Question about Kroy K2500 Thermal Label Printer
I get a cart code: 22. what does that mean ? it wont print or feed
What do airbag flash codes 22, and 18 mean on a 2003 Toyota corolla?
list of airbag flash codes.
12=Low Battery Voltage
13=Air Bag Circuit Shorted to Ground
14=Primary Crash Sensor Circuit Shorted to Ground
21=Safing Sensor Not Mounted to Vehicle Properly
22=Safing Sensor Output Shorted to Battery Voltage
23=Safing Sensor Circuit Input Feed/Return Circuit Open
24=Safing Sensor Output Feed/Return Circuit Open
32 Driver Side Air Bag Circuit High Resistance or Open
33 Passenger Side Air Bag Circuit High Resistance or Open
34=Driver Side Air Bag Circuit Low Resistance or Shorted
35=Passenger Side Air Bag Circuit Low Resistance or Shorted
41=RH Primary Crash Sensor Feed/Return Circuit Open
42=LH Primary Crash Sensor Feed/Return Circuit Open
44=RH Primary Crash Sensor Not Mounted to Vehicle Properly
45=LH Primary Crash Sensor Not Mounted to Vehicle Properly
51=Air Bag Diagnostic Monitor Internal Thermal FuseFuse Blown Due to Intermittent Short to Ground
52=Backup Power SupplyVoltage Boost Fault
53=Primary Crash Sensor Circuits Resistance to Ground or Air Bag Diagnostic Fault
Aug 04, 2015 | 2003 Toyota Corolla
How can i fix hp ink cart. if the strip was touched? Wont print that color anymore..black. its a full cart. but it just doesnt print it anymore.
You simply cannot. Once ESD field was broken to the touch that ribbon on the cart. is no longer serviceable meaning you cannot recharge it or nothing. You simply just have to purchase another or try to get a refund on it by taking it back to the store or sending it to HP.
Sorry that is just the way the ball bounces I know you where looking for a way out of this issue.
I like being honest instead of costing you more money..
Please do leave feedback and ratings for your free answer today!
Oct 20, 2009 | HP Photosmart C4580 All-in-One InkJet...
Yellow not printing on test print -
You either have a leaking cart or the print head has become cross contaminated. Remove all the carts and check the feed hole under each of them. Make sure they are the color of the ink in the cart. Remove the print head and, using a damp cotton bud (water ONLY!) give the print head a clean. DO NOT use the same cotton bud for all sponges.
If that doesn't solve it then take the print head to a re-inking firm and have it cleaned professionally. Won't cost much and will hopefully solve the problem.
Sep 14, 2009 | Canon Pixma iP4500 InkJet Printer
Can't print
It means "manual feed".
Go in to the menu, under paper handling (i think) and turn manual feed "off"
Mar 27, 2009 | HP LaserJet 4 plus Printer
Hi hello
You must replace both ink cartridges with GENUINE HP ink carts..
Jan 20, 2009 | HP PSC 1410 All-In-One InkJet Printer
Error message 83 - photodev cart exhausted
The photoev cart is the photo developer cartridge.
See User Reference
http://www.lexmark.com/publications/pdfs/c510/eng/userref.pdf
Understanding printer messages
pages 184 and 185
"Message:
83 Photodev Cart Exhausted
What this message means:
The photodeveloper cartridge is completely used.
What you can do:
Replace the photodeveloper cartridge.
See also: Replacing the photodeveloper cartridge [page 73]
Continuing below
Message:
83 Photodev Cart Life Warning
The photodeveloper cartridge is nearing the end of its life.
What you can do:
• Press Go to clear the message and continue printing.
• Replace the photodeveloper cartridge.
Continuing below
Message:
83 Photodev Cart Missing
The photodeveloper cartridge is either missing or incorrectly
installed.
What you can do:
Correctly install the photodeveloper cartridge to clear the message and continue printing.
See also: Replacing the photodeveloper cartridge [page 73] "
Dec 08, 2008 | Lexmark C510 Laser Printer
Printer cartridge missing
Make sure ur using the correct cartridge.....
for X2580 the cart number is 2 and 3
1.Cleaning the copper contacts on the carts as well as the copper contacts inside the cartridge carrier......
2. Remove the carts....and install the carts thru the solution center...(Start-programs-lexmark-solution center-maintenence -install carts
Clean the ink nozzel using a wet paper towel.....do not whip it ..just press and hold the nozzel....do this 3 or 4 times....
then
Install the carts...
open solution center.....click maintence tab...click on "clean to fix horizontal streaks"...
-----XXXX----
Apr 09, 2008 | Lexmark All-in-One Printer with PictBridge
Not printing at all!
Change your cartridge and then try again
Sep 23, 2007 | Canon i9900 InkJet Photo Printer
HP Deskjet 632C Printer
When you say you get blank pages do you mean the printer goes through the process of printing (i.e. head whizzing back and forth, page advancing one line at atime) but no ink actually reaches the page? If so, you should try an under head cleaning session - check my previous post here for details: http://www.fixya.com/support/t137335-problem_print_outs_from_printer If this is not the problem you are experiencing, please give a little more detail be adding a comment to this post. Also check that there is actually ink in the carts Shake them gently and listen for the sloshing and see if they are heavy enough. This is especially relevant if you use refilled carts. As carts are refilled the capacity is gradually reduced, so you will get less prints per refill and the printer will not realise they are empty. As far as the paper feed goes, get hold of some platen cleaner and clean the feed roller that grabs the paper and feeds it in as well as the seperator rubber. This will return thier 'grippyness' and help prevent the multi page grab. Also ensure the cork pad is dust free.
Jun 23, 2007 | HP DeskJet 3650 InkJet Printer
78 people viewed this question
Top Kroy Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Kroy Office Equipment and Supply Expert? Answer questions, earn points and help others
