Question about ViewSonic NextVision N3260W 32 in. HD-Ready LCD Television
New Power Supply
Where could I by a new, and better, power supply for Viewsonic N3260w ? if exchanging the two 1000 uF 35 V elconds donĀ“t solve my problem ? The average lifetime for these power supplies seems to be 18 months (safe margin to 1 year varranty) from what I have browsed on Internet, lousy performance, close to criminal!
  • Anonymous Jun 27, 2008
    can you purchase the pwr supply anywhere else viewsonic is out of stock
  • 3 Answers
Saadi2,
In my line of business I have purchased over 20 of these units. The power supply is listed on the Viewsonic Store web-site. Part# is B00005305 cost is about $65.00. Being a Tech myself I went the route of replacing individual parts but had no luck. Take into consideration time to repair its cheaper to by the replacement board. You can always fix the damaged board later as a back up.
Good Luck, OTBMAN
Posted on Apr 08, 2008
  • OTBMAN Nov 05, 2008
    OK, here is the inside secret for getting a new power supply for the N3260 or N3250 although different both are manufactured by the same company. Here is the link for the distibutor
    http://store.ramplus.com/fsfspopfrpos.ht...
    they deal in replacement power supplies.
    If this fails contact the manufacture of the board itself FSP Group, Inc. they can be reached via link
    www.fspgroupusa.com or phone at (909) 606-0960
    The part number is located on the parts side of the board, beginning with FSP---
    You can ship your board in for repair or order a new one if in stock.
    This should do it,
    OTBMAN
Changed electrolyte capacitors and resolved the problem.
Viewsonic n3260w will not turn on no green light and I have check the plug ,cord and power at the wall
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jul 10, 2012 | ViewSonic NextVision N3260W 32 in....
I have a Viewsonic N3260w TV, the Power Indicator light is flashing red continually, but the remote wont start the tv, I have changed the batteries, turned the tv on and off, but the tv still wont...
The problem of your tv is in the power supply. In order to find the power supply of your tv ,you should follow the ac cord. But first you should unplug the unit and open the back cover of your tv there you will find the power supply, try to check the capacitors, it is cylindrical shape and has a plastic cover. Try to observed if their is a wet mark or oil mark that spread in to the pcb then replace it. But when replacing the capacitor you should observed the polarity of the capacitor and replace it exactly the way you pulled it out.
Jun 06, 2011 | ViewSonic NextVision N3260W 32 in....
Power light flickers no other sign of power n3260w ?
If you get a flicker of power light then your problem is in your power supply, I would check for bulging capacitors and replace, if you don't find any then replace power supply, you can check places like shopjimmy.com, or discount-merchant.com or with an s, vancebaldwin.com
Feb 01, 2011 | ViewSonic NextVision N3260W 32 in....
My viewsonic n3260w
You need to find out if it is putting out the 24vdc needed by the backlight inverter board, you may have bad shorted out inverter board that may have taken out the fuse, you need to do some probing.
Power supply pin out: http://www.fspgroupusa.com/images/specs/FSP228-3F01_SPEC.pdf
Power supply: http://www.shopjimmy.com/fsp-fsp228-3f01-power-supply.htm
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 21, 2010 | ViewSonic NextVision N3260W 32 in....
Where can i get power supply module for viewsonic lcd tv model N3260w
You can buy power supply board/ module of Viewsonic N3260W from Shop Jimmy on special price, $65 only.
Thanks.
Mar 02, 2010 | Televison & Video
ViewSonic Mod# N3260W VS11436 1M
I do not know the exact value but if you trace out the copper trace from the rectifier output, it should go to the first filter cap and then there will be an inductor and filter cap after that, you can figure out the voltage rating from there. You can get the parts here: http://www.shopjimmy.com/catalogsearch/result/?q=ViewSonic+N3260W
Look here about caps: http://en.wikipedia.org/wiki/Capacitor_plague
Pictures of the power supply will help. budmrtn@aol.com
Dec 08, 2009 | ViewSonic NextVision N3260W 32 in....
Viewsonic N3260W made loud pop and will not turn on.
We got the part in today and the hubby fixed the tv. It is as good as new. We are very happy with our $62 purchase.
Go to http://store.ramplus.com/fsfspopfrpos.html
FSP228-3F01, FSP Open Frame Power Supply Replacement for Viewsonic N3260W - 32" LCD TV
It worked like a charm and took about 10 minutes to put in new part and put tv back together.
Jan 04, 2009 | ViewSonic NextVision N3260W 32 in....
Akai cftd 2011
Power supply, replace C31 (1000 25v), C32,and C35 both (1000 Uf 25v) and C33 (680 Uf 25) and it should be good as new...
Bill
Dec 01, 2007 | Akai CFTD2011 20 in. EDTV-Ready LCD...
ViewSonic NextVision N3260W 32 in. HD-Ready LCD Television Logo
1,114 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
