unable to sync with outlook 2003
Try to change conduits to hotsync with PDS, if it will work then the problem is with the MSOutlook.
Sep 12, 2005 | Palm Treo 650 Handheld
Lost all contacts, memos, tasks, after LifeDrive Update 1.0
This morning I downloaded LifeDrive Update 1.0, and when I did a HotSync afterwards, I got an error message saying, Handheld Tasks application database version not supported. Handheld Notes application database version not supported. Now my contacts, memos, tasks, calendar entries and possibly other items are all gone!! This is the core data that is the reason why I use a PDA! I would be totally distraught, except that the data does still seem to exist in Outlook on my PC. I am running Outlook 2002, SP3 on a WinXP machine. Can anyone help to fix this problem? thanks,
Sep 12, 2005 | Palm LifeDrive Handheld
Hot sync does not work
"PLEASE SET SYNCHRONIZATION OPTION ENABLE SYNC WHEN OUTLOOK IN UI IN ORDER TO SYNC IN OFFLINE MODE" Just go to your Hotsync Manager icon Click Custom Click each Outlook conduit ex. Calendar Outlook Click Change Click Settings Check the Box that says Enable Synchronization when Outlook is Offline Then do same process for Contacts, Tasks and Memos. Wherever your updated data is..make sure you set Action of conduit to example: Desktop Overwrites HH (if your OUTLOOK has the most updated data.) Hope that resolves your problem.
Sep 11, 2005 | Palm Zire 72 Handheld
How do I purge contacts from the Treo 600?
Best would be to perform a hard reset. This will delete all your contacts, but also all your other data on your phone as well such as mail, sms, call log, settings etc.
  • Unscrew the tip from your stylus
  • Locate the "RESET" hole on the back of your Treo 600
  • Press and hold the power button on the top of your Treo and then press the reset button with the stylus pin
  • Remove the pin from the reset hole FIRST, and then release the power button.
  • The screen will say "erase all data?", tap the up arrow to answer yes
  • Sep 11, 2005 | Palm Treo 600 Handheld
    Cannot SYNC Outlook Calendar and Contacts
    Probably one of these issues - your data is there but you are looking in the wrong place. I am trying to sync my outlook calendar and contacts via Hotsync on a Palm IIIc. It gives me the status of OK, but nothing shows up on the Palm. I have set the custom on Hotsync to desktop overwrites handheld, but still will not work. Thanks.
    Sep 11, 2005 | Palm IIIc Handheld
    MS Outlook syncs calendar, notes but not contacts
    Click on the hotsync icon in your system tray and then click "custom". That will bring up the list of things you are configured to sync with (conduits). For each of the ones you have problems with, click that conduit and then make sure it's set to sync the way you want...desktop overrides, handheld overrides, syncronize, etc. Potentially you have some of them selected as "do nothing". What shows up when I click custom from hotsync are the following Outlook Conduits: Calendar, Contacts, Tasks and Memos. If you don't have those showing up, you need to update your Outlook conduits on your PC. If you have them, click to select the problem conduit, then click "change" and select what you want to have happen.
    Sep 11, 2005 | Palm m130 Handheld
    Won't sync to clean Palm
    It may be due to a permissions issue on the workstation running the hot sync program
    Sep 11, 2005 | Palm m105 Handheld
    How Do I hotsync w/Outlook
    what software did you download for your outlook conduits? the installation cd already has the outlook conduits you need.. you just have to install palm desktop first then you'll be given options whether to sync your handheld with palm desktop or with outlook. choose sync with outlook
    Sep 11, 2005 | Palm Treo 650 Handheld
    Sync fails with "too many open databases"
    This is what I did to fix that error:
    Hard-reset your Palm to erase all data (that usually involves pushing the small "reset" button on the back, then pressing the "power on" button until the device boots, and then pressing "up" to confirm the hard-reset)
    After that, sync your palm. The sync software will ask if you want to use your existing profile or create a new one. Create a new one. Then the program will offer to sync your Outlook profile with your Palm. Click on "ok", and a message asking you to accept to sync your Outlook data with more than one profile will pop-up. Click on OK, again... and that's it!
    Sep 07, 2005 | Palm Tungsten T3 Handheld
    Palm Treo 755p Smartphone Logo
    412 people viewed this question
    Top Palm Computers & Internet Experts
    Michael Vincent Cruz
    ray gallant
    Raj Patel
    Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
