Question about Hotpoint Washing Machines
Hotpoint WMF540 - mouldy soap dispenser drawer
I have a Hotpoint WMF540 and the soap dispenser drawer has gone all mouldy inside.
How do I remove the drawer for easy cleaning?
dazmaraz
  • 67 Answers
SOURCE: Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
you have a blocked filter, unplug from mains, take off back panel you will see a black sump hose coming from the tub to the pump, tilt the machine forward and put a dish or bowl under sump unscrew clamp and pull off slowly to release any water in the drum. You will find a blockage, also what appears to be a ping pong ball dont throw away it is meant to be there.
Posted on Mar 07, 2008
SOURCE: Soap dispenser
I got my fixed last night. It was the "lid" for the softener despenser that was making the drawer stick. To remove it you need to take the top off of the washer. There is are two plastic "holders" on the back of the machine that hold the top onto the machine. Each of these "holders" have two screws, remove them, then remove the holder. You can then, with some effort, slide the top of the washer towards the back the then lift it off. You will then be able to see plastic tub that contains the drawer for the despensers. You can't remove this tub, but on the side facing the inside of the washer are a couple of tabs holding the top of the plastic down. You can gently release these tabs and pull up on the top slightly. This gave me enough "play" to then open the drawer. The problem, I believe, is that over time, that tub moves and makes it impossible for the drawer to open. With trial and error, I found that with removing the "lid" for the softener despenser, and completely closing the lid of the plastic tub, that that solved the problem.
Posted on Apr 05, 2008
MNTECH
  • 1543 Answers
SOURCE: Fabric softener not draining
Remove the dispenser drawer by pushing down on the tab at the center back and pulling drawer out. Now, remove the top of the fabric softener compartment and the parts of the soap dispenser and clean them all out. An old toothbrush often helps. Reassemble and replace. They should siphon out now.
Posted on May 23, 2009
  • 161 Answers
SOURCE: HOW TO CLEAN SOAP DISPENSER DRAWER ON LG WASHER
On the very back top of the drawer is a lock lever that you depress to relase the drawer. Push it down and pull drawer out. Clean and replace.
Posted on Jan 27, 2010
FitzOriginal
  • 842 Answers
SOURCE: does the hotpoint auarius have a filter that needs
It does, but our loving friends at Hotpoint put the filter UNDER the drum and it can only be got to by drgging the machine out and attaching from the rear. The filter is the size of a large coffee mug, covered in rubber, directly below the cetrre of the drum and held in place by a large jubilee clip. Remove the clip, pull off the rubber boot and inside is a white conical "pot" with a ping pong ball in it. HOWEVER. Before you do this, if you are getting smells, first take 3 DISHWASHER tablets, throw them in an empty washer and put it on the hottest whites cotton program you can. Modern biological powders use bacteria to "eat" stains and when they get trapped in the machine, they can smell. Dishwasher tablets are made to wash and to KILL bacteria. It may help. Its a good thing to do anyway every now and again and it may save you a fruitless job dragging the machine out for no reason.
Posted on Jun 04, 2010
Testimonial: "many thanks fitzoriginal will try the dish washer tablet remedy."
How do I remove the soap dispenser draw to clean it?
In general, soap dispensers are designed to be integral to the machine. While the machine was put together by human hands and therefore should be able to be disassembled in the same way, it may very well be more of a task than you wish to take on.
This answer assumes the dispenser is basically functional and you have no reason other than cleanliness to want to remove it.
I suggest you clean the dispenser in place and forego removing the unit. I think you will be happier in the long run with this approach.
Good Luck,
Pete
Sep 28, 2015 | Indesit Genuine Hotpoint Wmf540 Wml520...
The drawer section for conditioner is clogged. how do I unblock it
Hi.
Open the door and pull it out. There may be a clip or button to press down at the very back of the drawer.
Clean it thoroughly under hot water. remove the softener compartment and thoroughly clean. also clean inside soap dispenser body.
regards
Aardvark repairs
Nov 18, 2009 | Hotpoint BWM12 Front Load Washer
Detergent drawer gets mouldy and smells all the time bleach and mould removing products don't help what else is there
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 07, 2009 | Washing Machines
How to change a door seal on a hotpoint wma58
Firstly remove band holding front of seal then remove the screws from the door lock and push lock through.
Remove kick plate from bottom of machine &take out 2 screws holding front of machine.
Remove soap drawer &take out screws behind it then bring facia forward & slide to right to remove. Take care at this stage not to disturb wiring on cicuit board. An extra pair of hands would be helpfull to hold it.
Remove screws holding front as you did at bottom then lift and remove front panel.
Seal is now easily accessed.
Post back if any further assistance needed.
Thankyou for using Fixya.
Jan 26, 2009 | Hotpoint WMA58 Front Load Washer
Water is leaking from soap dispenser only at beginning of cycle
Remove dispenser drawer, and check for soap blockage.
Locate and clean filter, check to see if there is one located behind bottom kick strip, if no filter there, then you will have to remove lower rear cover of washer, and locate and remove the large black hose on bottom of tub.
Remove filter and plastic ball,clean and replace.
Refit filter, ball and hose ,ensuring it is fitted correctly.
Test for leaks.
Plz ratev my solution.
Thanks.
Jan 14, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
Dec 28, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
SOAP DISPENSER HOSE
take both star screws from under lugs on either side of the lid remove that then take soap drawer out if screws are not visable remove front facia panel the same screws which hold the facia will also hold the soap drawer in place as you lift the drawer you will be able to undo the hose to the drum.
Mar 08, 2008 | Hotpoint WMA64 Front Load Washer
Hotpoint Aquarius WF 240 Front loader
first remove the soap drawer, this should expose locating holes for screws, remove these first, then remove the screws from on top of the plastic front panel and then the plastic front panel tilts forward to remove, taking extra care with wires etc the soap drawer is now loose still attached to the rubber pipe, which is now easy to get to for inspection, or removal to clear it out. first of all just check that the machine drum is not filling up totally so it is overflowing back out of the soap drawer, if so that is a different fault entirely and does not need taking to bits the same
Sep 21, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Washing Machines Logo
183 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
