Question about Whirlpool Duet GHW9150P Front Load Washer
Contol locked came on.
What do you do when your control locked comes on and won't go away?
  • 5,911 Answers
The Control Lock is actually a safety feature that allows the consumer to lock the control panel to prevent children from manipulating the controls and accidentally starting the appliance. This can usually be reset and does not require a technician.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite or Whirlpool Duet), the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
Posted on May 27, 2010
Forgot the parental code how do we reset
Hello
Just unlock its Parential contol and reset the TV. NB: You must have its original remote control handset to proceed. If you haven't it with you, just boroww it from somone you know, who have the same model number of Tv; just to unlock it. After unlock, you can use universal remote or so.Proceedings are:
Most GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won
Jun 02, 2011 | GE GTD120 System
Profile fridge/freezer not cooling. Contol pannel
Fist thing you want to do is unplug pull away from wall and remove the cover that covers the motherboard. Then try to loosen by squeezing the plastic tabs that hold the mother board in place pull the board away just enough to expose the back side. Tell me if you see burn marks that are sometimes visible on boards when they become defective. What I want to find is if the high voltage side has failed powering the low voltage side or you just mayhave a defective control panel. Are lights out on the dispenser control panel? Is the model you listed correct PSW26? I can help if you like, Thanks, Sea Breeze
Feb 10, 2010 | GE Profile PSW26P Stainless Steel Side by...
Contol panel not working
do all your buttons work on the panel? if not, replace the user interface, if they do, replace the main control.
Jun 25, 2009 | Maytag 24 in. MDB7751AWS Stainless Steel...
Control locked
look forthe button marked "control lock" and hold it for 3 secs to unlock it
Mar 04, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Keyless entry, Interior lights, AC Fan Controls problem
Yes you Can. Just unhook the Battery Cables Before you Tear into the Box. The reason that everything went Nuts with it is whenever you Un Bolted the Box you took the Ground away from the Box and all the Components Connected to it. That Bolt is a Common Ground for the Dash ans other Components. Please Rate My Response! Thanks!
Feb 06, 2009 | 1998 Dodge Durango
How do you reset the control lock?
book said to hold the end of cycle signal button for three seconds or when the control locked light goes out, good luck
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer
to deactivate the control lock feature, press and hold drain/spin for 3 seconds.
goodluck.
tnx 4 using fixya,
drcool
Nov 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Controls are locked
door locked?? or control locked???? if control locked look to the far rigthset of buttons and the lowest one should say control lock(very small print) or a picture of a loc. hold it in for 305 secs and control lock will release
Mar 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
UNLOCKING THE FRONT LOCK CONTROL
hold it in and it will change. mike
Aug 15, 2007 | JVC AV-27230 27" TV
Whirlpool Duet GHW9150P Front Load Washer Logo
42 people viewed this question
Dan Webster
Dan Webster
Sal De
