I am trying to submit a page,the error below occurs,why?,?Server Error in '/' Application. Object reference not set to an instance of an object. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.NullReferenceException: Object reference not set to an instance of an object. Source Error: Line 649: this.password = member.Password; Line 650: this.loginName = member.LoginName; Line 651: this.facebookUserID = ValueFunctions.StringOrBlank(member.getProperty("facebook_id").Value); Line 652: Line 653: int mediaID = ValueFunctions.IntOrZero(member.getProperty("memberProfileImage").Value);
  • 590 Answers
Hi Mwiseman96,
The error stack trace which you have mentioned is specific to the code which you have written and it seems there is some problem with the code which you have written and not with server or anything else. So there is no common specif solution.
"this.password = member.Password;"
In the above line of code, you are trying to use "this" operator which specifies the current object which invoked the function. Your error shows that "this" object is null and not having proper object instance assigned.
so try creating new object using "new" operator and call your function with reference to that object which your created.
example:
class test
public void funtiontest()
//new object created
test obj1 = new test();
//function is called with reference to the obj created
obj1.funtion1();
private void function1()
//your code where this operator references to the called object "obj1"
I hope this is helpful to you.
Thanks
Posted on May 27, 2010
When I search for a specific web site (not all web sites), I get this: Server Error in '/' Application. Runtime Error Description: An exception occurred while processing your request. Additionally,...
For some reason the server that serves the page you are trying to access is not processing your request correctly. Could be a problem of cookies not accepted, or some other security settings, or a problem in the server.
Mar 04, 2014 | Computers & Internet
I can't logiin
Try again later. A system error occurred that wasn't your fault.
Apr 23, 2017 | GPS
When I trying to open the archive files, error "RRV Bucket is corrupted" is displayed. I am unable to solve this problem. can you please provide a solution. I understand data can be retrieved ,...
If this error occurs in a case where Shared Mail is being used, then first refer to the documents titled "'RRV Buffer Overflow' Error Message While Attempting to View a Mail Document" (#1093390) and "Using the OBJECT COLLECT Server Task to Manage Shared Mail Databases" (#1088860).
If the database is not in R5 format (ODS 41), then from a Domino 4.x server run Compact -M on the database. On a Domino 5.x server simply run Compact on the database. If updating the ODS to 41 does not resolve the issue, refer to the document titled "Database Has Grown too Large; Use File New Replica...' Error Occurs When Opening Local Database" (#1102305).
If none of the above resolves the issue, then where possible, a new replica should be made. If a replica is not available, restore the database from a backup, if one exists.
Supporting Information:
Corruption can be caused by many things, but a possible cause for the error in this case was that a third-party application had altered the physical location of the database on the hard disk, resulting in the Record Relocation Vector table being incorrect and the information not being located. This has been reported to happen with customers using a disk defragment utility while Compact is running.
May 28, 2011 | Computers & Internet
Kyocera 5050 error code 2202
This is an error is indicating a connection error when using the send feature.
Below I have provided some information or for more information download the users guide from the manufatcures website using this link. http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=16088&rid=16313
2101, 2102, 2103, 2201, 2202, 2203, 3101:
The network cable is disconnected or the hub that it is connected to is not operating properly. Check the cable and the hub. Otherwise, the server name or the host name of the SMTP server is
not set correctly. Use COMMAND CENTER and register the SMTP server name and the host name
correctly.
2204: The E-mail size exceeds the acceptable send data capacity. Decrease the size or resolution of the scanned data to be transmitted and resend the E-mail. 5101, 5102, 5103, 5104, 7102, 720f:
Turn the main power switch off and back on. If this error occurs several times, make a note of the displayed error code and contact your service representative.(Refer to the corrective action for the error message " An error has occurred.")
9181: The scanned original exceeds the acceptable number of pages of 999. Send the ecess pages separately.
Hope this is helpful,
Shawn
Mar 11, 2011 | Kyocera Mita KM-5035 Printer
Can't download drivers. http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h...
I just tried to get to the HP site from 2 machines, and they both failed as well. I download drivers from this site regularly, so the problem is that the HP support website is down. I don't think this is a problem with your computer or browser - it's an HP website problem. Give it some time, usually big websites like this don't stay down for very long.
May 14, 2009 | HP LaserJet 3600n Printer
I use frontpage 2003 to edit my site( http://www.riversoftime.com) I am getting an error message on my page called ''Miscellanous'' that reads: An error has occurred accessing windows share point server...
Hi..seems you are trying to edit SharePoint Portal sites using frontpage...open the same using sharepoint designer and with proper administrator credentials..(usually it prompts when you connect to server using a client machine)...All changes done to the application files are then committed on the server- end and will work absolutey fine../
warm regards.
May 06, 2009 | Computers & Internet
An unhandled exception has occured .......
An attempt was made in a program or script to use an object before creating the object. For example:
dim SomeObject as Object
SomeObject.attribute = "string value"
will generate thie error message because the SomeObject that is being referred to has not been created. For this, we need the New keyword:
dim SomeObject as New SomeObject
will run without errors
Nov 19, 2008 | Microsoft Windows XP Home Edition
Have a error show up as HP image zone-error states X the program has encountered an unexpected error.: object reference not set to on instant of an object
this error is caused when i tried to bind data in grid view in visual studio 2005. the procedure which i followed are as follows, first i have selected choose data sourse in the grid view task and then i selected new data source. then in the data source configuration wizard i have selected database and moved further. then i have clicked the new connection button and entered all the details and clicked test connection, i get the message 'test connection succeeded' after that when i click ok in the add connection page i get the error 'Object reference not set to an instance of an object error'.
Aug 15, 2008 | HP Computers & Internet
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
