Step by step instructions to install DR350 drum unit on Brother laser printer
  • Lynne Cramer May 27, 2010
    Am on my way to install the drum unit right now. I'll have to let you know how it went when I get back. Thanks for your assistance.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please follow these step by step instructions on how to install drum unit:
1. Open front cover of copier.
2. Rotate lever (maybe blue) to lower transfer/transport assembly.
3. Rotate Developer/Toner assembly handle to move assembly away from drum unit. There is either a Phillips screw or a plastic gripped screw that needs to be removed.
4. Then, carefully, pull the drum unit 2/3 of the way out. At this point, the back half of the unit needs to be supported while pulling the rest of the way out.
5. Open new drum unit.
6. Remove all packing materials with red tag attached...especially black paper covering new drum surface.
7. The new Drum Unit has guides on top that line up with guides in the machine....carefully insert unit in copier until it seats FULLY.
8. Reinstall screw to front of unit.
9. Rotate Developer/Toner Assembly lever to cam back against Drum Unit.
10. Rotate Transfer/Transport Assembly lever to lift assembly upward and latch.
11. Close the front cover and we are done.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 27, 2010
How do I reset a drum life on a d-350?
I think you mean a DR350.
1. Install the new drum and wait for it to display the "replace drum" error.
2. Open the front cover of the printer as if to change the toner out. The printer will read cover is open.
3. Press the clear/back button or just clear. The printer will say "replace drum?
4. press the 1 button and the printer will read "accepted".
5. Turn the printer off then on again to fully clear the error. Upon restarting the printer you'll be good to go.
Jun 12, 2014 | Brother HL-2040 Laser Printer
BROTHER HL4070CDW COMES UP WITH PRINT UNABLE 21. CANNOT CLEAR IT.PLEASE HELP
You need to replace Laser Unit, part number LR1461001.
See the link below from Brother for the instructions step by step on how to replace it:
www.support.brother-usa.com/ModelDocuments/.../SU_P1226_EN.PDF
Go to Ebay and search for "Brother LR1461001" to buy the part. Good luck.
May 27, 2014 | Brother MFC-9840CDW Laser Printer
I just changed the toner and the printer does not print.
If u have the CD of tht printer , u just delet tht printer from the Devices and printers settings. And re installed it
Aug 14, 2012 | Brother HL-2040 Laser Printer
How do you remove the toner cartridge from brothers model mfc-7420?
I would suggest downloading a copy of the user manual for your printer -it gives step-by-step instructions as well as detailed pictures to follow to remove the toner cartridge from the drum
Here is the link for the user manual for the Brother MFC-7420 All-In-One Laser Printer:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000387/ALLFB_UsaEngUsr_B.pdf
This is a .pdf file-You will need Adobe Reader to read the manual.
Once you have downloaded a copy of the manual to your pc, Go to Section 11-25 (p. 112) and 11-26 (p. 113)  Here you will find detailed step-by-step instructions and illustrations on how to remove the toner cartridge from the drum.
Apr 19, 2011 | Brother MFC 7420 All-In-One Laser Printer
How do i reset the brother dr350 drum
If you have already replaced the drum - only do steps 1, 2, 3, 7 and 8.
1. Make sure that the printer is turned on and the Drum LED is blinking. Open the front cover of the printer.
2. Press and hold the GO button for about 4 seconds until all the LEDs light up. Once all four LEDs are lit, release the GO button.
3. Pull out the drum unit and toner cartridge assembly.
4. Push down the blue lock lever and take the toner cartridge out of the drum unit.
5. Unpack new drum unit.
6. Put the toner cartrisge firmly into the new drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
7. Put the drum unit and toner cartridge assembly in the printer.
8. Close the front cover.
Jan 29, 2010 | Brother HL-2040 Laser Printer
Brother 2070 - putting in second cartridge, can't get paper light to extinguish
Do you mean a Drum Unit? If you put a drum cartrige called a DR-someting in the unit you must reset the counter. The step by step instructions comes with the drum unit. If you don't have it open the front door and push each button on top of the machine. one of them should reset it then close the door.
Jul 29, 2009 | Brother HL-2040 Laser Printer
Drum Kit For DCP-7020
Please refer the below link for step by step instructions on Drum replacement.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000098/faq000698_000.html?reg=us&c=us&lang=en&prod=dcp7020_us&Cat=7
Please rate the solution as Fixya if its solving your problem
Thanks
Feb 03, 2009 | Brother DCP-7020 All-In-One Laser Printer
DRUM LIGHT KEEP FLASHING
Take the drum out and wrap it up to keep the light out of it.  Check the contacts inside the printer and make sure there is nothing broken on them.  If there is toner on them, try to clean them off.
Oct 06, 2008 | Brother HL-2040 Laser Printer
Drum change
Step 1. Open Top Cover.(Press the oval button RHFront)
Step 2. Tilt Drum Unit by lifting slightly at the front.(The Toner cartridge sits in the top of this)
Step 3. Remove Drum Unit by lifting straight up.
Step 4. Insert "NEW" Drum Unit. (Steps 3 and 2 in reverse order and direction(s))
May 19, 2008 | OKI B4350 Laser Printer
60 people viewed this question
jasbo
jasbo
