SanDisk Sansa E280 MP3 Player Logo
Posted on Apr 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sandisk sansa e280
My son recorded a song , I plug it in to the computer to recharge, it just went dead, computer not recognizing it, keep coming out the name of the product over and over again in the screen
ThaMp3Doctor
Level 3:
  • Master 8,597 Answers
  • Posted on May 23, 2008
ThaMp3Doctor
Master
Level 3:
Answers
8597
Questions
Helped
2173475
Points
14133
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Sandisk sansa e280 will not down load songs
The Sansa player will only recognize certain file formats. The songs with a Red X are not eligible to be transferred to your player, because their DRM license does not allow transfer to certain (or any) mp3 players.
It is best to use songs that are in mp3 format only. They will give you fewer headaches.
iTunes songs will not work with this player.
-Tha Mp3 Doctor
Sansa 280 died, tried to rechrg but is not recognized by computer
Make sure the hold/lock is not engaged first.
Here is a friendly tip posted from another user - let me know if it works:
ok so i called 1-866-sandisk and she told me how to fix it. you just flip the key lock at the top so you see orange, then hold down the record button. then you should get some sort of message on the screen. then you plug it in and under my computer a file should show up. you open it and make a folder in it called sansa.fwm (i think thats the right folder name, if not, try sansa.tmp or email me). then you unplug it and it should say formatting or something like that. once its done it should work.
2answers
Micro sd card
Does your computer has an internal card reader?
Sandisk keeps skipping/freezing songs!
or
-Tha Mp3 Doctor
2answers
Sansa E280 isn't recognized by Vista
-Tha Mp3 Doctor
New Sansa e280 is "dead"?
hold the power button for 15 sec.
dosent work? just a guess.
Sansa e280 froze
It is probably because you have folders inside of folders inside of folder... i just had the same problem and copied all the songs in a folder into the main folder IE
dont do this
sansa>music>artist>album>music file
do it like this
sansa>music>artist>file
2answers
Sansa e280 malfunction
i have solved my problem !!
if it says connected and when you plug it and out and it is still not working you just plug then unplug (might take some time)
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
