Question about Eagle Fishmark 320 Portable Fishfinder
Transducer placement on pontoon boat
Where do you place the transducer on a pontoon boat?
Can a hds7 be installed on a pontoon boat? If so which pontoon to put the Tran-ducer and side scan on
Transducers with side scan need to be level with the bottom of the pontoon or below it otherwise the signal will be blocked by the pontoon.
Jan 05, 2018 | Boating
Piranha 1. I want to mount it on a pontoon boat. Do I need a bracket for the transducer?
Yes, there should be a small rectangular mounting plate on the rear of one of your pontoons.
Mount your transducer on that plate. If you don't have a bracket you can order them from humminbird.
If you need it you can download a PDF file on transducer installation from the hummingbird website.
Aug 01, 2015 | Boating
Why do I get a clearer picture on my screen when I set my transducer on single 200mhz beam,and the picture is not clear and I get a poor bottom view when set on single 83khz or dual beam 200/83 kHz.
It it understandable that different resolution would give you a better picture bit, loosing reception??? Judging from what you have tried I suspect the cable is damaged some place. If you have extra cable... try not to have the excess cable rolled up in a tight roll. This may cause interference. Make sure the transducer is aimed as flat as possible.
Feb 04, 2015 | Boating
Correct installation/placement of humminbird 898c si transducer
You can take a picture of the transom of the boat and email it to our customer service group and they will give you an idea of where the transducer needs to be mounted. There email address is service@humminbird.com.
Feb 12, 2011 | Sport & Outdoor - Others
2005 Water Skeeter Pontoon..What kind of pump for the valves
If you look up Halkey-roberts valves you will see the air filler part.
May 24, 2010 | Water Skeeter Guide Lite Pontoon Boat
I need a new inflation valve for my colorado pontoon boat
Check E-bay -
Item number: 310151809453, Pontoon Boat Boats Outdoor Parts Repair Kit Kits black
What is your problems with pontoon bladder
Thanks for reply
May 30, 2009 | Sage Colorado Pontoon Boat
Eagle Fishmark 320 Portable Fishfinder Logo
154 people viewed this question
Top Eagle Boating Experts
Steve
Steve
ray gallant
Phil Walker
Phil Walker
Are you an Eagle Boating Expert? Answer questions, earn points and help others
