Question about Brother MFC-8460N All-In-One Printer
Paper does not auto feed on top of printer
When I put a few sheets on top of feeder they do not go through to scan.
  • 241 Answers
You could be having feed issues. I would suggest you have a technician clean the paper path sometime the rollers get a little shiney and don't pickup the paper like they should. A certified technician will also replace any rollers if needed and perform a maintenance cleaning.
Posted on May 28, 2010
Canon ip1800 is experiencing paper jam.whener tries to print, cannot feed the paper properly
Sometimes a printer just needs some cleaning.
Remove the jammed paper following the procedure below. (1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the Paper Output Slot, whichever is easier.If the paper tears and a piece remains inside the printer, turn the printer off, open the Front Cover, and remove it. Be careful not to touch the components inside the printer. After removing all paper, close the Front Cover and turn it back on.If you cannot pull the paper out, turn the printer off and turn it back on. The paper will be ejected automatically. (2) Reload the paper in the printer, and press the RESUME/CANCEL button on the printer. If you turned off the printer in step 1, all print jobs in queue are canceled. Reprint if necessary.
Make sure to clean the paper feed rollers if paper is not fed properly. Cleaning the Paper Feed Roller of the Auto Sheet Feeder consumes it, so perform this only when necessary. 1. Make sure that the printer is turned on, and then remove any paper from the Auto Sheet Feeder. 2. Open the Printer Properties dialog box. 3. Click the Maintenance tab and then Roller Cleaning. 4. Confirm the message, and then click OK.The Paper Feed Rollers will rotate as they clean. 5. When the message appears, load three or more sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder.Set the Paper Thickness Lever to the left. 6. Confirm the displayed message and click OK.The paper that is loaded in the printer will feed through the printer and be ejected. 7. When the confirmation message is displayed, click OK. If this procedure does not solve the problem, clean the surface of the roller with applying a slightly moisten cotton swab with water to wipe off dust or stain.
If the problem still persists, contact a Canon service representative.
Mar 28, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
The printer keeps telling me it's out of paper, which it isn't
1> Open the sheet feeder cover and pull out the paper support.
Set paper, aligning the right edge of the paper to the cover guide with the paper's print side facing up.
Pinch and slide the paper guide to the paper's left side.
Note: Make sure to set paper lengthwise. Setting Credit Card sized paper long-side down by mistake may cause a paper jam.
Pull down the paper output tray supporting with both hands.
Pull out the extension completely.
Ensure that the Power lamp and the Auto Sheet Feeder lamp light.
Note: If the Cassette lamp lights, press the Paper Feed switch to light the Auto Sheet Feeder lamp.
If the Auto Sheet Feeder lamp does not light even after pressing the Paper Feed switch, Paper Source in the printer driver may be set to the setting other than Paper Feed Switch.
Nov 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
WILL FEED PLAIN WHITE PAPER BUT WILL NOT FEED PHOTO PAPER
Follow the steps:
•1
Turn on the printer and press the Paper Feed switch until the Auto Sheet Feeder indicator light turns on.
•2
Pull up on the paper sheet feeder on the top and back of the printer and slide out the paper support.
•3
Take a stack of no more than 10 pieces of photo paper and flatten the corners, if they are curled. Curled corners may cause jams within the printer.
•4
Place the paper in the paper sheet feeder with the printable side of the paper facing up. The printable side of photo paper is the shiny or whiter side of the paper.
•5
Print your documents as needed.
Paper Cassette :
•1
Switch on the printer and press the Paper Feed switch until the Cassette indicator light turns on.
•2
Pull on the cassette on the bottom of the printer to slide it out of the printer.
•3
Flatten the corners of a stack of no more than 10 sheets of photo paper if the corners are curled. The paper may become jammed in the printer if the corners are curled.
•4
Place the stack of paper in the cassette so the paper is touching the right side and the printing side of the paper is facing down. Adjust the plastic paper guides so they touch the paper. The paper stack guides help facilitate the paper moving into the printer.
•5
Slide the cassette back into the bottom of the printer. The printer is ready for printing.
Oct 20, 2010 | HP PSC 2355 All-In-One InkJet Printer
Canon MP730 Paper feed is not working correctly.....keeps jamming and feeds the paper incorrectly
There are two feeders on this MP730. There is the sheet feeder on top and there is the paper feeder on the back. You can have problems with both.
The sheet feeder on top.
If the problem is things go through somewhat sideways, and if this is the problem, stuff some postit notes between the back grey thing and the feeder tray to eliminate this problem. Add or subtract to the wad to make it right.
If the problem is it does not grip the sheet, what I used to do is to help it through by one sheet at a time, painful. I got frustrated with this so for scanning, I have a Snap Scan 1500, which is faster and better.
The paper feeder.
A small piece of paper left in the paper infeed path can cause a major problem. You cannot have anything in the paper path that will skew the paper, so you must get any little bit of restriction out of there.
As the printer gets older, you will have to produce your own guides to prevent this skewing, as the guides on the printer do not do this well. I use clamps and wooden guides to keep things in line.
May 25, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
The auto document feeder does not pick up the paper
The pickup roller is probably dirty. Take a clean sheet of paper and put a small amount of rubbing alcohol at the end. Take that same end and place it in the automatic feeder and attempt to feed through for a few times. This should clean the pickup roller and allow paper to be picked up. Wait a few minutes for the alcohol to dry and attemt to feed a clean sheet of paper. You might need to repeat the process a few times
Jan 21, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Not feeding
Have you still getting the problem, have you done cleaning of Cartridge, its nozzle and Contact strip.. then cleaning of Printer roller or carriage rack.. Do a Service of it or get it done by Technician.
Also check the feeder tray.. to grab paper one by one by printer.. Manually
Take all updates for printer and OS.
Oct 31, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Paper feed on Canon i 350n ink jet printer
If the paper is lodged too far into the printer and can't be removed:
Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for inkjet printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
May 13, 2008 | Canon i350 InkJet Printer
I have a Lexmark X3550 printer There is a paper way down inside that cannot be reached Tried the automatic remove and it does nothing. What should I do?This machine is only a few months old.
Bending the bottom exit tray will allow it to be removed. Simply remove tray and wipe rollers right in front of the bar that the ink slides back and forth on. Most printers get a lttle dust on the rollers then they wont feed. Hope this Helps.Sincerely Brian @ Game-On Computers.
Apr 26, 2008 | Office Equipment & Supplies
Automatic Paper feed
Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
Sep 06, 2007 | Samsung ML 1210 Laser Printer
Brother MFC-8460N All-In-One Printer Logo
113 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
