Question about Danby DKC646BLS Full Size / Pony Beer Keg Cooler
I plug it in it beeps and shows a ee code - Danby DKC646BLS Full Size / Pony Beer Keg Cooler
I just plugged my new one in and am having the same problem too. I was planning on calling Danby tomorrow. Did you figure out what it was?
Posted on Jun 15, 2010
  • Johnathan applepants
    Johnathan applepants Dec 17, 2013
    did either of you figure it out... im having this problem now and I just replaced the control board and thermostat
Change the display board on front of box!!
Posted on Aug 15, 2014
I have an EE code displaying on the front
Thank you for your post, friend!
I understand that your Frigidaire dishwasher is showing a "EE" error code. However, it appears "EE" is an invalid error code. May I have you model number please? Typically you can locate your serial tag (which lists your model number) on the inside of your dishwasher on the right hand wall. With this information I can better assist you with pinpointing the issue.
In the meantime, let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes. -Matt
Sep 03, 2014 | Frigidaire Dishwashers
Repair of room air conditioner /window unit
You need to check the main breakers in the breaker panel......
Sep 01, 2008 | Heating & Cooling
My asus ee pc atom dual core is not starting it is showing a black screen with ASUS showing and its not booting
Remove anything that's plugged into it (USB keys, USB mouse etc.)
Try power up. If fails, continue.
Remove power supply, and battery. Hold power button for 1minute. Insert battery and power supply.
Hook up to external monitor/tv. Power on. Can you see anything on the TV?
Remove the RAM chips. Try power up. Does it beep?
If NO then your motherboard is broken (specifically issue with CMOS)
If yes, could be graphics related.
Bring it to a PC shop for full diagnosis.
Jan 20, 2014 | ASUS Eee PC 1005HA-PU1X-BK Netbook
When I plug it in the screen shows EEE, and beeps continually. It is around 65 degrees in the area. Nothing clears it or stops the beeping. It worked great yesterday.
The error code E:EE means the breadmaker thinks the temperature is too cool i.e below 59 degrees F or 15 degrees Celsius.
As you say the temperature is actually 65 degrees - then this means that the temperature sensor on the Bread maker has failed and will need to be replaced.
The EEE code and beeping will continue until the failed sensor is replaced and as this is a component failure it cannot be reset unfortunately.
Thanks for using FixYa.
Sep 11, 2011 | Regal Ware K6725 Kitchen Pro Bread Maker
Shows ee and will not come on
EE is an error code. I cant help you with this one , but it means something has failed. Try the Fedders site or a Fedders Agent who may be able to state what the EE code means and then see if you can purchase or obtain a Tech to fit the part required.
Jul 03, 2011 | Fedders AEQ07FBG Air Conditioner
There is an EE code. The machine just beeps.
EE
Remove your washer from the power source if you see an "EE" error code, where the first E is missing the top part of the letter. Your washing machine has a serious malfunction, and you must contact a technician.
A bit odd that as error code EE does not exist for washing machines, it's a refrigeration error code. Unless of course part of the display (led) has been damaged and the code isn't displayed properly.
Hope helps.
Jun 27, 2011 | Washing Machines
We have ducted air which cuts out and shows on the control panel where the clock is says EE.EE
When EE:EE is displayed on remotecontrol , press "Energy Save" &"Zone Control" buttons simultaneouslyfor longer than 3 secs. The error code will then be displayed on the LCD.Then write again. Thanks.
Jan 31, 2011 | Fujitsu Heating & Cooling
Danby Kegerator is beeping and flashing EE and won't cool
I am having the same problem seeing if you found a fix??
Aug 26, 2009 | Danby DKC645BLS Compact Beverage Cooler
My 480 NT Royal Cash Managment System shows "EE" on the screen and beeps not stop
turn the machine to PRG - unplug for 20 seconds. while pressing clr plug back in
May 25, 2009 | Royal Office Equipment & Supplies
ERROR PROBLEM?
Hello this is Spur21,
It sound your machine as an defect and should be returned to the place you purchase it, unless you are willing to contact the Manufacture for assistance. Refer to your owners manual for telephone number. Good luck,
Spur21
Jan 03, 2008 | Breadman TR875 Bread Maker
Danby DKC646BLS Full Size / Pony Beer Keg Cooler Logo
556 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
