Question about Xerox CopyCentre C20 Black and White Copier
Had a paper jam, cleared jam. Had made probably 30 copies prior to this happening and then the copier doesn't work - open heat error
    New Friend:
  • 44 Answers
You probably had an overheating condition that opened the thermostat of the fuser.You'll have to replace the fuser assembly because it is not a resetable thermostat.But before you do that, check the wiring (two smal white wires exitin from the fuser) for an open cirquit or a bad connection to the terminals.
Posted on May 28, 2010
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
08,045.43:5458 power outage happened, when power
This error indicates that the paper path motor stalled. Clear the paper jam, power off the printer for 30 seconds and then turn it back on.
Here's how to clear a paper jam from Xerox website, depending on the location of the paper jam: http://www.support.xerox.com/support/phaser-8560mfp/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 19, 2011 | Xerox Phaser 8560MFP Laser Printer
I have a GESTETNER DSM645SP copier,fax,scanner,and printer....Everytime I try to print or copy the copier jams..."PAPER MISFEED (J016)". I clear the paper way and try again and it still jams. Help
If it is not a "real" paper jam, just an error message, you most probably would need the right driver for your device to get this work properly. If google is of no help, just send the model numbers of device and operating system to http://manualfox.com/driver.htm and they will come back with a solution.
Aug 24, 2009 | Office Equipment & Supplies
Error code E522. How to fix this?
You have an issue with your staple finisher, probably need to inspect the stapler unit itself to make sure nothing is jammed in it and it moves freely. If you can't clear the error then most likely the unit is defective.
Hope this helps,
TankMurdock
Apr 24, 2009 | Canon NP 6551 Black and White Copier
Carriage jam on HP Photosmart 3210 Printer
most likely the sensor on the paper path out of position, chech it out and put it back to where it have to be, good luck!
Dec 13, 2008 | HP Photosmart 3210 Printer
HP 6210 All-In-One
Open up the top and look into the cartridge/paper print area. Look in the corners, Sometimes little pieces of paper can still be stuck there. Once you are convinced that the paper and cartridge path is clear then...
Pull out the paper tray. Look inside the opening. If there is paper there then pull it out.
Take all of the paper out of the paper tray.
Turn it over (paper on top is now on the bottom of the tray)
Try it now.
Jun 20, 2008 | HP OfficeJet 6210 All-In-One InkJet...
PAPER JAMS
Does the fault clear when you open/close? If it does you probably don't have a jam.
Does the machine begin to try to make copies, then stop-if so it has probably failed to feed off the tray, hence the jam message.If this is the case, pull out the paper tray, check for obstructions, clean feed rollers and try again.Are there "skid marks on the paper(indicating the rolls have turned?) If so rolls could be dirty/worn. If no skid marks, can you determine if the rolls did in fact turn? Go from there
Nov 11, 2007 | Office Equipment & Supplies
Xerox CopyCentre C20 Black and White Copier Logo
129 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
