Question about Kenmore Elite Oasis 27052 Top Load Washer
Lid lock won't release ?
Have tried unplugging to reset ~ but goes back in mode of beeping and a du (?) smybol in display
  • 15,935 Answers
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
I have a whirlpool cabrio and the lid will not lock the light keeps flashing and it keeps making the lock clicking sound
BEFORE ASSUMING THE LID SWITCH NEEDS REPLACEMENT TEST WITH A METER, BUT FIRST TRY TO RESET CONTROL BOARD EVEN RUNNING A DIAGNOSTIC TEST WILL REVEAL THE SOURCE OF THE ERROR.. 1. Be sure the washer is in standby mode (plugged in with all indicators off; or with only the Clothes Clean or Done indicator on). 2. Select any one button (except POWER, START, STOP, and PAUSE/CANCEL) and follow the steps below, using the same button: a. Press/hold 3 seconds. b. Release for 3 seconds. c. Press/hold 3 seconds. d. Release for 3 seconds. e. Press/hold 3 seconds. ? If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display. ? If indicators do not display as described above, the press/hold/release procedure above may not have been performed within the time frame necessary for successful entry. Repeat step 2 to ensure this was not the cause. If still unsuccessful, see Diagnostic: Unsuccessful Entry, at right. 3. The test sequence continues by checking for saved fault codes: ? If there are saved fault codes, see Diagnostic: Saved Fault Codes, page 2. ? If there are no saved fault codes, all indicators on the console will momentarily turn off, then turn back on with 88 displayed. After 5 seconds, the Automatic test, below, begins.
http://www.applianceaid.com/pdf/Whirlpool-Cabrio-Waher-WTW6600SB3-Tech-Sheet-W10026634.pdf
TEST #8 Lid Lock Perform the following checks if washer fails to lock (or unlock). 1. Perform Manual: Lid Switch and Manual: Lid Lock tests on page 2. 2. Remove the console to access the machine/motor control assembly. See Accessing & Removing the Electronic Assemblies, at right. 3. Visually check that the P12 connector is inserted all the way into the machine/motor control. ? If visual check passes, go to step 4. ? If visual check fails, reconnect P4 and repeat step 1. 4. Check the lid lock motor winding and switches by removing P12 from the machine/motor control and checking the resistance values shown in the following Lid Lock Resistance table:
TO RESET TURN KNOB 1 FULL TURN COUNTERCLOCKWISE, THEN 3 TURNS OR CLICKS CLOCKWISE, 1 TURN COUNTER CLOCKWISE, 1 MORE TURN CLOCKWISE, THEN HIT START , ALL THE INDICATOR LIGHTS SHOULD THEN LIGHT UP, THEN UNPLUG FROM THE WALL FOR 5 MINUTES THEN PLUG BACK IN , IT SHOULD BE RESET AFTER PLUGGING BACK IN
Feb 11, 2017 | Whirlpool Washing Machines
The lid lock light won't stop blinking.
LID LOCK FAULT
Fault is displayed if Lid Lock has not moved into locked position or motor cannot be powered.
Lid is not closed completely due to interference.
Check for lock interference with lock striker.
Wash media buildup (detergent, lint, etc.) is preventing the lock mechanism from sliding.
Main control detects open lid switch when attempting to lock.
Main control cannot determine if lid lock is in a locked state.
Perform the following checks if the washer does not lock (or unlock).
1. Perform the Lid Lock test under Manual Test Mode on page 9. The following steps assume that this step was unsuccessful.
2. Check lid lock mechanism for obstruction or binding. Repair as necessary.
Oct 20, 2012 | Whirlpool LSB6200KQ Top Load Washer
Washer displaying du code with 3 quick beeps
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
TEST #8 Door Lid Lock
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Aug 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Du error code on whirlpool cabrio
that code is for the door unlock error. is it possible that you may have tried really hard to open the units lid when it was locked? if so the door lock may have been broken. if not, then try to unplug the unit for a few minutes and try a new cycle.
if the code comes up again then you will have to call for free service as it has a 1 year warranty for parts and labor. yes even if you broke the lid lock!!! dont worry it happens when you get something new and are not sure how it works.
Dec 29, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer keeps reading Du
sounds like lid lock failure clips each side just below top eadge of washer about 3-4 insches from outside edge use stiff putty knife to push clips in and release top should be able to acess switch from there swtich will need replacing
Apr 29, 2008 | Kenmore Oasis HE 27082 Top Load Washer
DU error code
liz, DU could mean a couple of things. Something is preventing the lock bolt from retracting or the motor control cannot determine if the door lock is in a unlocked state. With the lid closed put it in a manual test mode by pressing any key except for power, start and stop. With all indicator lights off, press and hold for 3 seconds, release for 3 seconds, press and hold for 3 seconds, release for 3 seconds, press and hold for 3 seconds. If done correctly 88 should appear. While this 88 apears press the same key again within 5 seconds. You are now in the manual test mode. Now go over and press the second rinse or extra rinse key. This key will toggle between lock and unlock. See if the lock assy. is working. To exit the test, just unplug the washer for 60 seconds. If you don't have any luck with the test, you will have to do a bunch of tests on the lock mechanism to determine if in fact that is the problem. If it's under warranty, I would have the service company get into that. Catriver
Dec 15, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Locked Lid, error code "du"
blat, unplug the washer for 30 seconds and plug it back in. Hit the power key and do the following: press any key except for power, start and stop in this order, press and hold for 3 seconds, release for 3 seconds, press and hold for 3 secnds, release for 3 seconds, press and hold for 3 seconds. The 88 should light up in the display if done right. While the 88's are showing (you have about 5 seconds) press the same key again. You are now in the manual test mode. Now by pressing the 2nd rinse or xtra rinse button, you should be able to lock and unlock the door mechanism. You can check the p-12 harness on the main board to make sure it is seated all the way. This test proceedure has to be done pretty precise or it will fail....Catriver...post back.
Nov 25, 2006 | Kenmore Oasis HE 27062 Top Load Washer
Oasis - DU and LF error codes
Ky, see if you can put the machine in the service mode by doing this: turn the washer on, select any one button except for power,start and stop. press and hold it for 3 seconds--release for 3 seconds--press and hold for 3 seconds--release for 3 seconds--press and hold for 3 seconds....if you entered it correctly all the indicators will light for 5 seconds and 88 will show in the 2 digit display..It will now go into a automatic test cycle. If no faults are found it should unlock the top. This auto test will go through c0 to c9, you will see it in the display. If this all fails, you can access your wash by pushing in the clips on the left and right side front of the washer lid. The whole top will lift up. I would still call for service while it's under warranty. Catriver...post back.
Sep 11, 2006 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
110 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
