The fuse inside the air condition blows when the compressor tries to start
  • 36 Answers
Does the fuse blow the first time the ac starts blowing cold or after a few minutes..
Posted on May 27, 2010
What would make my air conditioning compressor, body function control module fuse keep blowing
Unplug compressor and other related parts and try the fuse then,,this will tell you which part is the problem.
Dec 04, 2017 | Cars & Trucks
2004 VW Passat AC is blowing hot air
Have the dealer check to see if the AC compressor cycling switch is stuck.
Jun 14, 2012 | Cars & Trucks
Ac fuse blowing, in 1996 isuzu rodeo
Disconnect wire to Air Conditioning Compressor and connect normal test light to wire, from engine harness(body)side. Fit new fuse and try air cond controls and switch, test light should light up and hopefully fuse wont blow indicating short in compressor clutch windings(replace compressor). If fuse blows while doing this test compressor might be ok and fault short some where else, fan speed resistor block, fan or control/switches, wiring.
Jul 19, 2011 | 1996 Isuzu Rodeo
I have a 2000 Dodge Neon that keeps blowing the ignition and air conditioning fuse. It will crank, but when you put it in drive and accelerate...the fuse blows and it dies. Just before this started the...
Before you do anything else, please review this article:
Where's The Fuse?
Then I would say that the most likely cause of your problem is that the A/C clutch circuit is shorting out.
Jun 02, 2011 | Dodge Neon Cars & Trucks
10 amp fuse blown, air compressor will not run.
whats the fuse for. if it operate the air conditioning system on the engine fuse box ur compressor clutch is burnt. if its the fuse inside the car it o\powers the hvac controls. put a new fuse on unplug ur compressor clutch connector and turn the engine on switch your air conditioning and heating controls on and off see if it blows the fuse again if it does then u have a problem with ur inside wiring circuit or heating ventilation air conditioning controls. good luck.
Feb 20, 2011 | 2005 Hyundai Sonata
My duted air conditioning started blowing hot air instead of cold and then stopped. blew a fuse and now will not work
Sounds as if the compressor has gone bad. The blowing of hot air and then the fuse blowing lets you know the compressor is pulling a lot of amps causing the fuse to blow and no cold air could mean the compressor is locked up and therefore you need a new compressor.
Dave
Jan 24, 2010 | Honeywell ER150B Air Conditioner
My air conditioning blows hot air. Won't accept
Is the system low on Freon? If not, you most likely have a bad A/C compressor, or a bad low pressure switch.
Jun 10, 2009 | 1998 Ford Mustang
The air conditioning,the blower fan everything stopped working, on 2002 Nissan Sentra. Does anyone have any suggestions?
One suggestion. Have you checked the fuses ?
I would check the AC or blower fuse to start with. If you have the drivers manual it will show you where the fuse box is. Typically there are at least two boxes to check. One in the Engine compartment and one in the passenger cabin.
Look inside the lid of the fuse box to see which fuse may apply to the AC circuits or the blower and check to see if they are blow. the metal link between the two posts that plug in. If the link is missing you need to replace the fuse with one of the same rating. Make sure you know where you took the fuse out from and put it back in the same slot if its good. Check all the main fuses if possible to see if any have blown and replace if they have.
Aug 12, 2008 | 2002 Nissan Sentra
Ac conditioner stopped blowing
do you mean the fan doesnt blow either or its just not blowing cold air? check your fuses under dash and under the hood
i can try to help you further with more info
Jun 14, 2008 | 2004 Acura TL
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
