Question about Mitsubishi Televison & Video
AFTER MY TV WARMS UP AFTER A COUPLE OF MINUTES THE PICTURE HAS A RAINBOW EFFECT, IN THE CENTER OF THE TV THE PICTURE IS GOOD BUT MOVING OUT FROM THE CENTER THE RED, GREEN, AND BLUE SEPARATES. MITSUBISHI MODEL WS-65819
I have a same issue. What part is failed? Give us a solution. Thanks.
Posted on May 08, 2008
SOURCE:
Magnavox tv
try degaussing the screen... if your tv doesnt have that option, here are some ways to achieve that http://www.wikihow.com/Degauss-a-Computer-Monitor
Jan 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
Strange rainbow.reenish type effect
Did you notice any better picture when you play a movie on a DVD player or using a flashdrive on this TV? Is the picture quality better? Or is it the same? Try to check another cable connection or try to play TV channel thru internet. The last option in this case is to show a TV mechanic for he would better understand which part to order.
Jan 20, 2014 | LG 60PZ550 3D Plasma TV
Rainbow colors from bottom of screen to top corners
Check its degaussin posistor. Replace it. This component can be located at the main power regulator section.
Picture of the suspected component attached.
May 23, 2012 | RCA TruFlat 27F520T 27" TV
Has a double picture and looks rainbow
A double pcture with two different colours??? more seriousely the rainbow effect could be of an appature grill un hooked in one of the three tubes (THIS IS DANGEROUS IT COULD IMPLODE) you should have a proffessional looke at it and you should NOT USE OR MOVE the TV until then.
Jan 04, 2011 | Sony KP-53V75 53" Rear Projection...
Has rainbow lines on tv screen
shadow mask is warped. tv might have been dropped. crt is bad(picture tube). try deguassing it. if you dont know what that is take it to your local service center. the rainbow effect is a magnetic field of some sort. try unplugging and move to a different location. could be a speaker too close to tv.
Nov 12, 2009 | RCA F36650 36" TV
We have no picture, just rainbow pinkish effect, no sound either.
I have a Philips Matchine television which does a similar thing, the problem is in the receiver part of the set, where I have traced the Video signal with an Oscilloscope to a particular Chip (Integrated Circuit). By increasing the Contrast to maximum the picture can be brought back again, but still lacks contrast. The fault is varies as the chip warms up. Therefore you can locate the chip by cooling or heating it from a special non inflammable spray can.Have you tried the scart input which may work OK, then you can use the television as a monitor, as I do. Cost of repair is not worth it.
Nov 11, 2008 | Philips Magnavox 27MS343S 27" TV
Tv needs fixing, advice appreciated
it would intermittedly display a bowed rainbow effect and the picture would jump to that/black/back into focus. it was nothing but due to change of place due to decaussing ckt to take care of magnetic effect of earth. this morning i turned it on with a black screen. It has audio but no video. your problem it sounds me that it is due to loose contact or loose connector or due to video ckt. as you said that sudio is ok. if you are not tech person call skilled tech to fix it .it is not a major problem. hope this will help you please let me know what happened.
Sep 29, 2007 | Toshiba TP50F60/61 TV
Concave picture with rainbow effect at the edges
Hello, Check and replace IC1606 (P/N: 875292571) and IC1608 (P/N: 875982987). Best regards, Arpi http://www.partstore.com/sl/2/418644-ic-cxp86448635q-875292571.html
Apr 23, 2007 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
95 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
